02-11-2019, 03:15 PM | #91 |
No one sleep in Tokyo
945
Rep 1,507
Drives: 2011 E90 328i//1995 E34 530i
I let my E90 warm up for about 2-5 minutes. A little bit longer because it's been hitting under 40 degrees Fahrenheit here in San Diego at night. (I know, so cold brrrrrrr)
2011 E90 328i, 1995 E34 530i, 1992 E32 740i, 1991 E34 525i
02-14-2019, 10:50 AM | #92 |
Rep 81
I wait until the engine comes off high idle before driving, and keep the revs low for the first few miles.
Al Bundy's Dodge1640.00 |
02-14-2019, 05:17 PM | #93 |
Rep 3,752
I just start and drive about 20 sec. That about the time I put my phone on its mount and buckle my seatbelt. And then again 20 sec plenty of time to get the oil circulate.
02-14-2019, 05:41 PM | #95 | |
Rep 906
Then while going light on the throttle I usually shift under 2500 RPMs for a couple miles and then keep it under 3k RPMs until the engine reaches operating temp. All I know is what I do wont hurt the car, but driving hard after cold start certainly could.
2009 328i xDrive 6MT (Retired and I miss her)
2015 335i xDrive 6MT (Retired and I dont miss her) 2018 M2 6MT (Never retiring) |
02-14-2019, 06:10 PM | #96 |
Rep 193
Drives: 2012 328i Glacier Silver
I don't warm it up really, but I do take my time to leave from my spot, e.g. look at the gauges, look around my surroundings, wait for garage door to close, check my rear view mirror, etc. before actually leaving. So with all this, this is pretty much my warm up time.
2012 328i Sedan - Glacier Silver - 18" Toyo Proxes 4 Plus Tires with Nürburgring Metal Grey Rims, H&R Sport Springs, VRSF Intercooler, JB+, aFe Air Filter, Magnaflow Exhaust, Carbon Fiber accents, SS Pedals, Bavsound System, BMW CCA member since 2015. First Bimmer - 2000 Z3 M. Second Bimmer - 2014 X1 sDrive28.
02-14-2019, 07:25 PM | #97 |
Rep 2
Warming up the car is a practice that is not current anymore with all fuel injection vehicles. In fact letting the car warm up in idle for the car means that the "normal" functional temperature will take longer to be reached, and the car will have to compensate that by injecting additional fuel into the combustion mixture and we can say that that is "not beneficial".
a few seconds or a minute or 2 is more than enough to make the oil engine moving, after that driving smoothly until it reaches the "normal" operating temperature is the best practice for the sake of the motor |
02-15-2019, 03:49 PM | #98 |
Rep 859
No need to idle for minutes on end. You want oil pumped back to the top of the engine which occurs in the first few seconds of running, then take it easy on the gas until there's temp in the coolant AND in the oil.
2023 i4 eDrive40
2022 Acura MDX |
02-16-2019, 04:32 PM | #99 |
i'm just saying
5731
Rep 2,634
the duration of warming up depends on the temperatures for me but i believe waiting a little is good for every engine.. in hot summer days a 50-60secs will be enough.. in really cold ukraine winter i do wait 2mins at least.. and in super cold winter days i never turn off the engine when its super hot.. like pushing it for a while before reaching the destination.. i believe its not good also.. driving calmly in last 3-4 mins before i arrive..
if more than 12 hours past i do wait at least rev goes down.. for my current ride i press M button and wait till exhaust flaps open on its own.. then i go.. driving progressively higher revs till oil reaches optimal levels.. below -10c things are not like that cause viscosity changes also.. thicker oil cant reach every part of the engine %100 for a while.. actually cold start behaviors is affecting a lot for engine's lifespan.. not even talking about turbos.. |
OUGrad05525.00 |
02-17-2019, 09:19 AM | #100 | |
Rep 859
My garage drops to about 50* when its in the teens F* outside, so it has to get pretty darn cold to drop the temp in my garage to the mid 40s. That's only happened once or twice and both times it was below zero F outside If you're car is constantly in temps that are well below freezing you may need to let it idle for a short period but no need for a 10 minute idle session.
2023 i4 eDrive40
2022 Acura MDX |
02-17-2019, 05:12 PM | #101 |
Rep 18,726
It's called multi-viscosity oil for a reason...
02-21-2019, 10:00 AM | #103 |
Yoda of mods
1673
Rep 3,004
Drives: X5 RWD
I wait 15 seconds and drive.
Current: 2020 Explorer ST (Agate Black Metallic), F15 SGM RWD
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired) Follow me on Twitter: https://twitter.com/EdwyerCLT YT: https://www.youtube.com/@DWYERGARAGE/videos |
02-21-2019, 08:16 PM | #104 | |
Rep 3,030
02-21-2019, 08:18 PM | #105 | ||||
Rep 1,459
Drives: 2023 G81 M3 Touring
02-21-2019, 08:23 PM | #106 |
Rep 3,030
02-28-2019, 10:41 AM | #107 |
Rep 182
I don't let it warm up... but that being said, I live in FL and coldest it gets is in the 30s... mostly 70-90f weather.
My corvette shows me an alternative redline until engine warms up. Pretty sure some other BMWs have this. I go by that. |
02-28-2019, 12:55 PM | #108 | |
Rep 6,862
BMW M cars have a variable red line which increases as the engine warms up. However, even the reduced red line its still far too high to rev on a cold engine. I always keep it below 3k rpm until the oil temp needle has come off its resting position. |
02-28-2019, 02:11 PM | #109 | |
Rep 182
I wonder if car's shift points change to upshift more when engine is cold? Also what is the running temp for our cars generally? US cards are 190-210.... I noticed this X5 runs around 230. |
02-28-2019, 02:23 PM | #110 |
Rep 6,862
My car is a manual so I control the shift points, but I dont think the autos take engine temp into consideration. As long as you are not in D3/sport+/performance driving modes and accelerate mildly the transmission will likely never shift above 3k rpm.
