      03-20-2020, 06:58 AM   #1
Lightfytr
Drives: 2017 750ix 2014 M5 Competition
BMW Platinum Warranty
Just purchased my CPO 2017 750ix. I researched different warranties and found on some of the forums the deals given by Steve Thomas BMW in CA. I called and spoke to one of the new warranty sales reps, Theresa. I will tell you she gave me an amazing deal that was cheaper than the other 5 BMW dealerships I contacted. If you are considering a BMW warranty, give her a call.
I got the platinum wrap coverage, 6 years unlimited miles. under $4k
If you are military, let them know.
Tell her Grant sent you!
Theresa Belvedere
Steve Thomas BMW
805-482-8878
tbelvedere@stevethomasbmw.com
2017 750ix & 2014 M5 Competition
      03-20-2020, 01:54 PM   #2
13M5F10
Hide! My wife's coming!
13M5F10's Avatar
Thanks for sharing. That's awesome news. Just shot her an email.
      03-20-2020, 06:57 PM   #3
Lightfytr
Any answer yet?
      03-20-2020, 08:05 PM   #4
13M5F10
13M5F10's Avatar
Any answer yet?
Yes, same deal as yours. Debating whether i should or not in case I sell the car. Need to call her.
      03-20-2020, 09:00 PM   #5
Lightfytr
Awesome! They really do give the best prices.
      03-20-2020, 11:47 PM   #6
Moopai
Moopai's Avatar
Drives: M850GC Tanzanite Blue Metallic
What does the platinum wrap coverage cover? How good is it in comparison to the original warranty? Thanks
Theresa Belvedere
Steve Thomas BMW
805-482-8878
      03-21-2020, 04:30 AM   #7
Lightfytr
From BMW:
As with standard CPO Protection Plan coverage, CPO Wrap plans cover engine, automatic/manual transmission, final-drive assembly, steering, hydraulic brake parts, anti-lock braking system, electrical, air-conditioning/heating system, cooling system and fuel system repair/replacement (with certain limitations).
The standard CPO Protection Plan does not cover audio, entertainment or navigation systems. To obtain coverage of those systems, you will need to acquire one of the two CPO Wrap Platinum plans described above.
https://pictures.dealer.com/bmwsplas...4ab02653e2.pdf
      03-21-2020, 10:41 AM   #8
Moopai
Moopai's Avatar
Thanks
From BMW:
      03-28-2020, 10:52 PM   #9
inque1
Drives: 2016 740i
That is awfully cheap for a platinum warranty. I just paid over $6K for 5 years, 75K miles.
      03-29-2020, 03:27 AM   #10
Lightfytr
I realized after calling around, dealerships can offer different prices, maybe based on performance of dealership/incentives.
      04-11-2020, 06:28 PM   #11
OnlyGerman
OnlyGerman's Avatar
Drives: F15, F13, F10, E60
Does this add 6 years from date of purchase?
      04-12-2020, 02:14 AM   #12
Lightfytr
It can, depends on which length you choose.
      05-05-2020, 11:52 AM   #13
Malu59RT
Malu59RT's Avatar
29
Drives: BMW 740i
Anyone know of any big ticket items that haven't been covered with a CPO Platinum Wrap? I couldn't find any mention of the air suspension components being covered under the CPO, and wondering if there are any other items that wouldn't be covered. Thinking about getting a CPO car with 7yr/unlimited mile warranty. I figure brakes would be one of the bigger ticket items to deal with. Anyone with any experience? Thanks!
2021 X7 40i - Tanzanite Blue
2016 BMW 740i - M Sport (Gone)
      05-05-2020, 03:05 PM   #14
13M5F10
13M5F10's Avatar
I found this online ... i recall someone with air ride on their 7 getting the air ride covered. I guess if depends on what the failing part is.
WHAT IS NOT COVERED
The BMW Certified Pre-Owned Protection Plan provides specific coverage against defects in materials and workmanship. There are various items that are not covered by this warranty for enrolled vehicles retailed on or after September 1, 2017
Vehicle Maintenance
Brake pads and rotors (discs), brake shoes and drums; filters; fluid replacement of a component by itself; scheduled maintenance services; spark plugs; wiper blade inserts, blade assemblies/beams.
Upkeep
Adjustments; batteries (as a stand-alone repair); driveshaft flex disc (guibo coupling); engine drive belts; exhaust systems (including the gasoline engine catalytic converters, and the diesel engine "SCR" catalytic converter and particulate filter); flywheel, ring gear and clutch disc contact area; fuses; manual and "SMG" transmission clutch assemblies; oils, lubricants, fluids, refrigerants and coolant (except as required in the course of performing a covered repair); rubber engine and heater coolant hoses, vacuum hoses (including clamps and connectors); tires; tire balancing and rotation; wheel alignment.
Suspension
Ball joints; bushings; center tie rod; coil springs – sagging (except for leveling system pneumatic/hydraulic springs); control arms and brackets; idler and pitman arms; stabilizer bar links and supports; strut elements/shock absorbers (dampers); tie rod ends and adjusting sleeves; trailing arms, thrust struts; wishbones.
Body
Air leaks; body carriers, cross members, supports, braces and mounts; body panels, body shell, walls, partitions and chassis sheet metal; body noises, squeaks and rattles; body seals and gaskets; bulbs - incandescent, Xenon and LEDs; convertible top (except for electrical/electronic components); damage due to rust, corrosion or contamination; door brakes and checks; door handles and carriers (except for electrical/electronic components); exterior moulding, trim and fasteners; gas pressurized springs/struts; glass - side, sliding roof, rear and mirrors (except for electrical/electronic components); latch and lock mechanisms and their related components (except for electrical/electronic components); paint finish; water leaks; wheels and valve stems (except for electrical/electronic components); windscreen (including the sliding roof); windshield (except for the front rain sensor); wind noises.
Interior
Bulbs – incandescent and LEDs (except for the instrument cluster); carpeting; floor and trunk mats; headliner/sliding roof liner panel; interior noises, squeaks and rattles; interior dashboards, consoles, panels, covers, vents, grills, trims and fasteners (except cup holders); seatbelt extender arm assembly (except for electrical/electronic components); sunblinds (except for electrical/electronic components); sun visors (except for electrical/electronic components); upholstery (except for seat heating elements and seat occupancy sensor mat).
Accessories (Standard and Optional)
All non-original equipment parts, components and accessories.
      05-12-2020, 02:29 PM   #15
direw0lf
Drives: BMW 750, Ram 3500, Porsche 997
I got a quote from Theresa and for the 6 year 75K wrap she was barely less than MSRP.
