07-19-2019, 05:07 PM | #1 |
Rep 7
Hello, a friend of mine buyed a BMW 7 series g11 and it has not heated and ventilated seats, the car is fully equipped but the touchscreen buttons of the ventilated and heat are missing,he buyed the car from italy and they Say that they didn t equipped the car with that.Can someone help? I wan t to know if they code that out and if i can activate them via coding[IMG][/IMG]
07-19-2019, 05:12 PM | #2 |
Rep 398
there should be hard buttons on the HVAC in the center console if the car is equipped with heated/ventilated seats. Are those buttons non-functional?
07-19-2019, 05:15 PM | #3 |
Rep 7
07-20-2019, 02:32 AM | #4 |
Rep 527
Unfortunately you won’t have the hardware to do it so not just a coding issue (for example the seats would need to be perforated to allow the ‘cooling’, you don’t have these two ‘options’ it seems or they would show up in the centre console display. Wasn’t aware the G11/12’s could come without heated seats!
07-20-2019, 08:09 PM | #5 |
Rep 1,593
If the touch sensitive area where the heating or cooling buttons is missing, (for both driver and passenger side), then somehow you have a car without the option(s). Have you checked the VIN to see what was produced? If it isnt listed as an option, then I believe you are out of luck as the seats themselves would need replacement, along with the electronics.
BMWCCA
07-22-2019, 09:00 AM | #7 | |
Rep 7,468
Unless BMW changed things...the option codes for climatised (ventilated) seats & heated front seats are:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 07-22-2019 at 09:05 AM.. |
