05-24-2023, 12:13 PM | #23 |
Rep 2,349
My point exactly, an entire brand designed for people who don't drive their cars properly
05-24-2023, 12:34 PM | #24 |
Rep 140
I went to a few BMW-sponsored autocross events over the last couple of years where cornering & handling are emphasized more than top speed. There's no way I would've gotten my results with a steering wheel that was anything else but round.
Joralemon st.770.50 karpman920.50 |
05-25-2023, 07:04 AM | #25 |
BMW Owner Since 1971
2257
Rep 1,406
Drives: 1964 700 Sport Cabriolet
Y'all probably haven't spent much time behind the awful squared-off wheel of the BMW iX50 or ixM60 tanks yet.
05-26-2023, 02:03 PM | #27 |
Rep 3,626
the flat bottom only works if the car has an extremely tight steering ratio. it also helps ingress/egress from bucket seats. i'd rather have the round one especially for sliding the back end around.
it works in ferrari's because they have extremely fast steering with a tight ratio. a little trick they do to make the car feel lighter than it is. Alfa does the same thing
2018 Porsche GT3 6MT 2021 M2C DCT Previous: Ferrari 458 | R35 GTR | F80 M3 | E46 M3 | E36 M3 | Scion FRS |
chris7197334.00 |
05-26-2023, 02:32 PM | #28 | |
Rep 4,142
can't grab a hexagonal or flat wheel easily example below is a very mild and controlled example where you can follow the wheel by moving your hands if you wish, but some drifts are much more forceful and violent and following with hands is not an option. Last edited by G30M; 05-26-2023 at 02:49 PM.. |
05-26-2023, 03:13 PM | #29 |
Rep 2,362
Drives: G87 M2; E92M3 MT&DCT; M3 euro
It's hard to drift with a flat bottom steering wheel, meaning it is harder to counter-steer.
D-shaped handles on street cars are for posers, not for performance drivers.
Pass me if you can.
05-31-2023, 01:52 PM | #30 | |
Rep 2,163
And unless your car is primarily a track car, then a flat-bottom wheel still works...as those of us who track our cars a few times/year (like me) pales in comparison to accruing 99% of the miles on the street. |
05-31-2023, 05:13 PM | #31 | |
Rep 836
https://bmw.fanatec.com/ Rally and drift are probably the only motorsport application of round wheels. Most classes seem to be D or yoke type wheels. |
05-31-2023, 05:43 PM | #32 | |
Rep 14,115
Drives: G82 M4C X-Drive
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
06-01-2023, 07:24 AM | #33 |
Rep 2,268
They make performance steering wheels—I have had an alcantara M perf wheel on my 1M for the past 9 years and it’s great!
don't read this. too late...
06-01-2023, 09:25 AM | #34 |
Riding the knock sensor
2371
Rep 1,591
Drives: 21 X5MC | 23 M4CSL
Flat bottom wheels allow for a bit more leg clearance given the driver position, knee angle, and position of steering shaft. In a road car on track the typical driver can achieve the best results sitting further forward than would feel comfortable on the street, with the wheel telescoped further towards the chest and lower than normal. This position reduces strain on the arms and input delay. This ideal endurance racing position puts the elbows and knees at acute angles and increases potential to interfere with the bottom of the wheel. Given this position, a flat bottom wheel is ideal for driver changes making ingress/egress easier in deep bucketed race seats.
06-01-2023, 10:06 AM | #35 |
Bowties r cool ▶:◀
1409
Rep 796
Drives: 09' 128i MT e88, 24'G05 X5 50e
IX and XM have them
06-01-2023, 10:50 AM | #36 |
The Seeker
13863
Rep 3,323
But it's fair to say that not all professionals use the same technique. Letting the wheel slip has, in times past, been frowned upon, and is more for economy of motion rather than skill.
06-01-2023, 11:29 AM | #37 | |
Rep 2,362
Pass me if you can.
06-01-2023, 01:49 PM | #38 | |
Rep 4,142
obviously with BMW moving from ultimate driving machine to ultimate moving cinema there is no longer a need for round steering wheels |
06-01-2023, 02:02 PM | #39 |
Rep 256
I'm not a fan of the flat bottom, for steering wheels or other things of interest.....
Anyhow, they just seem to throw me off when driving, especially on the track. None of my track cars had a flat bottom steering wheel nor does my current Cayman GTS. While I know the majority of track folks hold the steering wheel only on the sides, I tend to do more of a shuffle which works well for me, and makes a flat bottom more difficult.
23 X3MC BGM. MSS. H&R 12mm spacers
20 4Runner 18 Cayman GTS 15 Beetle Vert |
06-01-2023, 02:05 PM | #40 | |
#buildnotbought
10855
Rep 4,893
Usually not something you do at the track as corners arent that tight there. With drifting you need huge steering angles (drifting suspension geometry is usually set in such a way that the max. steering angle is extended quite a bit), so there letting the wheel slip in your hand is a normal technique to get back to straightline fast. I think flat bottom steering wheels are also cumbersome and feeling unnatural when parallel parking (something I have to do every day multiple times) where you also overgrab the wheel looking the other way. Having that dip in the wheel just bugs me. To me the only advantage is in racecars (or arguably low slung sportscars) where you virtually lying down in position and the flat bottom frees up space. Or in a normal car when you're too fat and short to fit under the steering wheel. When you're tall you're setting the wheel in a higher position, and then the legs usually always fit. So I don't see any advantage in a normal car when you have a normal built, only disadvantages.
06-01-2023, 02:07 PM | #41 | |
The Seeker
13863
Rep 3,323
The Drift King himself does not use this technique. |
06-01-2023, 02:21 PM | #42 |
Rep 4,142
06-01-2023, 02:44 PM | #43 |
#buildnotbought
10855
Rep 4,893
He also doesn't use a flat bottom steering wheel.
BTW he uses a combination of techniques, whatever suits him best at the moment. as can be seen in this clip 11:10 and further. Letting the steering wheel slide as he casually uses the handbrake and gearshift. He makes it all seem really easy I don't think anywone frowns upon his technique and control, other than out of amazement.
06-01-2023, 04:37 PM | #44 | |
The Seeker
13863
Rep 3,323
He has, many times. I said this earlier, it depends on the set-up, but as a general rule he doesn't use the technique. It could be because his skill was forged with normal cars, or it's just his technique, but drifting, like guitar playing, doesn't have an exact technique for everyone. |
