11-08-2017, 12:11 PM | #1 |
Rep 106
random driver seat lumbar button popup
Has anyone experienced random popup on display for the driver and/or passenger seat controls without touching or being close to the buttons? I keep getting the lumbar support button popup off and on...
11-09-2017, 05:13 PM | #2 |
Rep 594
When you touch any seat controls with the "show seat settings" area checked it will pop up on the I-drive to let you know what you are adjusting and how it adjusts.
If you don't want it just uncheck the show seat settings. The seat buttons are very sensitive so if you have a towel down there or anything, it will typically show it unless you uncheck the option. |
02-25-2019, 11:02 PM | #5 |
Rep 5
I'm experiencing the same behavior; happens up to 12 times a day without touching anything. Asked the dealer to check it and they said "unable to duplicate". Neither am I, as there is no rhyme or reason as to when it happens. I was sitting parked in idle the other night watching a DVD and it happened.
One tech at the dealer cleaned off the adjustment buttons, saying that maybe a little residual oil from fingerprints could trigger this, as it is sensitive. Will report back on the next dealer visit. |
02-26-2019, 05:22 AM | #6 |
Barge driver
8656
Rep 12,425
Yes I have exactly the same issue (and after the car had a full software ISTA update to cure many other issues) I just went into the idrive and unchecked the box.
730d/Z4C
