      04-10-2023, 10:24 AM   #23
Crisp
Crisp's Avatar
Albania
459
Drives: F95 X5M
Just picked up my 760i. No automatic doors. Dealer said there's a huge recall with the sensors not working properly.
I was very disappointed.
Current F95 X5M; E60 M5 6spd; Mclaren 570s; Aston Martin Vantage; Ferrari FF
      04-10-2023, 08:54 PM   #24
Gemini7866
Gemini7866's Avatar
Drives: 2023 i7
2023 BMW I7  [10.00]
Did you have the excutive package in your build ?
      04-11-2023, 04:55 AM   #25
HMN
HMN's Avatar
480
Drives: 2024 X5MC LCI, 2017 F86 X6M
2014 BMW X5  [0.00]
Again.. classic first MY issues. I had the light issue around one month in, but it went two days alter.
2009 E71 X6 50i- Azurite Black - Sold
2014 F15 X5 50i - Sophisto Grey - Sold
2023 G70 740i - Oxide Grey - Sold
2017 F86 X6M - Donington Grey
2024 F95 X5M Comp LCI - Isle of Man Green
      04-11-2023, 05:02 PM   #26
Spam Head
Spam Head's Avatar
United Kingdom
64
Drives: BMW i7 xDrive60 M Sport
Originally Posted by patrikr View Post
Really? A reinstall of the existing version or is a specific version required that fixes this particular problem? When mine was at the dealer about a month ago they told me that there wasn’t a newer version than 2022.11 available.
I am not sure which update they did but, on my one, it took approximately 40 mins and the light bar started to work with all its functions as good as before the fault occurred. I guess they must have updated one of the patches.
      04-18-2023, 02:01 PM   #27
freshxdough
BMW Elite Master Tech | HV Gen 5 | HV Specialist
freshxdough's Avatar
3967
Drives: 2024 iX 50 | 2020 X3 M40i
Originally Posted by Spam Head View Post
NO NO NO!!!
DO NOT try this on the i7.
On the i7 the 12v battery is connected to the car's High Voltage battery. Therefore, in order to do a full battery reset, you MUST first disengage the High Voltage battery and allow it to drain. If you fail to do this, you are exposing yourself to a really dangerous situation and could also potentially seriously damage your car.
It is therefore certainly not as easy as "disconnecting the negative battery terminal" on the 12v battery.
The whole process, if done properly will take about 45mins to an hour.
It will also most likely simply mask the cause of the issue rather than to fix it permanently.
It would therefore be best to simply book the car in for a full software update as this will ensure that all the software patches are up to date. Most likely such an update will fix the issue. I am going to have this booked to be done on my i7 within next 4/5 weeks and will update you accordingly- unless someone else gets to have theirs updated quicker than me!!!!
It takes a couple minutes if done properly. I don’t recommend people to disconnect their 12v or HV unlsss they know how to do it properly. Disconnecting the 12v with an active HV system can cause arcing in the switch contactors located in safety box and greatly reduce their life. A hard shut down causes wear to the equivalent of ~20,000 or so proper shutdowns of HV system.
** PM me for any kind of work if you are local to me. M Performance parts, M Performance suspension, OEM + add ons, Car Eye 3.0 **
Boulder554.50
      04-19-2023, 12:31 PM   #28
frankiegnzlz
Drives: BMW G70
Hello everyone I recently acquired a 740i Carbon Black and also had the passenger vent and Auto door button go out as well 2 weeks in of ownership. The process was fairly simple to fix and diagnose according to my service advisor. They removed the light bar and disconnected the terminals and cleared the fault codes. Re-installed and all is working like it should.
Best of luck to everyone who is having this issue.
greg_t1.50
hufington5167.50
      04-20-2023, 07:47 PM   #29
mattsrs
Drives: X7
Now its my turn. Have had the car for about 10 weeks and been fine. Today, got home turned off the car exited the car and went to passenger side and opened the door and the moment door was opened those lights on the light bar near passenger side went off. This seem to be definitely some of electrical issue. Will take it to dealer next week
      04-20-2023, 11:38 PM   #30
AlteBMW
AlteBMW's Avatar
1655
Drives: 23 760ix 23 X3 25 530ix
2025 BMW 530ix  [0.00]
2023 X3 x30  [0.00]
2023 BMW 760ix  [10.00]
The button issue I have is the rear blinds button on the drivers door neither raises nor lowers the blinds. It brings up the blinds menu on the screen — and that works. I’m not sure I even want them to fix this as I had raised the blinds several times looking for something else on the door by feel. Then I started to think that maybe the last software update might have made this change deliberately. Anyone out there who can educate me on this?
