08-26-2018, 12:02 PM | #133 |
Rep 20
Unfortunately I do not- see a screenshot of all my options (unless its in expert mode).
Also trying to find a way to code the BMW Ambient Air to turn on automatically with the can- anyone know? Thanks.. |
08-26-2018, 12:37 PM | #134 |
Rep 8,364
09-17-2018, 02:47 AM | #135 |
Rep 104
I've use Bimmercode and it's week in "standard" mode. It's looks better in expert mode but it's hard to know what do you want to change.
I want to change: - seat belts reminder remove - change start up logo in rear entertaiment system - start/stop turn off - change "drive mode" from default to last choice I'll be grateful for helping me where i can find it in expert mode. |
09-27-2018, 11:24 PM | #136 |
Rep 3
Hi,
my g12 come with Harman Kardon sound system. I retrofit it to Bower wilkin system. Done all the wiring right. Just find out the B&W system require bigger power cable for the amp. Change the power cable. Suddenly the sound is bigger but bad. No more define and control, middle sound flat, tweet lose it crisp sound it used to has. What could be a problem? is it possible that the amplifier has reset when i discharge it? Do i need to recoding all the way again? Feeling really bad. Please help and pardon my english. Best regards. |
09-27-2018, 11:26 PM | #137 | |
Rep 8,364
11-26-2018, 11:41 PM | #138 |
Rep 3
Has anyone retrofitted/coded up LED headlights, yet?
I have just done the retrofit and the result after coding is that all lights are coming up one-by-one for only few seconds then after everything goes off.
It is an obvious error code but I can't figure what is wrong. Did a new custom wiring and replaced both FRM (61 35 6 992 947) and ZGW (61 35 9 322 532) All modules are brand new. Any ideas would be greatly appreciated. BR, Thank you. |
12-13-2018, 07:24 AM | #139 |
Rep 18
12-13-2018, 09:44 PM | #140 |
Rep 8,364
12-27-2018, 08:03 AM | #141 |
Barge driver
8668
Rep 12,430
Has anyone coded the Alpina blue instruments on their 7 yet? Bimmercode says it's available but I wonder if the diesel dials are there or just the petrol. (rev counter)
730d/Z4C
02-06-2019, 03:35 PM | #146 |
Rep 176
Hi There,
I have a 2018 G12, not able to remove the seat belt reminder. The cheat code did did not see the codes in the ncd file. Any idea where i can find it? |
02-07-2019, 09:28 PM | #148 | |
Rep 176
I found a way to deactivate the Seat Belt reminder in a 2018 G12 750 the warning is based on the speed of the car, and there is no way to just turn it off, so you have to override the Wrete to FF HERE is HOW edit FDL CAF [ACSM_5] under 3001 Gurtwarnung, 32 SBR variant (Not sure what this is) SBR (Seat Belt) disabled without SBE (long-term); SbrVariantDriv set to SBR_ohne_SBE_SBR-3.0 SbrVariantPas set to SBR_ohne_SBE_SBR-3.0 Deactivation belt condition indicator driver in cluster SbrDispBltStDrivEnb Set to NICHT_¬AKTIV Deactivation belt condition indicator front passenger in cluster SbrDispBltStPasEnb Set to NICHT_¬AKTIV Speed threshold for motion detectionSbrVvehMotion Wrete = FF Speed threshold for SBR (Seat Belt) warningSbrVvehWarn Wrete = FF Speed threshold Cancellation of Drive warning to FFSbrVvehWarnCnclDriv Wrete = FF I hope that will help. |
02-08-2019, 05:08 PM | #150 | |
Rep 176
And when you get stuck in a car and you can’t get out in an accident, like it happened to me and the fire department had to cut it off, you think i want to wear that thing anymore!!! |
02-10-2019, 10:59 AM | #151 |
Barge driver
8668
Rep 12,430
Yes, that way there is still something worth cutting out.
730d/Z4C
02-17-2019, 05:16 PM | #152 |
Rep 2,534
I got one. For all you G series owners with drivers assistance. Wouldn't it be nice to extend or remove all together the automated steering cancellation when you take your hands off the wheel for an extended period of time?
Not sure if I explained it clear. With steering assist enabled, taking your hands off the wheel for 7-10 seconds and the features disables. Would love to disable that. |
02-17-2019, 05:27 PM | #153 | |
Barge driver
8668
Rep 12,430
730d/Z4C
02-17-2019, 05:30 PM | #154 | ||
Rep 2,534
If theres an option to extend or disable all together, I'm definitely coding it. |
