      09-18-2020, 06:52 AM   #353
theechassis
Drives: E93
Little help
Originally Posted by Almaretto View Post
Originally Posted by Alex@Alpine View Post
I can code the new 7 series no problem. It's minimal options such as folding mirrors with key, windows up with key, removal of seat belt chimes, amber delete, removal of legal disclaimers, rolls Royce gong (the new one.)
DVD in motion is only for clients local to Los Angeles & New York (will not do remote.)
Most of the functions have the same names; one exception being enabling closing of trunk with KeyFOB.
I was able to enable Video in Motion on ID4 for HU_NBT2, but only up to 63 kmh on ID5. How did you figure out DVD in motion? Is it with hardware or just coding?
Among others, I can do the following:
Enable/Disable Horn when locking vehicle with engine running
Fold mirrors/ roll up windows with keyfob and CA
Remove Mirror / Window Initiation Delay with CA and KeyFOB
Remember Auto Start Stop Setting when shutdown
Unlock doors when Engine stopped if either auto-locked during driving or manually locked
Enable Fog Lights with Parking Lights
Enable Fog Lights with High Beams
Allow Front Window Roll Up when doors opened
Allow Rear Window Roll Up when doors opened
Close Trunk with KeyFOB
Remove Seat Belt Warnings
Disable Headlight Washers
Enable HVAC to Remember Settings when vehicle shutdown
Disable Turning on A/C if AUTO is pressed
Disable Seat Belt Status in Cluster (Passenger/ Driver)
Disable Seat Belt Reminder (Driver/ Passenger)
Disable Seat Belt Disconnected Reminder Sound (Driver/ Passenger)
Disable Initial Belt Warning
Disables 1st fuel warning at 50 miles
Efficient Dynamics Graph Direction (Left to Right or Right to Left)
Trip Computer Auto Reset (Never/ Always/ 4 Hours)
Enables HUD Distance Info
LIM FUNCTION
Disable Cluster ASS notification
Enable/Disable Speed Correction
Cameras at All Speeds
Various (12+) Head Unit Functions (Disclaimer Removal, Entire SMS message, British Navigation Voice, Tire Pressure & Temp, etc)
How were able to ge the trunk to close with the fob? I can't get it to work.
Thank you
      09-21-2020, 02:35 AM   #354
sarb2
Drives: G12 2016
Hi dear
Can I use bimmercode app for coding this option
1-edit the ACC space with a car in front
2-open camera with any speed
3- change the color
The problem is i can't find the correct value
Like V_SCHWELLE for camera ( REM, TRSVC)
ACC ( ICM 3000 daten)
Color ambient ( lci_lci) there is no 360A or 360D
I can't find the correct value in expot edit
I have g12 2016
Please if you can help me
Thanks all
      09-21-2020, 02:50 AM   #355
sarb2
Drives: G12 2016
If you wanna this
      09-21-2020, 02:53 AM   #356
sarb2
Drives: G12 2016
GLOBAL_TUBE_RECHTS_INHALT_ECO_ANSICHT eda -> komb_verbr_anzeige [01]
ECO_RW_DIGITAL_ENABLE nicht_activ -> activ
ECO_RW_ANALOG_ENABLE activ -> nicht_activ
hmi_MSA_COUNTER_ENABLE nicht_activ -> activ
HMI_SEGEL_COUNTER_ENABLE nicht_activ -> activ
HMI_ECO_SPA_ENABLE KEINE ANZEIGE -> SPA
You can do it with bimmercode app
      09-28-2020, 11:28 PM   #357
snowmuch
Drives: 2016 Macan Turbo
Anyone know how to code the tail lights so they light up during the day with bimmercode?
C300->C63->535->S4->M4->Macan->Macan Turbo
      10-06-2020, 12:59 AM   #358
MauricioJay21
Drives: G12 BMW 750i xdrive
Hey guys long time lurker, I’ve looked through tons of pages and threads and cannot find whether or not it’s possible to code the M760 cluster into my 750i, not the M760i logo but the cluster itself which shows 200mph on the dash. I’ve tried a couple things in BimmerCode expert mode but no dice, any input appreciated thank you
      10-06-2020, 05:04 PM   #359
mrgicm
mrgicm's Avatar
441
Drives: BMW M
Yes it is possible. Not sure wheather it can be done with bimmercode.
      10-06-2020, 10:01 PM   #360
MauricioJay21
I figured if the alpina dash can be done then the M760 must be do able as well, do you know where it would be ? I tried going into the instrument cluster and changing M_LAYOUT_Variante to M but this did not do anything
      10-07-2020, 07:52 AM   #361
padrino
Alpina!
363
Drives: Alpina XB7
I have a M760 and although I have only ever done it with Bimmercode the dash type seems to be separate, if I code Alpina, M, or BMW I get the readout to 200.. Mentioning as it is probably a separate option from the dash itself.
