12-19-2016, 10:15 AM | #1 |
Rep 3,537
Laptop Spec's - Which is better?
I was wondering if someone could provide some feedback on what would be a better option to go with when comparing the two laptops listed below.
Things to note: This laptop's use will orient mainly around internet browsing and music/movie downloading, along with general MS Office use. This will not be a gaming laptop. Link to the same specs I posted below: http://www.bestbuy.ca/catalog/compar...button_laptops Thank you. |
12-19-2016, 10:26 AM | #4 |
Rep 3,395
Both are bare bones entry level machines
The lesser expensive box with the AMD processor is the better value....and you get an extra USB port Both have slow as shit HDD's but you also get more RAM with the AMD box The AMD has 4 cores to the Intel's 2 AND a lot more l2 cache which improves response time Last edited by jpnh; 12-19-2016 at 10:32 AM.. |
12-19-2016, 10:27 AM | #5 | ||
Rep 3,537
Could you guys elaborate a bit on why i5 over A10? |
12-19-2016, 10:31 AM | #7 |
Rep 3,395
12-19-2016, 10:35 AM | #8 | |
Rep 3,537
From what I can see there they tested I5-6200U where as the one I got listed is i5-6198DU. Regardless looking at the site wouldn't you say AMD A10-9800P outperforms i5-6200U |
12-19-2016, 11:22 AM | #9 |
Slow.
3782
Rep 7,151
Drives: Single Turbo N54 on Meth!
I wouldn't buy any computer without a SSD in this day and age. But I would go with the intel lappy.
12-19-2016, 11:27 AM | #10 |
Rep 458
My current computer I built has an i5 CPU. However, I would recommend the one with the AMD. Based on what you are doing with it, the additional USB port and 50% more RAM at a $50 less price will be more beneficial.
01-02-2017, 06:46 PM | #11 |
Rep 5
I would go for the AMD, but I first would check if the hdd is easily swappable. You can turn that $500 laptop into an $800 laptop by switching out the hard drive to a SSD. I just upgraded my wife's old laptop this weekend, and it went from a slow POS to a speed demon!
GuidoK10767.00 |
01-02-2017, 10:00 PM | #12 |
Rep 1,303
Drives: 2021 C8 Corvette 1LT
Go with the i5. Intel runs cooler and uses less energy (usually means charge lasts longer, but maybe by 10minutes or maybe by 30minutes). It's a laptop so heat can cause a ton of issues like a failed hard drive, CPU fan (saw it happen a lot) and in rare instances the CPU itself.
I love AMD, but regardless what the add says, it doesn't support DDR4 yet. Their new processor architecture will (Zen platform). Also, the "graphics card" mentioned by someone else is false. The A10 is an APU with a couple more graphics cores on it. It does not have a dedicated graphics card. Also, the extra l2 cache is good, but when on a 5400rpm hard drive it means absolutely nothing. Expertise: Worked Geek Squad for 5 years fixing computers and selling new ones. Plus I've built a countless number of desktops and upgraded them and laptops more than I care to count. |
01-03-2017, 12:03 AM | #14 | |
Rep 1,514
01-03-2017, 05:32 AM | #15 |
Rep 3,241
01-03-2017, 07:00 PM | #16 |
Rep 1,514
01-03-2017, 07:02 PM | #17 |
Rep 1,514
01-04-2017, 12:06 AM | #18 |
Rep 3,241
01-04-2017, 01:41 AM | #19 |
Rep 1,303
The only thing hardware locked is the factory OS recovery discs. They look for specific hardware to verify it is the correct OS for their laptop. This is done because it doesn't prompt for a product key because of the mass license they purchase from Microsoft. Guaranteed the hard drive isn't one of the checked items because those go bad much quicker than say something specific to the model like a motherboard. A normal copy of windows that comes with a product key only checks for a storage medium to put the files onto during the install.
01-04-2017, 03:17 AM | #20 | |
Rep 1,514
01-04-2017, 04:51 AM | #21 | |
Rep 1,303
Edit: Forgot to mention that the only thing that would cause windows to "complain" about a hard drive is if it couldn't recognize it. This however is usually because the motherboard doesn't support the size of the hard drive (usually not a problem now days). This would be due to a 2TB limit on the SATA controller, or a BIOS limitation (usually fixed with a BIOS update). The only time it is due to Windows is if you're running an old version of Windows (XP 32-bit I believe, think 64-bit fixed the issue) where windows doesn't support over 2TB storage media. On either of the laptops in question though, Windows 10 recovery media wouldn't care if it was a HDD, SSD, or over 2TB in size and neither would the hardware. Last edited by Joe240; 01-04-2017 at 05:33 AM.. |
01-04-2017, 07:42 AM | #22 |
Rep 3,537
So just a quick update:
I didn't end up getting the AMD one. However I did get this Dell laptop $499 from Microsoft Store (as it was one user's suggestion) along with the Asus VivoBook i5. Currently I am comparing the two side by side and Asus is loosing the battle. Screen quality on Asus is horrible. Dell's HD screen blows it away. A few additional perks that Dell offers are touch screen, backlit keyboard and cd drive and a slightly newer i5 gen. from the link above: So far I am leaning towards returning the Asus and staying with this Dell machine. |
Joe2402923.50 |
