06-08-2009, 07:41 PM | #1 |
Rep 2,526
Lighting in a Gym?
So I've been told I have to take photos of an awards assembly at my school which takes place in our fairly large gym.
One problem with shooting in this environment is lighting - while light is plentiful, it is by no means enough to shoot at a fast enough shutter speed to prevent motion blurring caused by people moving around and such. I would like to shoot at a somewhat low ISO, preferably below ISO400. I've thought about using my external flash, but there are no walls close enough to the center of the gym to bounce off of, and the ceiling is way too high to be bounced off of. A diffuser will not work (true?) because it needs a reflective surface to bounce off of, otherwise it is no better than doing direct flash, from what I've heard. In this case, what would I do/use? I will be shooting with a 70-200mm f/4 IS, and lighting gets tricky down at the 200mm end with an on camera flash (off-camera is not allowed - they're afraid of people tripping over lightstands...) Help? |
06-08-2009, 11:14 PM | #2 |
Rep 36
First of all, what flash and body are you using?
Nikon D700 / Nikon D300 / Nikon P6000 / Nikon 10.5mm F2.8 / Nikon 14mm F2.8 / Nikon 20mm F2.8 / Nikon 24-70mm F2.8 / Nikon 50mm F1.4G / Nikon 70-200mm F2.8VR / Nikon SB80DX x 2 / Nikon SB28 x 2 / Nikon SB800 x 2 / Nikon SB900 x 2 / Pocketwizard Plus II Transceiver x 7
My Photos: http://www.flickr.com/mikeboldt |
06-08-2009, 11:35 PM | #3 |
186
Rep 2,391
a D700 and an SB-900 would solve your 200mm on-camera flash problem. ;] but you didn't go that route.
don't you have a 5D2? why do you feel like you have to stay below ISO 400? are there ledges where you can set the flashes without a stand and aim them up? ceiling too high? grab some small reflective bits to aim the flash with - or small 12" umbrellas. i'm sure you can talk whoever into letting you use something smaller than what they think a "lightstand" is. full flash power (and some extra batts) and ISO 800 will go a long way.
2009 135i | space grey | sport | navi | hifi | heated
dinan stage 2 software | bmw performance exhaust kw v2 | hotchkis front sway | vmr v710 |
06-09-2009, 12:02 AM | #4 | |
Rep 2,526
Yeah I'm using a Canon 5D2, 580EX II, and a 70-200mm f/4 IS. I prefer not to use a tripod. I feel like I need to keep my ISO below 400 because the 5D2 has a funny way of handling noise reduction. Currently, I have NR turned off so that I can get the sharpest pictures, but when turned on, even on the "low" NR setting, I find that it makes the photos really soft. I find that if I keep the ISO at or below 400, then I can avoid noise for the most part. There are no ledges or anything that can reach out to the center of the gym. At the moment I think my only solution is a diffuser of some sort. |
06-09-2009, 12:03 AM | #5 |
aka 1013MM
1288
Rep 9,545
only way is to use higher ISO and or lower aperture. What camera are you using??
06-09-2009, 12:27 AM | #6 |
186
Rep 2,391
definitely keep NR off. always.
the fine grain noise of the D3/D700 and (hopefully) the 5D2 is pleasing and very film-like. embrace it. either way, you should be pretty noise free at 1600 and below, as long as you're not exposing for the shadows. at f/4 and your IS giving you 1/125 (it's a ceremony not a game), you should be able keep your ISO at or below 1600 in this gym. place your undiffused flash on the opposite corner from you (you have triggers right?) and aim it at your subjects far side/back quarters so that the flash is at your 2 or 10 o'clock. this will give you a nice rim on your subjects to make your bad ambient lighting look bad-ass. edit: you can has triggers, too: http://www.gadgetinfinity.com/produc...roductid=16766
06-09-2009, 12:37 AM | #7 |
Rep 24,685
Drives: '04 330i ZHP
twitch.... if you need to, go rent a Norman flash kit (or something similar) and a soft box. you'll also need a bracket to mount the flash head on and you can put the battery pack on a belt.
http://www.glazerscamera.com/rentals-lighting.html looks like they might be local so give them a call. Last edited by UdubBadger; 06-09-2009 at 01:01 AM.. |
06-09-2009, 12:41 AM | #8 |
Bootleggin' 'n Gunrunnin'
143
Rep 2,372
Can you get into the gym ahead of time to try some test shots? That might help you find a solution. Without a diagram of the gym and the ceremony setup, it is hard to give specific advice.
