12-26-2022, 11:27 AM | #1 |
Rep 1,592
ESim billing issues
Setting up the esim resulted in four separate esim numbers being created by ATT -- and all four appeared on my bill. Do not even bother with ATT wireless support, as they cannot solve the issue. I finally reached the "ATT Connected Car Department" but not until after speaking to no less than 7 customer service reps and supervisors. The rep on the phone ended up removing all four numbers (and their charges) and then we started from scratch setting up the esim. The process was a bit different than a couple of weeks ago when I first set it up, so hopefully this won't happen to you. The number for ATT Connected Car is 1-866-706-5773. It makes sense if you talk to them to get the number that is set up in the esim, so you will know that any other numbers are duplicates. It also makes sense to look at your bill on line to make sure that it is correct.
BMWCCA
01-31-2023, 12:24 PM | #3 | |
Rep 394
Drives: 2018 M550i Xdrive, 2021 X5M co
Mike
01-31-2023, 12:47 PM | #4 | |
Rep 288
You can't use your Verizon number for the BMW e-sim without getting a separate account with either of these two other carriers. You can, of course, use your Verizon phone in the car, and you can connect your Verizon phone to the car through the e-sim, and it will all go through the new BMW e-sim but show that number on all your calls. If you don't want to do that, just use your phone in the car, and not connect it to the e-sim, and then your calls will show with your Verizon number. |
Mr.blue221.50 |
01-31-2023, 12:53 PM | #5 | |
Rep 394
Mike
02-01-2023, 11:16 AM | #6 | |
7374
Rep 10,196
Such a pain in the ass. |
02-02-2023, 12:02 PM | #7 |
Rep 1,592
You need to call the connected car department at ATT. They can see which numbers are active. The esim numbers appear in the ATT bill also, but you cannot tell from the bill which one is the esim dedicated number.
BMWCCA
Game7374.00 |
05-09-2023, 01:40 PM | #8 | |
Rep 8
Anyone successful in setting theirs up with Verizon? |
Mr.blue221.50 |
05-09-2023, 03:38 PM | #9 |
Rep 394
Thanks, did not know Verizon had been added!
Mike
05-10-2023, 10:26 AM | #10 |
Rep 242
I just set it up with Verizon
Setup went smoothly, and now I’m trying to figure out the benefits and how it works 1) what do I gain, if I always have my phone with me 2) will it ring even when my wife takes the car, even though it’s linked to my cell? 3) when my car is in for service, with they get all my calls? Ideally, it would be linked to using my digital key or remote, and not ring if a different user has my car |
05-11-2023, 10:46 AM | #11 | |
Rep 1,592
Your question 2: when your wife drives the car she should select her own phone in the "mobile device" applet. That should mean the esim will not ring. Question 3: Yes all your calls will also ring in the car, but I guess you could select your phone as the mobile device before you drop it off. It is a shame that neither BMW nor the carriers have taken the time to explain esim and how to use it. There should be a FAQ for example for questions like yours.
BMWCCA
05-13-2023, 10:43 AM | #12 |
Rep 47
I tried setting this up with Verizon with no luck. We have a business account with Verizon and I could not get it set up through the app.
I spent about 2 hours on the phone with Verizon with 4 different reps. All of them confirmed that ESim works with business accounts as well … but none of them could figure out how to get it to work with the imei bmw provided to bypass the bmw app activations … Anyone have any luck with this ? |
05-14-2023, 07:39 AM | #13 | |
Rep 288
I also had an older plan that is no longer offered, and when I changed mine to a current plan as well, it also went through right away. You might want to check into this. |
05-14-2023, 03:06 PM | #14 | |
Rep 47
05-15-2023, 08:45 AM | #15 |
Rep 1,592
I have had esim going for a while but am not sure it is worth it. Carplay keeps disconnecting while esim is active, and sometimes the esim has to reconnect itself. Thowing in the towel for me would be cancelling esim. YMMV
BMWCCA
BMWKaz13.00 |
05-15-2023, 10:01 AM | #16 |
Rep 47
That’s actually interesting … the only reason I want the ESim is for the screen in the back … without internet it’s useless… I haven’t been able to find a workaround to get internet on the theatre screen
05-25-2023, 09:09 PM | #17 |
Rep 47
Well I finally gave in… there is currently no way of setting up the ESim/ getting data in the vehicle with a Verizon business account. I had to port my numbers over to a personal consumer account … now I can finally use the app to start the process and I added the 20/month plan… but can’t get the vehicle to register it … I’m stuck in the vehicle on the setting up personal ESim prompt ….
If they told me it was this much trouble I would have never forked out the money for the screen … what a crap delivery !! |
05-26-2023, 08:38 AM | #18 | |
Rep 1,592
BMWCCA
