06-01-2023, 12:53 PM | #1 |
Rep 3
New here - few questions on pre-LCI 740/750
Hello all! I'm probably going to be replacing my car in the next 6-12 months, and I'm considering a 2018-2019 740 or 750. It seems the 740 engine may be a bit more solid, but it also seems much harder to find those with the options I'd like... I have a few questions and thought this might be the best place to ask (apologies if this should have gone in a different sub-forum).
Thanks in advance for any info you can offer! |
06-02-2023, 01:23 PM | #2 | |
Rep 59
Drives: 2018 BMW 740i Xdrive M Sport
I don't do extended warranties, I self-insure. You either 'pay now' or 'pay later'. Since I bought the car and after the original warranty expired I probably had about $4500 in repairs which would have been covered by extended warranty however the cost of that plan (BMW OEM - same as original with no deductible, less hassle, etc) would have been $6,500 and would have expired in August 2023 so with 3 months left I am still 'ahead' by about $2K. That is why extended warranties are a gold mine to those that sell them. I don't have CarPlay and to my understanding it can be added. Remote start I am not sure. The HK sound system is amazing. Happy Shopping keep us posted on progress! |
06-04-2023, 08:24 PM | #4 |
Rep 342
Drives: 2019 BMW M760li
On pre LCI cars you can add Carplay and it works well. However you cannot add remote start. You only get remote start functionality with ID7 which can only be upgraded to with extensive parts changes on the infotainment system. Someone on this forum did it successfully but it was fairly expensive and involved.
Other than the change of exterior looks of the LCI car and ID7, there isn't too difference. I know the sound deadening was enhanced in the wheel wells and pillars to make the interior quieter. I’m not sure about engine enhancements but I’m sure there are minor updates to certain engines. If you aren’t a fan of the LCI exterior and don’t mind ID6, you’ll be happy with the pre LCI. |
06-05-2023, 01:10 AM | #5 |
Rep 186
Drives: BMW X5 and BMW 7 Series
When it comes to the Pre-LCI to LCI there’s a Handful of Difference(s):
1. The Harman Kardon Sound System is not Quite Audiophile Quality of Sound but the 9 Band Equalizer means you can fine-tune the song. (Keep in mind it’s a 600w System not a 464w System like LCI Cars) 2. For Apple CarPlay Support you **MUST** Have a 2017+ Model Year 7 Series to be compatible with Apple CarPlay. I bought it off of BMW ConnectedDrive for 300 Bucks and you can use Bimmercode to make it Full Screen. 3. The Extended Warranty in my Opinion is a good Idea as unexpected Repairs will Occur. This does not show the car is Unreliable but it goes to show the Vehicle has Many Electrical Components and what not and also you can Get a free BMW Display Key with a Extended Warranty. (You can get as many as your Heart Desires) 4. The looks between Pre-LCI and LCI Are Controversial I strongly recommend you see both cars in-Person. Paint and the spec make a huge difference when it comes to Looks, Now My personal take is: The Back looks Amazing but the Front big Grille fits the X7 better as there’s more room to the 7 Series. Now with the Display Key it’s 70 Dollars a Year to have all Functional items Active but to Summon the car you have to have specific options. I hope this all Helps! Cheers and Congratulations on The Future Flagship!
Danyal.N55
06-10-2023, 03:42 PM | #7 |
Rep 18
Drives: BMW 2016 750i & 2018 M760i
Hi.
Exciting! Here my point of view. 1. If taking the 750i I would recommend the upgraded engine post LCI (530 hp) because it is (even) more reliable. The pre-LCI has (e.g.) a quite common coolant system leakage problem which is now solved with the upgraded engine. 2. On Apple Car Play you should be able to retroactively activate it even with a 2016 model (my model and I did it) - but good to check - if it appears in the ConnectedDrive website then you can do it. 3. Lane keep and LIDAR: it may be my car but I think the ID7 version (and all related SW) from 2018 is better. My LIDAR/Lane keep is not as accurate. So if you want to go for a pre-LCI version (and don´t mind the engine risks of point 1.) - I perceived a difference in performance between the LIDAR/lane keep software from 2018/ID7 which was better than the 2016/ID6. 4. HK vs B&W. I do not know how the HK performs on the G11 - I recently tried it on a brand new 850i and it was nowhere near the B&W I have on the 2016 7series. HK is a good system. But if you care about sound and immersive experience, I would go for the B&W. These opinions are based on my direct experience by driving the following cars: 2016 G11 750i (my car) 2018 G11 740i, 740d, 740e 2021 G11 LCI 750i Hope it helps. |
akataka23.00 |
