02-17-2019, 05:31 PM | #155 | ||
Rep 2,534
Almaretto2374.00 |
02-18-2019, 04:55 AM | #156 |
Barge driver
8655
Rep 12,424
Having your hands on the wheel will help with that.
730d/Z4C
02-24-2019, 07:20 PM | #157 |
Rep 106
I just got BimmerCode and OBDLink MX+.
How do I code: * fog light on with high beam * comfort close with key fob * disable chime only for seatbelt - keep warning on dash I was able to code: * close tailgate with key fob * turn off all seatbelt warnings * default driving mode |
02-25-2019, 06:41 PM | #159 |
Rep 106
markymarc1979 take a look at: https://www.youtube.com/watch?v=LDlPsxOOs-A
02-25-2019, 06:45 PM | #160 |
Rep 2,534
02-26-2019, 12:14 AM | #161 | |
Rep 104
02-27-2019, 05:09 AM | #162 |
Rep 1
Hi all,
I'm new to coding and need some help/advise please, I've got a 2016 G11 730d xDrive, and am trying to code it to match a G30, so far have successfully changed from ID5 to IDT6 via expert mode in Bimmercode. I now want to change the digital instrument cluster to show the added info in ECO PRO mode the G30 does (miles saves, miles coasted) I was able to change the display from the standard Power/Charge to the G30 one using :- GLOBAL_TUBE_RECHTS_INHALT_ECO_ANSICHT from eda to komb_verbr_anzeige the issue I have is the display has changed but it doesn't show the figures for for miles saved and miles coasted, does anyone know how to code this please? Last edited by s77ngh; 02-27-2019 at 05:10 AM.. Reason: typo |
02-28-2019, 07:37 AM | #163 | ||
Rep 176
I posted how you can turn off the seatbelt warnings But here is some of what i did HERE is HOW edit FDL CAF [ACSM_5] under 3001 Gurtwarnung, 32 SBR variant (Not sure what this is) SBR (Seat Belt) disabled without SBE (long-term); SbrVariantDriv set to SBR_ohne_SBE_SBR-3.0 SbrVariantPas set to SBR_ohne_SBE_SBR-3.0 Deactivation belt condition indicator driver in cluster SbrDispBltStDrivEnb Set to NICHT_¬AKTIV Deactivation belt condition indicator front passenger in cluster SbrDispBltStPasEnb Set to NICHT_¬AKTIV Speed threshold for motion detection SbrVvehMotion Wrete = FF Speed threshold for SBR (Seat Belt) warning SbrVvehWarn Wrete = FF Speed threshold Cancellation of Drive warning to FF SbrVvehWarnCnclDriv Wrete = FF Hope this will help. |
03-21-2019, 04:06 AM | #165 |
Rep 107
It seems to drive really well considering it’s not a “self driving” car, but the steering wheel sensor is very sensitive. If you’re driving with one hand (mainly fingers) then it quickly wants you to grab the wheel. It would be really nice to disable the warning, or extend the waiting time before being triggered.
03-23-2019, 10:14 AM | #166 | |
Rep 453
03-24-2019, 01:12 AM | #167 |
Rep 8,364
03-24-2019, 01:24 AM | #168 |
Rep 176
03-31-2019, 08:33 AM | #169 |
Rep 107
Anyone have any luck finding a way to extend or disable this? Driving with one hand, especially when holding the area where the wheel and center bar connect, makes the car think I'm not touching the wheel at all pretty often. During that "grace period" of 7 seconds or so before it warns you and disables, the car does drive itself very well. I've tried it on aggressive turns and it still steers perfect through the turn completely on it's own.
04-07-2019, 08:44 AM | #170 |
Rep 342
Maybe this also works on the G11....
https://quidzel.com/ It’s a device you plug and makes the steering wheel think you’re always touching it. |
04-07-2019, 10:15 AM | #171 | |
Rep 107
04-14-2019, 05:46 AM | #172 |
Rep 83
04-14-2019, 10:26 AM | #173 | |
Rep 83
04-14-2019, 11:23 AM | #174 | ||
Rep 107
04-14-2019, 12:00 PM | #175 | |||
Rep 83
