04-26-2011, 02:55 PM | #1 |
Rep 81
Rub / No Rub Index
I just mounted a new set of wheels and tires along with installing the Dinan Stage 1 with camber plates. I did a good amount of research and asking questions and in the end was fairly certain I would not have rubbing issues. Well, I do rub...albeit slight. So, I thought I'd start this thread and perhaps it would be a good single source for those interested this topic. Here are my specs...
Car: 08 E92 Wheels w/ Offsets: HRE P40S - (F) 19x9 +25, (R) 19x10.5 +25 Spacers: None Tires / Miles: Yoko Advan 08 - (F) 255/35/19, (R) 295/30/19; New Tires Suspension: Dinan Stage 1 with camber plates EDC Setting: Normal/Sport Alignment: (F) -1.7 camber 1/16" toe (R) -1.5 camber 1/8" toe Fender Modifications: (F) None (R) None Rubbing?: (F) Yes, both sides, just barely kissing the liner on full lock (R) Yes, both sides, outside of tires rubbing the plastic nub on the wheel well liner mostly on bigger bumps at speeds over 40mph. Sounds nasty...and as you would expect rubs less frequently on Sport. Hopefully after some miles on the tires and the plastic nub wearing down it will stop. Hopefully there aren't too many other variables to consider in order to get a good sense of what you can expect when sizing up new goodies. Man I love this car. Cheers! db Last edited by dbacon; 04-28-2011 at 02:52 PM.. |
04-26-2011, 03:55 PM | #2 |
Rep 3,982
2011 E92 ZCP
19x9 ET 31, 255/35/19 Nitto Invo 19X10 ET 25, 285/30/19 NItto Invo Stock alignment and suspension. No rubbing at all. Dave
2020 Ford Mustang GT 6MT PP1 444rwhp
(Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk 2007 Porsche 997C2S Speed Yellow/Blk sport seats 2004 BMW M3 Imola/Blk |
04-26-2011, 03:58 PM | #3 |
Rep 3,454
not surprised on the front - I'm running the same size tire (although I'm running PS2's) and it rubs very slightly on the driver side when I have the wheel cut all the way to the right. it's just the overall diameter of 255/35/19 that causes it, because I have a different set of wheels with 265/35/18 (wider but shorter - also PS2's) that don't rub at all.
on the rear, that sounds tough. I went through a bit of this there's another guy on here with the same offset and tires who doesn't rub (Fastrack). I reached out to him because I went through some of this myself. Where are you rubbing? Maybe you can trim that rear bumper tab (where the rear bumper meets up with the upper fender). no point in posting my specs as I ended up having my fenders pulled to run a wider tire. post some pics of the new wheels! |
04-26-2011, 04:25 PM | #4 |
Rep 6,845
Drives: 2018 Audi RS5 coupe
Car: 08 E92 M3
Wheels w/ Offsets: VMR VB3 - (F) 19x9.5 +22, (R) 19x10 +25 Spacers: None Tires / Miles: Michelin PS2- (F) 255/35/19, (R) 275/35/19 Suspension: OEM EDC Setting: no EDC Alignment: Stock Rubbing?: nope |
04-26-2011, 08:19 PM | #5 |
Rep 1,599
2010 E90 M3 255&275/35x19 Vreds 9&10 Et22
Standard ride height. Factory suspension settings
Fronts: A few of the RAC group buy guys 9" +22 w/Vredestein 255/35 x 19's have reported rear fenderliner rubbing at full lock. My car with that setup just barely clears on both sides in the rear and left front. The right front just touches. Rears: 10" +22 w/Vredestein 275/35 X19 - Clear.
04-26-2011, 10:53 PM | #6 |
Rep 4,319
Car: 08 E90
Wheels w/ Offsets: RAC RG63 - (F) 19x9 +22, (R) 19x10 +22 Spacers: None Tires / Miles: Yoko Advan AD08 - (F) 275/30/19, (R) 295/30/19 Suspension: Stock EDC Setting: All Alignment: (F) -1.6 camber (R) -2.0 camber Rubbing?: (F) Yes, both sides, just barely kissing the liner on full lock (R) Yes, both sides, outside of tires rubbing inner fender lip under full compression over large bumps.
