02-03-2021, 01:30 AM | #1 |
Rep 27
Coolant on garage floor.
Coolant on garage floor under my car. Check reservoir still at max, slight white coolant residue splash around tank. Remove engine cover looked over hoses and didn't see any indication of a leak. To much fluid to not be a potential leak from the car. Any help will be grateful appreciate. I did have the low coolant warning light around the holidays. Dealership top off fluid. I did purchase some coolant as well just for future alarms. Thanks for all the help
02-03-2021, 07:26 AM | #2 | |
Rep 912
I would get the dealer to check it again. You are right, this a lot of coolant, it has be coming from somewhere.
02-11-2021, 05:49 AM | #3 |
Rep 27
Vehicle went to the dealership, pressure test conducted no leaks. 🤦🏾*♂️🤔. However thrust bushings are leaking so warranty replacement.
OnlyGerman372.50 |
02-18-2021, 09:41 AM | #4 |
Rep 8
May only leak when it sits over night and gets cold. seen this happen a lot,
02-23-2021, 10:09 AM | #5 |
Rep 99
Turbo coolant lines leak on this car.
OnlyGerman372.50 |
02-24-2021, 09:07 PM | #7 |
Rep 67
I had a similar problem a few weeks ago. Mrs H62 reported the low coolant warning, so I topped off the reservoirs. Seemed OK for about a week, then happened again, but this time I noted a LOT of coolant on the ground. Called the dealer, they sent a tow (and a loaner). Report is that both a coolant line, and the larger reservoir were cracked. Parts ordered (covered under warranty), but snow-ma-geddon has delayed delivery.
02-24-2021, 09:50 PM | #8 | |
Rep 99
02-25-2021, 09:56 PM | #9 |
Rep 67
02-25-2021, 10:43 PM | #10 |
Rep 99
I see, so your 4 yr original factory warranty is covering it, not your cpo, as I bought cpo also but this wasn't covered as I was out of the original 4 year window
02-26-2021, 12:02 AM | #11 |
Rep 27
I have a 16 740i with 40k and I had topped off the reservoir as well. Took it in and they stated all was well. Pressure test no issues. I'm still in shock. The coolant came from some where. My factory warranty is up this April thank god I have a secondary warranty as well just incase.
