05-13-2020, 08:45 PM | #1 |
Rep 2
2016 740i OBD2 Code P05AE Lower Active Air Flap
Hello
Last week my check engine light came on. I connected my scanner and got Code P05AE Lower Active Air Flap. Took the car to BMW Dealer. They replaced the lower air flap assembly and also replaced a corroded connector. After 2 days check engine light came back on. I connected my scanner and got the same code P05AE. I took the car to a different BMW Dealer and just picked up the car today. And here is a synopsis of findings and repair. They performed Short Test and found Code 138203 (lower active flap control). They also performed Test Plan AT1214-BX8-KJ and found lower active flap faulty. Per the test plan and diognostic code D1150-00000000-40-001 both upper and lower active air flap's replaced togethor. There was no fault code for the upper active air flap but per BMW anytime there is a active air flap fault code both should be replaced togethor. I'm just happy the car is still under warranty other wise the repair bill would have been almost north of $1500.00 |
05-14-2020, 02:12 AM | #2 |
Rep 891
This fault is so common that on newer Istep versions the check engine light doesnt even come on for this error.
BMW has extended warranty on air flaps on G30/G11/G12 as they have such a hight failing rate. |