GT3 RS | Desperately seeking the next great M car...
04-27-2011, 12:21 PM | #7 |
Rep 1,278
2010 E92
Stock Rims 19x8.5, 245/35/19 Continental CS3's 19X9.5, 285/35/19 Michelin PS2's H&R Sport springs. No rubbing.
PAST 2007 Black Sapphire E90 335i, 2010 Jerez Black E92 M3, 2012 Mineral White E92 M3, 2013 Singapore Grey F10 M5, 2016 Azurite Black F80 M3,
CURRENT 2017 Oxford White GT350 |
04-27-2011, 08:08 PM | #8 |
Rep 2,278
TE 37 9.5 x18 et 28 front with NT05 275/35/18 - no rubbing
TE 37 10.5x18 et 22 rear with NTO5 285/35/18 - no rubbing I have ground control suspension with something like 2.4 camber front, 1.9 rear.
2015 f80 M3, 2016 GT3
04-27-2011, 09:14 PM | #9 | |
Commander-In-Chief
2206
Rep 8,949
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
04-27-2011, 10:55 PM | #10 |
Rep 1,599
I think it may be a tolerance thing so that some clear and some don't. You can see from the photo that mine really just touches.
04-28-2011, 01:35 AM | #11 |
yodog
197
Rep 5,025
Car: 09 E92
Wheels w/ Offsets: Advan RS (F) 19" +22, (R) 19" +20 Spacers: None Tires / Miles: Yoko Advan AD08 - (F) 245/35/19, (R) 295/30/19; New Tires Suspension: Eibach Springs EDC Setting: Normal/Sport Alignment: (F) -Unsure (R) -Unsure Rubbing?: (F) No. (R) Yes when going at a freeway speeds usually over 80mph and hit a sudden bump. Dips are fine but bumps are not. If I have people in the back this creates a greater chance for rubbing on the rear plastic of the bumper. No damage is visible and the fender seems to be 100% okay.
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle Special Thanks: Gintani | OETuning | eAs |
04-28-2011, 02:25 AM | #12 |
Rep 10,407
Good thread. A rubbing "database"!
Yes. I have the same setup and like Greg, no rubbing. Even as precise as modern cars are there are some tolerancing issues. Might even be a tire that is on the upper end of the overall OD tolerance range. Lots of plastic in this area does not help with final assembly tolerance.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | |
04-28-2011, 02:48 AM | #13 |
Rep 16
Hey,
New guy here with question regarding fitment and possible rubbing, etc. Interested in some 19inch wheels, M6 OEM. Have spoken to two dealers that say they don't fit but have seen a few posts here where people had them on for summer and/or winter tires. Not sure if those were OEM or replica? The OEM M6 167M wheels are: F 255/40/19 et12 R 285/35/19 et17 I am looking to fit to a 2011 M3 vert (E93). Anyone know the truth to this? Would I have t oalter the wheel well, roll fender, etc. Thanks |
04-28-2011, 09:37 AM | #14 | |
Rep 3,454
there are guys on here who have run OEM M6 wheels no problem. I think they look awesome, btw. with re: to rolling the fender, the M3's fenders are rolled from the factory, so there's nothing else you can do besides pulling the fender out more, which is a more serious job that requires paint work. |
04-28-2011, 09:39 AM | #15 | |
Rep 1,278
The rears will work fine however the fronts will rub. Grab 255/35/19's and you SHOULD be OK. Some members recently have complained of issues, but the majority of members are fitting 255/35's no problem. You could always be safe and run a 245/35 with no issues.
