11-02-2020, 08:50 AM | #1 |
Rep 11
Spacer/Adapter for M760i winter wheels/tires?
Hey team, I have a 2018 M760i that I bought earlier this year as a CPO. Dealer included a set of BMW wheels with winter tires that previous owner traded in with with car. Winter tires have less than 2,000 miles on them, so I'd like to use them if I can.
Stock Summer set is style 760 M, 245/40/20 Front and 275/35/20 Rear (5x112) Winter set is style 343 M, 255/40/20 Front and Rear (5x120) The winter wheels didn't come with any adapters or spacers. Can any of you recommend a specific brand or manufacturer for an adapter that will work with my winter set? Have any of you run a similar size on an M760i? I'm worried about the fronts sticking out too far with an adapter since they're already slightly wider. Thanks! |
11-03-2020, 02:49 PM | #2 |
Rep 7,484
You need to get more info about which 343M wheels you have. They came in various staggered set-ups with different wheel offsets depending on which model it was being offered on. So you need to know (and reveal) which 343M wheels you have when discussing them. Since you have the same size tires...you probably have a set of 4 wheels that are the same...but which ones do you have?
There should be info on the back side of the wheels or around the hub. For example: M5 343M
M6 343M
