Go Back   7Post - 7 Series Forum > BIMMERPOST Universal Forums > Classic BMW (Pre-2005 Models)
      04-04-2026, 01:38 PM   #1
symbiontsik
Drives: e91 335d
e39 generator issue i cant really explane
Hi all,
Its ongoing issue with my friend's car's M57 engine, and the issue started with the belt tensioner making noise when the lights were switched on. A small ticking noise is coming from it, and we have taken the most common way of fixing it by throwing money at it. The water pump was replaced, the belt tensioner was replaced the alternator was replaced. By all this, the result was that charging got better, and we had fewer places to put the blame. Noise now sounds like a chain is stretched. If you remove the belt noise stops. So today we removed the plus cable from the generator and were surprised that the noise stoped but if you just remove the small connector, the noise stays and gets worse when the lights are switched on. So my question here is, have any of you run into something like this.
      04-05-2026, 06:35 PM   #2
FoxberryJam
FoxberryJam's Avatar
2114
Drives: Z4 M40i;M Roadster;540i M-Sprt
Originally Posted by symbiontsik View Post
Hi all,
I would suggest heading over to the E39 section of Bimmerforums and ask this...
'25 G29 Z4 M40i Handschalter Edition, San Remo Green (w/ full Stealth PPF), Cognac Vernasca
'98 M Roadster, Estoril Blue, Estoril Blue & Black Nappa
'03 540i M-Sport 6-speed, Topaz Blue, Montana Grey (1 of 21)
      04-06-2026, 06:10 AM   #3
TriumphTim
Drives: 2008 328xi
Since an E39 probably has high miles, I would check the voltage regulator and its brushes on the back of the alternator.
A brush may be worn or not seated?
