Go Back   7Post - 7 Series Forum > BIMMERPOST Universal Forums > Site Related Announcements - Suggestions - Feedback - Questions
      12-06-2022, 09:43 PM   #23
Limegrntaln
Limegrntaln's Avatar
Drives: 2022 DG/BLk xDrive M4C Wk 34
Originally Posted by Draper View Post
Are you sure? 🙃
Pretty sure, anyway.
On a side note, this is an issue.
DjJ8ZTFfCE8
2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou
apptest2999.00
      12-06-2022, 10:18 PM   #24
apptest droid
apptest droid's Avatar
Drives: BMW
Originally Posted by Limegrntaln View Post
Is there an option Im missing to turn this off? I think if I have to reach all the way to the top, right corner to submit the post, I already know I want to post it.
Not a bad idea, we will put this in consideration for sure. Still on the fence on this one
BMW is great
Limegrntaln13475.00
      12-06-2022, 10:20 PM   #25
Limegrntaln
Maybe just a switch in settings for the option to do it. Default it on so we can turn it off.
YT: G Dubyou
      12-06-2022, 10:21 PM   #26
apptest
Private2
apptest's Avatar
Drives: BMW M3 F32 Coupe!
DjJ8ZTFfCE8
Wow that’s insane, the problem I’m seeing is the editor box is totally white, right?
Was that a one off thing for you or is it consistently happening? Or even ALWAYS happening?
Test 23456rt
      12-06-2022, 10:23 PM   #27
apptest
Private2
apptest's Avatar
Yup that’s what I’m thinking is the best solution…. Shouldn’t be that hard at all.
Thinking out loud right now, the default will be the way it is now, and you would have to set it to skip confirmation as a setting.
Keep an eye out for the next update either tomorrow or in a few days that will include that update, if it makes the cut it will be in the release notes 👍
Test 23456rt
      12-06-2022, 10:24 PM   #28
Limegrntaln
I tried to reply 4 times in dark mode. Everytime I either tried to reply, or start a new post, it defaulted to white text. I turned off dark mode, for the night, so, I could use the app.
YT: G Dubyou
      12-06-2022, 10:26 PM   #29
apptest
Private2
apptest's Avatar
Can you totally close/shut down the app and open it from scratch (should see the blue splash screen at the start) and let me know if it is still white?
Test 23456rt
      12-06-2022, 10:32 PM   #30
Limegrntaln
Can you totally close/shut down the app and open it from scratch (should see the blue splash screen at the start) and let me know if it is still white ?
Still white. Closed and got the BP logo on the splash screen.
YT: G Dubyou
      12-06-2022, 10:37 PM   #31
apptest
Private2
apptest's Avatar
Ok Yes that is very wrong. Even the colors in the editor box are not the way its supposed to be….
Do you mind if I ask what phone and what iOS version you are on so I can try to drill down on what is going on there?
Anyone else out there having dark mode issues?
**** EDIT: I looked at the top of your screen shot—- duh I know what it is. iPhone 14pro and iOS 16
I’m using it on the same device and it looks great, but I did make a change that might fix it for you, look for it in the next update in the next day or two
Test 23456rt
Limegrntaln13475.00
      12-06-2022, 10:49 PM   #32
Limegrntaln
Originally Posted by alex2364 View Post
It’s not auto filling my username and password that’s saved in my Chrome password manager when I try to log in.
Attached
YT: G Dubyou
      12-06-2022, 10:50 PM   #33
Limegrntaln
Also back in darkmode
YT: G Dubyou
      12-06-2022, 10:59 PM   #34
apptest
Private2
apptest's Avatar
Thanks. Yes that is no dark mode at all. Not exactly sure what the issue is since I’m not seeing that on a simulator or my own phone.
Anyone else out there seeing this?
Are you using the auto bright -> dark mode or the fixed dark mode?
Test 23456rt
      12-06-2022, 11:03 PM   #35
Limegrntaln
Auto bright. Not sure if you just did an adjustment or it was my phone, but it looks like now it’s working. If I didn’t have screenshots, it would be hard to believe.
Also, when you attach an image, there is no return to message button. I have to swipe down after I upload a picture, because once you attach a pic, it doesn’t automatically go back to the message to type.
YT: G Dubyou
      12-06-2022, 11:52 PM   #36
apptest
Private2
apptest's Avatar
Oh wow, that’s very cool. Nothing done on my end, but I did make some changes at least to get your keyboard to be dark mode.
That’s one weird bug I have to say— Never seen it before and the app has been in production for a long time on the Android side without anything like that happening. Maybe it has to do with auto change. Like you started using the app when it was on bright mode, and then when it auto switched to dark it got confused.
The app right now wont auto switch, it has to be totally closed and exited and restarted to take on whatever mode you are in. I will have to work on getting it to auto adjust for a future version for sure
As for attachments, that’s on purpose in case you want to add multiple attachments. If it auto closed and you wanted to add 3 pics, it would be a pain in the *** to have to keep reopening it to add another pic
Test 23456rt
Limegrntaln13475.00
      12-07-2022, 12:43 AM   #37
Limegrntaln
Ok, gotcha on the attachments. It took me a second to figure out how to use it. I felt like this.
YT: G Dubyou
apptest2999.00
      12-07-2022, 08:03 AM   #38
DrFerry
Field Marshal
DrFerry's Avatar
Drives: '08 E92 M3
2008 BMW M3  [5.25]
2015 BMW X5  [4.50]
Can’t find the search functionality ???
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
M5Rick60145.00
      12-07-2022, 11:34 AM   #39
apptest
Private2
apptest's Avatar
Magnifying glass on the top right when you are looking at the complete forum list or when you are inside a specific forum
Test 23456rt
DrFerry6728.50
      12-07-2022, 02:14 PM   #40
goneloco
goneloco's Avatar
Drives: 2019 M4
2015 BMW M4  [0.00]
After reading and then closing a post app returns to top of postings list instead of holding its place. iPhone 12 mini iOS 16.1.1.
2019 M4 Coupe MG SS DCT ZCP
2015 M4 Coupe MG SS DCT (Trade)
2009 335xi Coupe Dinan Stage 2 (Sold)
2003 M3 Coupe (Sold)
1998 M3 Sedan (RIP)
      12-07-2022, 08:32 PM   #41
Esteban
Esteban's Avatar
Drives: a slow car fast
Bimmerpost app gone from Apple Store.
      12-07-2022, 10:34 PM   #42
Esteban
Esteban's Avatar
^^ New app - I like it!
PS - it’s kinda buggy but I’m sure they’ll work ‘em out.
      12-08-2022, 04:12 AM   #43
10"
10"'s Avatar
Drives: orange BMW 1M.
i am unable to login to the app.
also there is no password reset on the new app
I am able to login through the desktop with my password
but the app just says login failed.
don't read this. too late...
'Cane8531.00
      12-08-2022, 09:50 AM   #44
'Cane
'Cane's Avatar
Drives: 2022 Aventurin/SS G82 xDrive
I've posted in the G80 forum and on the Bimmerpost FB page, but I have been having a ton of issues since the update. Got logged out on all my devices, and it took me 12+ hours to reset my PW (with all the timeouts), finally got the PW reset with my iMac, but I can't sign in on the iOS app (iPhone or iPad) and I can't even sign in on Safari on my iPad. I hardly use my iMac, so that means I won't be able to be as active in the community as I used to be. Any help? Anyone else with similar issues?
Also, FWIW, things I have tried: deleting and reinstalling the App, rebooting both devices, clearing cache, etc. Pretty frustrated right now.
