01-29-2023, 10:32 PM | #1 |
Rep 1
M4 engine issue when it starts and idles
My m4 has a issue when it starts cold or warmed up, it idles rough and choppy almosted like it’s cammed.
Mods are only catless downpipes, single mid pipe, and some tune that the old owner put on what do you think the issue can be. |
01-30-2023, 08:41 AM | #3 |
Rep 122
Drives: 2009 E92 335xi
What Tejas said or vacuum leak would be my next guess. Possible misfire? Have you run codes yet?
01-30-2023, 09:02 AM | #4 |
Field Marshal
6729
Rep 1,829
Drives: '08 E92 M3
Old spark plugs, poor fuel injector(s) spray pattern, pre-cat O2 sensor(s), fuel tank breather valve, bad gas, or a small air inlet vacuum leak.
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
///M Power-Belgium63328.00 |
01-30-2023, 09:13 AM | #5 |
'20 M2 Comp.
902
Rep 182
Drives: '20 M2 Competition DCT
try reading the codes. My car had the same issue with the same mods it turned out to be the tune. Although I had a JB4, after removing it the car ran smoothly again.
'20 BSM M2 Competition DCT
IG: @porky_m2c |
DrFerry6728.50 |