04-28-2011, 12:58 PM | #17 |
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
Car: 08 E90 Sedan
Wheels w/ Offsets: Volk G2 - (F) 20 x 9 +20, (R) 20 x 11 +29 Spacers: None Tires / Miles: Pirelli PZero Nero - (F) 255/30/20, (R) 305/25/20; New Tires Suspension: Eibach Springs EDC Setting: Normal/Sport Alignment: (F) -1.3 camber (R) Left -1.6 camber, Right -1.9 camber - apparently my rear alignment was "off" Fender Modifications: (F) None (R) None Rubbing?: (F) Slight fender liner rub at full lock (R) None __________________________________________________ ____________________ 2nd Set of wheels on '08 M3 Sedan - same car / alignment specs listed above Wheels w/ Offsets: Volk TE37 SL - (F) 19x9.5 +22, (R) 19x10.5 +22 Spacers: None Tires / Miles: Yokohama Advan AD08 - (F) 275/30/19, (R) 295/30/19; New Tires Suspension: Eibach Springs EDC Setting: Normal/Sport Fender Modifications: (F) None (R) dremeled the liner where it protrudes at the junction of the rear bumper and the fender. Rubbing?: (F) Yes, both sides, kissing the liner on full lock. Both sides also barely rubbing the inner side of the upper fender. (R) Yes, both sides, I think the outside of tires are still rubbing the plastic nub on the wheel well liner (I already dremeled it slightly) mostly on bigger bumps. Right rear also barely hitting the inner side of the upper fender. __________________________________________________ _______________ Went in for an alignment and Camber adjustment Alignment: (F) -1.6 camber (pins removed) (R) -2.1 camber Fender Modifications: (F/R) See above Rubbing?: (F) Yes, both sides still kissing the liner on full lock. Upper fender rub has been eliminated. (R) Slight fender rub on big dips (on front edge of rear fender 9:00 on Driver's side; 3:00 on Passenger's side) with 4 hefty guys in the car. It's slight enough that I called it a day and lived with it. __________________________________________________ _______________ NEW CAR - Car: 13 E92 Wheels w/ Offsets: HRE R43 (F) 18x9.5 +27, (R) 18x11 +30 Spacers: See "Rubbing" below Tires / Miles: Michelin Pilot Super Sport - (F) 275/35/18, (R) 285/35/18; New Tires Suspension: KW Clubsport - 3-Way EDC Setting: NA Alignment: Don't know but front camber is at least -2.0 degrees Fender Modifications: (F) None (R) None Rubbing?: (F) Yes - Front tire rubs KW spring without spacer (et27). Added 5mm spacer (resulting in et22) and still rubs very slightly but not detectable until wheel is removed - observed tire mark on spring. Added 12mm spacer (resulting in et15) and no inner rubbing but tire now rubs the fender liner at full lock (didn't rub the liner at et22). (R) None at et30. Added 12mm spacer (resulting in et18) and still no rubbing __________________________________________________ _____ 2nd Set of wheels on '13 M3 Coupe - same car / alignment specs listed above Wheels w/ Offsets: Volk TE37 (F) 18x9.5 +22, (R) 18x10.5 +22 Spacers: (F) 5mm - needed to clear KW Clubsport spring, (R) None Tires / Miles: Hankook RS3 - (F) 275/35/18, (R) 285/35/18; New Tires Rubbing?: (F) Yes - Front tire rubs KW spring without spacer (et22). Added 5mm spacer (resulting in et17) and no inner rubbing but tire very slightly rubs the fender liner at full lock. Not enough to cause any issues and difficult to detect any marks on fender liner. (R) None __________________________________________________ _____ 3rd Set of wheels on '13 M3 Coupe - same car / alignment specs listed above Wheels w/ Offsets: Advan TC3 (F) 18x9.5 +22, (R) 18x10.5 +25 Spacers: (F) 5mm - needed to clear KW Clubsport spring, (R) None Tires / Miles: Hankook RS3 - (F) 275/35/18, (R) 285/35/18; New Tires Rubbing?: (F) Yes - Front tire rubs KW spring without spacer (et22). Added 5mm spacer (resulting in et17) and no inner rubbing but tire very slightly rubs the fender liner at