04-24-2018, 02:29 PM | #91 |
Rep 8,852
Drives: '15 SO M4/'20 Z4 M40i
The riddle was worded wrong - should not have "weighs" in it. It should say "What is a ton forward and not backward." The word "ton" weighs nothing.
04-24-2018, 02:52 PM | #93 |
11818
Rep 23,187
He was alive long enough to get in the car and try to drive off, killer crawled out the trunk, he's in a convertible?
04-24-2018, 02:57 PM | #95 | |
Rep 1,965
Shall we do another? You have two coins in your pocket totaling 15 cents. One of the coins is not a nickel. What are the two coins? |
RickFLM410991.00 |
04-25-2018, 09:37 AM | #102 |
Rep 181
04-25-2018, 10:04 AM | #104 | |
Rep 545
Parenthesis Exponents Multiplication and Division Addition and Subtraction So the 3/(1/3) should be done first and equals 9. Then you're left with 9-9+1 = 1 EDIT: just realized you were trying to answer the second question...you're right 6/2(1+2) = 3(3) = 9
2011 BMW 135i ///M-Sport, DCT
Bilstein B12 kit, Dinan camber plates, M3 front control arms, Whiteline poly RSFB, MHD Stage 1, cp-e Charge Pipe, H&R Front sway bar, BMW performance diffuser |
King Rudi13157.00 |
04-25-2018, 10:52 AM | #105 | |
Rep 181
6/2(1+2) 6/2(3) 6/6 1 |
04-25-2018, 10:59 AM | #106 |
Rep 1,965
04-25-2018, 12:42 PM | #109 | |
Rep 14,122
Drives: G82 M4C X-Drive
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
04-25-2018, 12:57 PM | #110 |
Rep 378
If you were educated prior to 1917 you might of had a choice in the order of operation
I think that would look like this answer 7.1 9-[3/(1/3 & 1)] = 7.1 Not sure but I think that is the old method explained in modern order of operation On the car thing with the dead guy is it a transport from funeral home?
