      10-18-2019, 12:26 AM   #89
AlpineWhite_SJ
Drives: 2018 F80 M3 ZCP, 2020 F97 X3MC
Originally Posted by Triple Seven View Post
From a technical standpoint, what's the actual difference between DSC and MDM?
MDM is simply a less invasive DSC mode, but not totally DSC free.
clee1982797.50
      02-08-2020, 09:46 AM   #90
Wht550jersey
Drives: 2011 550i
Dsc is partially off in sports + mode ? And you can fully turn off by holding the button ? Had my car for 4 months now still learning everything . Lol
      02-09-2020, 12:16 PM   #91
Moflow
Moflow's Avatar
Drives: 2020 M2C 6MT
I used to turn traction control off in my 350z every time I got into it. After swapping to a square tire setup, the TCS became too intrusive, sometimes going off if I was just trying to accelerate on a curved on-ramp.
The car didn’t have stability control. In my 13+ years of daily driving that car, I never spun it. A sports car with a low center of gravity isn’t going to do anything too weird in a moose test, and I’m confident enough in my driving (100s of sideways moments in that car on purpose) that I’d be able to keep control in an emergency. Please note, there’s no black ice where I live. In a colder climate, I’d be much less inclined to roll around without electronic nannies.
That said, I don’t roll around in the bimmer with the stability control off most of the time, unless I’m trying to rev match on my own. I need to feel the car out and explore it’s limits in a safe environment first to get my confidence up. Once that happens, I’ll still probably leave it on for normal driving but go full off (vs mdm) when I’m trying to fool around. The MDM is pretty intrusive from what I can tell just through small slides. The minute you lift, it clamps everything up tight again and you immediately stop sliding.
      02-09-2020, 11:04 PM   #92
Greer
Greer's Avatar
1889
Drives: 2022 M5 Competition
Yes, DSC on 24/7.
2022 F90 M5 Competition & 2019 M2 Competition
2019 F90 M5 Competition
2017 F80 M3 Competition
2014 F10 M5 Competition
2003 E39 M5
      02-09-2020, 11:46 PM   #93
pennsiveguy
pennsiveguy's Avatar
Drives: F15 xDrive50i M-sport
In every day driving (I daily my F15 50i) I leave the DSC on. If there's snow on the roads, I'll switch it to DTC. If there's snow and I have an opportunity to have some safe "play time," I'll turn it completely off and have some fun.
2017 F15 xDrive50i M Sport | Superformance GT40 Roush 511 IR FE
      02-11-2020, 10:26 AM   #94
Meeni
Gateropode
Meeni's Avatar
329
Drives: BMW 330i 06
DSC is on 98% of the time. It's off only if I am intent on doing things that would trigger it, on purpose. Otherwise, if it triggers by surprise, it's probably saving my sorry arse from self-inflicted stupidity. I have found that it is well calibrated in that it will not often trigger for no good reason.
      02-12-2020, 12:43 PM   #95
b92
b92's Avatar
Drives: E92 335is, 6MT
I've discovered the 'DTC on startup' function in the JB4 menus so I primarily use that now. DTC gives me a little more play when accelerating but DSC will still step in if I'm putting the pedal to the floor. It's nice not having to press/hold the button every time I get in the car though.
I now only go full DSC off when the situation calls for it... which is usually not for any good reason.
2011 E92 335is, Space Grey/Coral Red, 6MT.
RB 2+, Wedge tuned. E85 PI coming soon.
      02-12-2020, 01:01 PM   #96
quick6
Drives: BMW M6,BMW M340i
Since getting the VF tune, my car breaks loose in 3rd with DSC on-used to drive in MDM but have switched to fulltime DSC. Don"t want to cause any harm-the car has over 700hp at the crank and 612 at the wheels. Its wild.
      02-12-2020, 01:30 PM   #97
ky0u
ky0u's Avatar
Drives: e92 335i, f22 m235i, e30 325is
2015 BMW M235i  [0.00]
1988 BMW 325IS  [0.00]
2007 BMW 335i  [0.00]
My DSC is also on almost 100% but im curious, mine seems a touch aggressive. It triggers even if i do half throttle straight line pull in 2nd. My car is fully stock except for dci and chargepipe. is it really breaking traction?
      02-12-2020, 01:38 PM   #98
Conissah
Conissah's Avatar
1576
Drives: 2018 M3
My stock M2C will sometimes break traction in 3rd. In MDM, it's very lenient, as long as I keep it from wagging its tail too much, it'll let me spin. In regular traction and DCS mode tho, as soon as it detects wheel spin, it kicks in.
      02-12-2020, 07:25 PM   #99
Meeni
Gateropode
Meeni's Avatar
329
Drives: BMW 330i 06
I have a 330i, you have a 335i. Not so surprising that you see it in action a tad more than I do then. I'm pretty sure that with the torque numbers a 335i puts down, you can break traction if conditions are less than perfect for tire grip.
      02-12-2020, 10:03 PM   #100
Flacht3
Not Enough Garage Space
Flacht3's Avatar
1137
Drives: STO /765LTS/ Macan
In my M4 I'd have DSC on about 50% of the time. For local driving or places without much traffic I'd go MDM. If I was out in the countryside and knew I could recover without risk of other cars/people I'd usually turn the bells and whistles fully off.
However, in my GT3 I leave it on about 99% of the time. I've experimented with it off and once the back starts to spin in that car, it's basically already too late. I've also done driver control training on a track with full instructor, and understand that my recovery in the GT3 with DSC off simply isn't as controlled as it was in the M. I don't want to risk that on any public roads...and also I'm just a helluva lot more careful in that car in general