Scott
2024 G01 X3 M40i, Brooklyn Grey Metallic /// 2015 F15 X5 35i, Space Gray Metallic, 99K miles /// 2013 F30 320xi, Mojave Metallic, 112k miles 2019 Ford F450 STX, Oxford White 2013 Ducati Multistrada Touring S, Red |
06-09-2009, 02:26 AM | #9 |
Just another peanut in the Turd!
94
Rep 598
The 5D MKII has incredible latitude with ISO. Its images at 5000 ISO are better than the 1D MK III at 2000 ISO Do not be afraid of pumping up the ISO on that body. I have shot with the 5D MKII at 6400 ISO with very favorable results.
Now do they have any theatrical lighting for the ceremony, if so then an ISO of 1250 to 1600 should be fine with a color temp of 3200 deg. If it is only overhead gym lighting then probably ISO of 2000 to 2500 with a color temp of probably 4300 deg should be fine. Depending on your distance from subject a 580EX should be able to reach at least in a fill capacity. I would direct fire it but use a diffuser like an Omni Bounce attached (3/4 stop loss). Hope that helps. |
06-09-2009, 02:36 AM | #10 | |||
Rep 2,526
I'll also be picking up that Omni-Bounce diffuser you mentioned pretty soon, except I don't know if I'll end up using it or not. Good idea! |
06-09-2009, 10:20 AM | #11 |
Rep 24,685
hey thats fine, but don't forget... opportunities like this are ways to GET PAID for jobs like this. If you take it seriously, take good pix, then that is the difference of you being asked to come back to do it or something similar again, and get paid $500 instead of $50 because the pics turned out the best they could have.
06-09-2009, 10:35 AM | #12 | |
aka 1013MM
1288
Rep 9,545
06-09-2009, 07:18 PM | #13 | |
Rep 2,526
06-09-2009, 08:11 PM | #14 |
Rep 24,685
06-10-2009, 12:37 AM | #15 |
Rep 2,526
06-10-2009, 11:17 AM | #16 |
Rep 7,389
Twitchy, my friend, use the 5D2's high ISO performance and fix the color temperature of the lighting in DxO. You've got all the tools you need and you're fighting with one arm behind your back with that archaic ISO 400. Shoot in RAW to get a 25MB file and then adjust the crap out of color temperature for those false lights.
The attached image was taken handheld from 33 meters with my f4L 70-200 at f4/183mm and ISO 2000. Color temperature required several hundred degrees of correction because of lots of yellow ambiant light and a mix of floods. It's also cropped about 1/3, if I recall correctly. I started with a RAW file around 25MB. There's some slight softness, but that's mostly due to the movement. I should have probably used the P-mode and set the ISO at 3200 or 6200 to get a faster shutter speed than the 1/160 that resulted from being in fully automatic mode. Anyway, noise is not the issue. This file looks even better when it hasn't been reduced in size for internet consumption. One huge reason to spring for the big bucks on the 5D2 is it's stunning high ISO performance. You're missing out when you don't use it, IMHO. Look at those deep, rich noiseless blacks. Look at the detail on the flag that's not moving and the dress patern at the top of the stair. Dave
06-10-2009, 11:50 AM | #17 |
Rep 7,389
Of course, when you shoot up close, flash is often the way to go.
Still, you really need to explore your camera's high ISO performance. It'll change your life. Dave
06-10-2009, 02:32 PM | #18 |
186
Rep 2,391
dave, did you have NR on? it looks a bit smeared.
06-10-2009, 02:42 PM | #19 |
Rep 7,389
No. There was subject movement. Look at the building trim and that flag to the right for the real sharpness guage.
Oh, I should say, DxO applies noise reduction prior to RAW conversion, automatically (unless I turn it off), so there was some out of camera NR. Dave
06-10-2009, 03:01 PM | #20 |
186
Rep 2,391
i am looking there. i would keep all NR off. it just makes smear. and these sensors have really pleasing fine-grain. try it next time.
3200 - no NR: ISO 5000 - No NR: Twitchy, would like to see your results when you get done. Try that rim light idea.
06-10-2009, 03:37 PM | #21 |
Rep 577
I had to shoot a dance performance under low light and flash was not permitted. Just use the iso and aperture combination to get the shutter speed you need. Then process the grain with noise ninja or noiseware if it's that objectionable. I managed these shots with no flash at 2500.
06-11-2009, 12:02 PM | #22 |
Rep 7,389
I think that Twitchy, our OP, has a FF camera.
Dave