2021 Alpina XB7 - Alpina Blue
2022 M5 CS - Frozen Gray
      10-07-2020, 03:19 PM   #362
MauricioJay21
I get the 200 with the alpina dash but I prefer the regular look, what you just said makes me think there is something else I must enable to get it to 200 just can’t figure out what
      10-23-2020, 01:58 AM   #363
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Thank you
My launcher cheat codes will enable function for you.
      10-25-2020, 01:17 PM   #364
JustinP
Drives: BMW X3M competition
Hi All, I’ve just installed ISTA and have successfully connected it to my 2019 G11 using an ENET cable. Can one of you kind gents talk me through the process of lowering my car a little?
A quick google suggests this should be possible using the Vehicle Management menu and then selecting Service Function -> Chassis and suspension -> ride height setting.
I guess I should add 15mm to the actual height measurement of each corner to trick the car into thinking it’s sitting a little higher?
Is there anything I should be careful of?
My gravel drive way isn’t level enough, so I plan to do this at work, so won’t have the car connected to a battery charger.
      10-30-2020, 11:49 AM   #365
JustinP
Hi all, I’ve successfully lowered my G11 15mm using ISTA and a £12 ENET cable from Amazon. I’m very happy with the result.
      12-01-2020, 02:18 PM   #366
Daans
Daans's Avatar
Netherlands
51
Drives: Bmw 440ix grand coupe
Originally Posted by andriuszz View Post
Hi,
If anyone interested coding g11, g12 for Automatic heating activation for seat and steering wheel heating, settings below. It took for me many hours to find these setting, thanks to Eaglesrest and Skepta for help.
BDC_BODY\LHZ_CCM_IKF value: aktiv
BDC_BODY\IKF_ENABLE, value: ikf_alle_sitze
HU_EVO\AKT_AUTO_SITZE_FRONT value: heizung
HU_EVO\AKT_AUTO_SITZE_FOND, value: heizung
HU_EVO\AKT_AUTO_LENKRADHEIZUNG, value: aktiv
Happy coding !
Perfect! Good job👍
      12-03-2020, 03:07 AM   #367
Almaretto
Almaretto's Avatar
2374
Parameter is in Github launcher Cheat Codes. Also some G20 driverfs reported it is automatically enabled with 7/2020 software.
      12-05-2020, 06:31 PM   #368
rickyd99
Drives: BMW 740xd 2016
Hi all,
I have been coding my 2016 740 G11 and have gotten some awesome stuff going. Currently using Bimmercode and OBDLink MX+. I wanted to ask about a specific code I really want but not sure how to do.
I want the auto high beam assist to always be on. Every time I need to press the button, and every time I shut the car off and back on it resets and I need to press the button. Is there anyway to do this?
Also, can someone please tell me how to add CarPlay to my car? I don't have the option from BMW to do it (March 2016 production) so I need to get it activated via FSC code and then coded into the car. I would really like to do it but not spend like $100 for this like many online websites ask for. Would love to any advice. I have the 2019 software on the car and coded ID6 Lite from ID5++ on it.
      12-05-2020, 11:34 PM   #369
Almaretto
Almaretto's Avatar
2374
Originally Posted by rickyd99 View Post
Hi all,
I have never seen coding to enable as auto-hba on a g11.
Check eBay... There are multiple sellers for much less. Hopefully car has been updated since factory because carplay is rather buggy in early software.
      12-06-2020, 04:41 AM   #370
mrgicm
mrgicm's Avatar
441
Drives: BMW M
Hi all,
Adding Carplay is not simply coding. Depending on the activation going with cheap solutions might bring you problems in sone cases, as dealer might not be able to update your car. 100$ is not much, you drive a 7 series not a VW Golf. The cheapest way is doing it right the first time.
      01-08-2021, 11:28 AM   #371
Sedoy
Drives: F10
Did anyone tried this in US? I wonder how it works?
Hey guys,
I am getting many PM’s regarding hands off driving with steering assist coding. Please note you need driving assistance plus package to code this option. I would like to share my knowledge with others so this information is available to anyone.
CAF: SAS
C_STA_ALC_handsoffgestchwausschaltgrenzeKmh
C_STA_ALC_handsoffgestchwausschaltgrenzeMph
C_STA_ALC_handsoffgestchweinsschaltgrenzeKmh
C_STA_ALC_handsoffgestchweinsschaltgrenzeMPh
Change werte value to desired speed (use hex converter) when hands is required on the wheel. Please be aware steering assist occasionally disengages without any warning. Use this coding on your own risk !
      01-21-2021, 03:45 AM   #372
sarb2
Drives: G12 2016
LIM FUNCTION
How can I do this please for g11
      01-21-2021, 04:15 AM   #373
Almaretto
Almaretto's Avatar
2374
Using E-sys and Launcher Pro or EsysX.
      01-25-2021, 05:22 AM   #374
sarb2
Drives: G12 2016
Thanks for reply
But what i need to change in any foler and details like this if you know
Thanks
