      08-29-2025, 05:01 PM   #1
Ihdihd
Drives: X7
i7 Cabin air filter (micro filter) install
I recently took over an i7 lease with a few thousand miles, and thought it would be best practice to replace the cabin air filter. Who knows what the last guy did in the car to despite it looking completely new.
After a bit of research here, I discovered that there is a nano filter available that filters beyond our traditional filter. I ordered one from the bmw dealership and it looked quite similar to the exiting one.
The install was an absolute nightmare- almost 2 hours (vs. 15 minutes for the hardest filter I’ve replaced in the past). Between the difficulty of install and the expectation vs reality of the difficulty, I would have sooner rather rebuilt the engine on a gas car than do that install again.
There are some instructions I tracked down (attached). I will say that at every step of the way there was a laughably difficult thing to do:
1. Removing trim - once the two clips are rotated and out of the way, you have to pull the trim out of its track on the left side of the well. Then I clip the entire light assembly out of the trim (knock it in) instead of pulling the wire harness. After that you have to remove the vent tube- easiest part, then remove the hose on the left. The hose is attached via a small hole latch- simply lift the rubber a bit from top and bottom and it will unlatch, then you can hand pull it.
2. Unscrewing the tiny metal screws required a torx T15 bit, and I had to switch between a straight long driver and a smaller 90 degree wrench due to each screen being in an impossible position to reach. There are 6 screws in total to remove (not 5 as in image). And they are all there and the only way to see them is to contort your body so your head is deep inside the well. The farthest screw on the upper left was the biggest pita - completely inaccessible with the perfect size, perfect shape ratchet. You need a lot of patience because one wrong move and it will drop into the abyss behind the carpet and it’s gone.
3. Once the screws are out, unclipping the right side of the filter cover is a nightmare - again a perfect sized perfect shape flathead screwdriver is needed to unlatch it, essentially in the blind.
4. Closing everything up is easier than taking it out, but again- putting the final trim covers back in their tracks was a real PITA. Had I not already bought it and committed, I would have happily let the sealer do it. It would have been the best $500 I spent.
In sum- don’t do it unless you love pain. I don’t know why BMW designed this massive land yacht and decided to put 80% of their systems in the passenger footwell inaccessible except to contouring circus performers with tiny hands.
What would have made it better- 1) a super low profile right angle ratchet with wobble bit; 2) a good mirror like the dentist ones; 3) much better battery flood light in the footwell; 4) printed instructions.
I didn’t notice any difference so far, but I’m sure it’s better than a 2,500 mile old filter…
Here are the parts:
64-11-5-A54-7D8 Filter Element $145
And attached are the instructions. Follow them religiously.
ZHPsedan151.50
      08-29-2025, 06:25 PM   #2
BMW5and7
BMW5and7's Avatar
2626
Drives: B8 Alpina; X7 M60; Mbenz GLS
Great write up, but I just want to warn everyone. I would NOT suggest for anyone to try this now.
There is an internal TSB note (or in fact an open technical enhancement campaign) on every single G70 produced to date now (am 100% sure about i7s, but not sure about 760/740). BMW is working on an actual full recall. There is a wiring harness and some cables (likely more relevant for i7 but am not sure) that can get blindly damaged or pinched due to how they are routed by factory behind or near the filter. There has been a number of reports internally within BMW by technicians damaging/pinching those cables accidently as the filter is being swapped out. Basically, during a microfilter or cabin air filter service), the harness can either: get pinched, get routed incorrectly, or develop abrasion over time.
The idea behind the current TSB is that for now, until a recall is issued, BMW has a technical enhancement campaign to make sure dealers carefully carries the filter swap following revised/new instructions, and then also inspect, reroute, and properly secure that harness every time the A/C filter is changed and look for potential damages from previous filter changes.
It might be best to let the dealer does this job for you (but please do ask them to pay attention to the note and not just skip it), or at least, be very well aware of the issue. If you can get a copy of the internal TSB and how to avoid potential cable/harness damage, that would be great. It is accessible to dealer within their internal notes as they pull the VIN.
The Enhancement code for this issue is 0061270900
Anyone can use this BMW Group wide website to look for things beyond recall, like this instance.
https://vehiclerecall.bmwgroup.com/i...uk&language=en
ZHPsedan151.50
      08-30-2025, 03:18 AM   #3
rollingtaser
Switzerland
246
Drives: i7 M70, SL63
i noticed it very well... stinking lorries, pollen and other stuff... all gone!
i just love my nano-filter
      08-30-2025, 12:34 PM   #4
hufington
hufington's Avatar
Drives: 2025 760ix
Thanks but no thanks.
25 G70 760i Msport
25 RR SV E2
RETIRED BMWs: '23 F92 M8 Comp / '22 G05 X5 m50i / '18 F15 X5 50i / '16 F10 550xi / '13 BMW F10 535i / '07 E64 630i / '03 E65 745i / '95 E34 540i / '89 E30 M3
      03-27-2026, 06:50 PM   #5
asci01
Drives: 2020 750I xDrive loaded
I just did mine. Do it after the recall so they can move the A/C wires out of the way and it's easier and safer to change. I'm glad I did mine after the recall since they had left the drain hose unhooked so it would have made that whole area damp and possibly moldy. My suggestion is to do it right after the recall is done and make sure you use a magnetized tool so the screws don't fall into the the abyss.
Use the nano filter part no. 64115A547D8, not the regular cabin filter (64115A547D4). You'll be glad you change the cabin filter. It really filters your cabin air. The old one was really dirty.
      03-27-2026, 10:28 PM   #6
BMW5and7
BMW5and7's Avatar
2626
[B]The Enhancement code for [...]
Update: There is no an open-recall to completely address and fix the “potential” damage of the nearby harness I referenced above. It moved from a TSB to a formal recall now.