BMWCCA
Current: 23 760ix (Carbon Black/Tartufo) (after first one totaled) '23 X3; '25 530ix
Prior: BMWs (3,5,7 & 8 series (2x!)) X3, MB (C, E, and S), Alfa GTV, MGB, Audi (A4, A6), Saab, Volvo, Toyota, Lincoln, Chrysler, Oldsmobile, Chevy, Rambler.
      04-21-2023, 08:24 PM   #31
Lovin7er
Lovin7er's Avatar
179
Drives: 2023 760i /2025 MAYBACH EQS680
All that button does is bring up the menu on the screen. It is working correctly. It is basically a short cut button.
AlteBMW1654.50
      04-21-2023, 08:26 PM   #32
Lovin7er
Lovin7er's Avatar
179
Didn't they tell you it was deleted from your build after you ordered the car?
      04-23-2023, 07:41 PM   #33
Crisp
Crisp's Avatar
Albania
459
Drives: F95 X5M
Nope. I found out when I picked it up and went looking for the button to open the door.
So any word if they’re going to bring it back?
Is it just the exterior button delete and software decoding or other hardware too?
I wonder if it can be coded back in, at least to tell BMW to open/close doors and with the interior button.
      04-23-2023, 07:42 PM   #34
Crisp
Crisp's Avatar
Albania
459
Drives: F95 X5M
Yes. All packages except the screen in the rear.
      04-23-2023, 07:49 PM   #35
Gemini7866
Gemini7866's Avatar
Drives: 2023 i7
2023 BMW I7  [10.00]
That really sucks I’m still waiting on my i7 and my
Executive package 2 and
Executive lounge seating package with rear screen was deleted
No email or anything explaining I found out while checking my status .so far I was able to add the crystal lights back because it now shows up on the sight but nothing else ..they say it’s suppose to start week of. Jun 18 so maybe other things will also show up on the sight
      04-25-2023, 08:40 PM   #36
AlteBMW
AlteBMW's Avatar
1655
2023 X3 x30  [0.00]
Thank you. I happen to like it that way, but when I got my (first) G70 end of November last year, the door button worked to open and close the shades. This was a royal PITA as it was easy to hit the button accidentally. I believe it changed with one of the OTA updates and thats the way it is in my current car.
BMWCCA
      04-28-2023, 07:58 AM   #37
frankchn
Drives: i7 x60
Interesting, my car was built on 4/20 and currently waiting at port, and all the options I picked seemed to have been preserved on the BMW My Garage website.
The VIN decoder websites also shows that I have the automatic doors (3CD), theater screen (6FR), executive lounge (4F4 and 4F5), and everything else. (I picked everything I could except for two-tone paint.)
Must have just made it through before the parts shortage really hit.
      04-28-2023, 08:46 PM   #38
Gemini7866
Gemini7866's Avatar
Drives: 2023 i7
2023 BMW I7  [10.00]
You are so lucky !!
      05-02-2023, 02:57 AM   #39
HMN
HMN's Avatar
480
2014 BMW X5  [0.00]
Just to add to this, I recently noticed the rear automatic doors aren't working as it should be so the car is currently sitting with the dealer to fix a bunch of other issues. I seriously hope there is no recall on the doors.
      05-02-2023, 08:19 PM   #40
patrikr
Drives: 2023 760i, 2020 Model X LR
My son has been complaining about this as well in my car.
Edit: Nevermind, I had accidentally pressed the child lock button. Doh!
      05-03-2023, 05:05 AM   #41
HMN
HMN's Avatar
480
2014 BMW X5  [0.00]
Apparently my dealer just told me the same thing - he expects the entire light bar to be replaced due to sensor issues.
      05-03-2023, 05:08 AM   #42
HMN
HMN's Avatar
480
2014 BMW X5  [0.00]
well thankfully it wasn't a sensor issue
      05-03-2023, 08:48 PM   #43
mattsrs
Drives: X7
Just want to share that my dealer also said they fixed those buttons by software update. When I took it to service, my SA said there’s a mandatory update available so that’s the first thing they did before even diagnosing the buttons issue but it fixed them too
      05-04-2023, 02:49 AM   #44
HMN
HMN's Avatar
480
2014 BMW X5  [0.00]
+1
Just picked up my car from the dealer, this was fixed too with a software update, but there is still a possibility they may change the entire light bar if the problem recurs.
