08-20-2020, 04:40 PM | #23 |
Rep 929
Drives: 2019 F87 M2C, 2023 G87 M2
I wonder if they give their press cars a different tune for more hp 🤔
08-20-2020, 06:41 PM | #24 | ||
Rep 14,141
Drives: G82 M4C X-Drive
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
08-20-2020, 06:45 PM | #25 | |
Rep 20,742
Drives: 2021 911 turbo
I agree, the M2cs does not make more power than the the M4cs. However, the slight power and torque deficit of the M2cs is made up by its lighter weight.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
MDuckie96.00 |
08-20-2020, 11:06 PM | #28 |
Rep 20,742
Crank.
Maha dyno figure crank hp by measuring drivetrain loss. Blue line is measured whp, green line is drivetrain loss, red line is calculated crank hp (red=blue+green).
08-21-2020, 05:09 PM | #31 | |
Rep 489
Anyway amazing 15 years later the economy car based M is putting out power equal to the top of the line M5 |
08-21-2020, 08:06 PM | #32 |
Rep 2,208
Drives: G81 M3 Touring (Frozen Black)
Wasn't the GTS water-cooled? I think any tune can whack up hp but doing it with confidence to maintain a warranty is another thing altogether. I understand the CS has altered cooling and air circulation in the engine bay?
08-22-2020, 11:58 AM | #33 | |
Rep 20,742
That's the thing with aftermarket tunes, they simply tap in the thermodynamic margin the S55 has. On stock tunes, the engine keep making peak power throughout an entire track session because it has sufficient thermodynamic margin to sustain the power despite the higher IAT. Aggressive aftermarket tunes are great for highway pulls, but will revert back to stock power levels after a few laps around a track.
dmboone254972.00 |
08-23-2020, 09:19 AM | #35 |
Rep 4,714
08-23-2020, 09:40 AM | #36 |
Rep 4,008
Drives: M235i, 420i, and now the M2 CS
I could not have said it any better myself
M2CS,
The second coming of ///M! |
08-23-2020, 09:51 AM | #37 |
Rep 20,742
As posted previously, this is consistent with the dyno AMS/SA charts, the M2cs showed ~590N-m while the M4cs showed ~640N-m, ~9% more just as the official rating.
08-23-2020, 11:56 AM | #38 | ||
Rep 358
Drives: '16F80,TR6,Defender,PA23-250T
From what I understand, despite being marginally larger, the F80/82 was ever so slightly lighter. |
08-23-2020, 01:43 PM | #39 | |
Rep 20,742
If you look at the screenshots from the M2cs and M4cs dynos, the weight of each car is also posted: M2cs: 1588kg M4cs: 1609kg M4cs is lighter than M2C but heavier than M2cs
Ragged Edge365.00 |
08-23-2020, 03:06 PM | #40 | ||
Rep 1,232
Drives: BMW F87 M2 CS (6MT)
M2 CS - with 6MT and CCB - 1525kg.
Sometimes, the simplest recipes, done well, with quality ingredients, are the tastiest, - evo Car of the Year 2020
2020 BMW F87 M2 CS - 6MT - Misano Blue Metallic |
08-23-2020, 04:13 PM | #41 | |
Rep 20,742
The M2cs weighed by AMS/SA is a DCT with irons.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 08-23-2020 at 05:14 PM.. |
08-23-2020, 04:13 PM | #42 | ||
Rep 1,232
08-23-2020, 04:17 PM | #43 |
Rep 20,742
It's a "spec" weight, for certification purposes, different cars will have different weights depending on options. The DIN spec weight of the M4 when it was released was 1497kg, you'll be hard pressed to find an example that is that light. That's why I prefer to rely on actual weighing from "trustable" publications.
