01-05-2021, 02:15 PM | #1 |
Rep 323
Does BMW use recycled plastic?
I've read that automakers use recycled plastic in cars. Does BMW? If so, where is the plastic sourced from, and does it affect quality?
01-06-2021, 09:19 AM | #2 |
Rep 687
Drives: 06 Black Sapphire Z4MR
Can't say specifically for BMW, but majority of plastic parts you see today will have SOME recycled plastic content.
I can't imagine anyone doing mass production today spending the coin on virgin grade anymore unless its application specific.
Revolution of our Times
I will return to the track, one day. |
01-06-2021, 10:13 AM | #3 |
Rep 1,222
Yeah... the proliferation of recycled plastics is pretty much unavoidable....
01-06-2021, 10:29 AM | #4 | |
Rep 2,665
From your question I think you are trying to oversimplify it.
2006 Z4M Coupe - Stromung exhaust, ZHP knob, stubby antenna, clutch delay delete
chris7197354.50 |
01-06-2021, 11:38 AM | #5 |
Rep 323
Well I had an eccentric shaft sensor fail recently. Its a $200 plastic, German made part and the oil gets inside the sensor and messes it up. I've also had the upper plastic neck of radiator fail and basically fall apart before 100,000 miles.
The plastic was not able to handle the heat or age well. |
01-06-2021, 11:51 AM | #6 |
Rep 19,790
Recycled plastic used in high stressed engine/gearbox parts subject to high heat and oil/fluids are a passport to fail soon. Recycled and new plastic mixed together will always be brittle and every manufacturer uses the process.
01-09-2021, 09:41 AM | #7 |
Rep 18,777
Most people do not understand plastic.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
F32Fleet3606.00 |
01-09-2021, 09:52 AM | #9 |
Rep 18,777
Most people don't understand "engineered plastics" either.
01-09-2021, 10:51 AM | #11 |
Rep 323
I use only organic non GMO plastic in my BMW, lol. However, I do think the radiator plastic used in the n51 is biodegradable because it disintegrates in hands after about ten years in the car.
E92William1998.00 |
01-09-2021, 06:16 PM | #12 | |
Rep 10,370
BMW used to have a program in Germany where they recycled as much what was feasible. For example they would convert seat foam into wheel well liners. BMW also invested heavily in environmental friendly interior materials which contained some recycled content. They were heavily advertised with the i3. Edit: YouTube is full of BMW recycling videos.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
01-10-2021, 01:21 AM | #13 |
Rep 2,026
Drives: 2008 E92 328xi
I was under the impression that there were some EU regulations requiring car manufacturers to use X amount of recycled plastic. Of course this could just be gibberish that's being thrown around but if they can give you a ticket for leaving your car idling because you're "polluting" while half a dozen oil tankers do more than all cars in the world, I wouldn't be surprised if there was some sort of law regarding which plastic they have to use.
01-10-2021, 12:06 PM | #14 | |
Rep 10,370
https://en.m.wikipedia.org/wiki/End_...cles_Directive https://eur-lex.europa.eu/legal-cont...X%3A32000L0053
01-10-2021, 12:06 PM | #15 |
Rep 3,655
BMW plastic is some of the worst in the industry so I would say it probably is recycled. It's supposedly due to some sort of German government regulations but from what I've seen Mercedes-Benz does not have the same degree of issues with their plastics that BMW does so I'm not really sure what the answer is.
