| 04-14-2026, 09:49 PM | #1 |
![]() 28
Rep 52
Driver's seat issues
On my new 2026 750ex it has a feature " comfort exit " and " automatic "
" comfort exit " means that the car when shutting off the engine the seat, steering wheel moves back and steering wheel moves up . When I get in the car the seat and steering wheel don't go back to Memory 1 ( which is what I drive with ) unless I buckle the seat belt then it moves to the proper position ( memory 1 ) but it has to be done before I turn on the engine otherwise it doesn't happen . I went into the settings and turned off comfort exit and automatic and the same issue. I turned off just comfort exit and left automatic and the same I called Genius but their suggestions din't fix anything either ! Does anybody have a suggestion on how to be able to get to a destination, turn off the car and when I comeback the same position I left the seat and steering wheel are being kept when I left the car and I don't need to do anything just be able to drive with the seat and all the other memories the way there were left ? Thanks for any help . |
| 04-15-2026, 12:04 AM | #2 |
![]() 24
Rep 52
I'm not sure I understand your problem.
You should be able to sit into the car, press the brake for closing the door, then while or after closing the door you press the start button and the steering wheel moves downward immediately. It is not dependent in the belt, when the door is closed. It is dependent on the belt though, while the door is still open. This is for security so you cannot drive while door open AND belt open. You need either one of them closed |
| 04-15-2026, 09:56 AM | #3 | |
![]() 3890
Rep 1,611
Drives: M8C Coupe,E63s ED1,AMG GTC
On EV's the steering wheel moves up when opening the door as that turns off the car. |
| Bookmarks |
| Thread Tools | |