full lock. Not enough to cause any issues and difficult to detect any marks on fender liner. (R) None __________________________________________________ _____ 4th Set of wheels on '13 M3 Coupe - same car / alignment specs listed above Wheels w/ Offsets: Volk G25 (F) 19x9.5 +23, (R) 19x10.5 +25 Spacers: (F) 5mm - needed to clear KW Clubsport spring, (R) None Tires / Miles: Yokohama AD08 - (F) 275/30/19, (R) 295/30/19; Used Tires Rubbing?: (F) Yes - Front tire rubs KW spring without spacer (et23). Added 5mm spacer (resulting in et18) and no inner rubbing but tire very slightly rubs the fender liner at full lock. Not enough to cause any issues and difficult to detect any marks on fender liner. (R) None __________________________________________________ _____ 5th Set of wheels on '13 M3 Coupe - same car / alignment specs listed above Wheels w/ Offsets: BBS RGR (F) 19x9 +20, (R) 19x10 +25 Spacers: (F) None & 5mm tested, (R) None & 5mm tested Tires / Miles: Yokohama AD08 - (F) 275/30/19, (R) 295/30/19; Used Tires Rubbing?: (F) None without spacer but very close to Stoptech BBK. Added 5mm spacer (resulting in et15) and still no rubbing. There is a very slight rub of the fender liner at full lock with the 5mm spacer. Not enough to cause any issues and difficult to detect any marks on fender liner. (R) None without spacer. Rubs the fender with the addition of a 5mm spacer (resulting in et20) __________________________________________________ _____ 6th Set of wheels on '13 M3 Coupe - same car / alignment specs listed above Wheels w/ Offsets: HRE R40 (F) 18x10 +18, (R) 18x11 +30 Spacers: (F) None, (R) 12mm Tires / Miles: Michelin PSS - (F) 275/35/18, (R) 285/35/18; New Tires Rubbing?: (F) None (R) None
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 09-17-2013 at 03:57 PM.. |
04-28-2011, 01:10 PM | #18 |
Rep 1,962
Car: 11 E90
Wheels w/ Offsets: OEM ZCP + Spacers = 19x9 et16 / 19x10 et 15 Spacers: F 15 / R 10 Tires / Miles: 245/265-35-19 OEM PS2 - 11K Suspension: KWV3 EDC Setting: None Alignment: Stock Rubbing?: Absolutely none.
Peanut Butter Chunky
04-28-2011, 03:48 PM | #19 |
Rep 3,454
Car: 2011 E92
Wheels: HRE P40S - (F) 19x9.5 +22, (R) 19x10.5 +22 Spacers: None Tires / Miles: PS2's (F) 255/35/19, (R) 295/30/19; New Tires Suspension: KWV3 Alignment: (F) -1.5 camber (R) -1.8 camber Fender Modifications: (F) None. (R) dremeled the liner where it protrudes at the junction of the rear bumper and the fender. Pulled fender out slightly. Rubbing?: (F) none. (R) none. I originally ordered these wheels for a 285 in the rear. it did not rub at all, but when I wanted to increase the rear tire size to a 295, it stuck out slightly. the PS2's are also slightly larger than the Conti ExtremeDW's that I had originally. |
04-28-2011, 03:56 PM | #20 |
Rep 468
Car: 09 Coupe
Wheels w/ Offsets: GTS Wheel (ZCP) - (F) 19x9 +31, (R) 19x10 +25 Spacers: 10mm all around Tires / Miles: Mich Pilot Super Sport - (F) 255/35/19, (R) 275/35/19 Suspension: Stock EDC Setting: All Alignment: Stock Fender Mods - None Rubbing - NO rubbing |
04-28-2011, 04:26 PM | #21 |
Rep 3,454
IND did the work. I've tried my best to find evidence that it was done, but they did such a good job you can't even notice it. it wasn't cheap, but it was much less expensive than ordering new wheels.
04-28-2011, 05:40 PM | #22 |
Rep 1,203
Drives: 2021 M2C
I'll add mine. I'll post twice for both sets of wheels (summer/winter)
Car: 2011 E92 ZCP Wheels w/ Offsets: HRE P40 - (F) 20x9 +22, (R) 20x10 +22 Spacers: None Tires / Miles: Michelin PS2 - (F) 255/30/20, (R) 285/30/20; New Tires Suspension: B&G springs EDC Setting: Normal/Sport Alignment: Don't know. I should have asked the shop! Fender Modifications: (F) None (R) None Rubbing?: (F) None (R) None ADDED 5mm spacers all around = slight rubbing on sharp low speed turns. |
