05-21-2019, 04:40 PM | #1058 |
Rep 265
05-21-2019, 04:44 PM | #1060 |
Rep 3,308
Here is the pizza doe recipes if anyone is interested. Its very easy
415 grams flour (00) see picture for best choice 9 grams salt 270 grams water 1.5 grams of fresh yeast, or 1 gram of dry Olive oil for coating. Tap water should be 65 F. Add yeast to water and stir to combine Combine flour and salt Make a well in a mixing bowl and combine flour/salt to water. Mix roughly with a spoon to combine. Then put the bowl in.a stand mixer with a dough hook and mix on medium speed for 7.5 mins. Dust work surface with flour and shape the dough into a ball. Put the dough in a bowl and cover with a towel and let ferment for 6/8 hours, better 8 if you want to use it tomorrow. Make sure the room is around 65 F. Use a scale and divide the dough into 3 230 gram balls, or 2 bigger ones if you like larger pizzas. Put oil on your hands and cover the balls and transfer to the fridge and let rest for 30 mins uncovered. Then either cover with an airtight lid, or wrap individually with cling film and rest overnight in the fridge. 30 mins before you are ready to make the pizzas, take them out and rest on a floured surface before shaping. Stretch into the pies on a floured surface and make your pizzas! |
05-21-2019, 04:51 PM | #1061 |
Rep 6,030
05-21-2019, 04:54 PM | #1062 |
Rep 3,308
05-21-2019, 05:18 PM | #1063 | |
Rep 265
It is surprising how much of a difference 00 flour makes over even bread flour. If you start messing around with fresh milled flour you won't believe what a difference it makes. |
Sassicaia4453.00 |
05-21-2019, 05:21 PM | #1064 | |
Rep 6,030
05-21-2019, 05:33 PM | #1065 |
Rep 3,308
05-21-2019, 05:44 PM | #1066 |
Rep 6,030
Looks like it comes with the pizza spatula at Lowe's. Also out of stock though. Not sure if you can order direct from the mobile site maybe need the desktop version or someone in the Amazon marketplace.
05-21-2019, 06:17 PM | #1067 |
Rep 3,308
it should come with both the pizza spatula and wooden peel as standard.
05-22-2019, 12:58 PM | #1069 |
Rep 279
05-22-2019, 01:38 PM | #1070 |
18076
Rep 9,380
05-22-2019, 02:40 PM | #1071 |
Rep 14,521
I believe so. there's actually 2 varieties that Sams Club sells and maybe you guys can tell me the difference. one says sirloin while the other says angus. arent' they both the same? prices are about $1 difference
05-22-2019, 02:50 PM | #1072 |
Rep 14,521
pretty much you can use whatever meat you like. I use kosher salt and let it tenderize for about 1.5 hours in the refrigerator. than wash it off and pad dry with a paper towel. than whatever seasoning you like. my family likes Applewood Rub and or Montreal/Chicago steak seasoning. on a very hot grill 2 minutes than turn 180 the other way to get the grill lines for another 2 minutes. flip them bad boys over and repeat. lower the heat on half the grill, turn the other burners off and let the meat cook on the cold side until you're desired likings. for me I find it takes about 12 min total for a medium cook steak.
upstatedoc7567.50 nyalpine907434.50 |
05-22-2019, 03:25 PM | #1073 |
Rep 3,032
Barbarians is the best steak seasoning, brings out the flavour without the terrible over-black peppered taste most steak seasonings have.
http://www.barberians.com/steak-spice/ |
lsturbointeg9160.00 |
05-22-2019, 03:34 PM | #1074 | |
Rep 14,521
anyone else have recommendations for some pretty good steak seasoning?
05-22-2019, 05:44 PM | #1075 |
18076
Rep 9,380
Sirloin is the cut of the cow that is ground up into patties and generally has a higher quality/flavor, with slightly less fat than chuck(normal burger). Angus is the type of cow that is genetically different and supposedly has better marbling and flavor of the meat.
05-23-2019, 07:42 AM | #1076 |
Rep 3,032
$18! Damn. It's really, really good because the meat still tastes like meat, there's no overpowering flavour it just enhances the beef. Try direct from the store.
05-23-2019, 01:19 PM | #1077 |
Rep 14,521
Hmmmm...probably cause it's coming from Canada?
05-23-2019, 01:54 PM | #1078 |
Rep 3,032
