05-27-2023, 09:16 PM | #1 |
Rep 376
Charging Times (According to BARD)
I asked BARD, the Google AI, the below question:
Q: Using a Level 1 charger, how long would it take to charge a 2023 BMW i7 EV? A: The 2023 BMW i7 EV has a 106.1-kWh battery pack and comes with a 1.4-kW Level 1 AC onboard charger. The following table shows the estimated charging times for the i7 EV using a Level 1 charger: State of charge........Time to charge from..............Time to charge from ..........................................1% to 100%..............................10% to 80% 0%.....................................47.2 hours.................................14.2 hours 25%................................10.9 hours...............................3.7 hours 50%...................................21.8 hours..................................7.4 hours 75%...................................32.7 hours.................................10.1 hours 90%...................................47.2 hours.................................14.2 hours MY two questions re the above then are: (1) Is BARD's response reasonably accurate -- especially the second line I placed in bold which claims that if I start charging an i7 with 25% battery power, using a Level 1 charger (i.e., plug a US standard 3-prong plug into a 120v outlet) that it would only take 3.7 hours to reach an 80% charge? and (2) If I drive very infrequently, why would I want or need a Level 2 charger (240v hookup that would have to be wired by an electrician for $$$)? - Mike Last edited by DroMike; 05-27-2023 at 09:17 PM.. Reason: Edits |
05-28-2023, 09:54 PM | #2 |
Rep 371
It is not accurate. These models can be (1) bad at math and (2) can hallucinate information.
You can do the math yourself. A level 1 charger typically maxes out at 1.5 kW, so it will fill up 1.5 kWh of energy per hour (hence kilowatt-hours). The i7 has a usable battery capacity of 101.7 kWh, so it will take 67.8 hours to go from 0-100%. There is no throttling when you are charging that slow, so it is a linear relationship. 5-95% (i.e. 90% charging) will be 90% of 67.8 hours (i.e. 61 hours), etc... |
05-29-2023, 01:10 AM | #3 |
Rep 376
Well, I was a little skeptical of that information as it was contrary to what I'd heard before. That's why I asked here in this forum for real-world info. Thank you very much.
The reason I asked was that I'm now starting to lean toward the all-electric i7 instead of the ICE 740i, so was wondering if I could get away with a Level 1 (120v) instead of a Level 2 (240v) setup. I knew there was NO WAY I was going to pay for a $5,000 circuit panel upgrade for the latter, but DID in the interim find I could obtain and use the SplitVolt circuit-protected, plug 'n play dryer switcher to negate any of that, so I'm all set now. BTW, I've caught BARD in a whole pack of lies or misinformation. I've learned to take him(?) with a huge grain of salt. Last edited by DroMike; 09-18-2023 at 02:05 PM.. |
05-29-2023, 06:32 PM | #4 | |
Rep 1,940
