07-12-2019, 05:36 PM | #1 |
Rep 891
How to operate the side sunblind rolo
Hello, so one very frustrating thing I can figure out is there a way to lift the rear side sunblinds from the drivers seat? On my previous A8 I would just double click to close the window and the blind would come up.
Is there a way to lift the rear side sunblinds or to code it? |
07-12-2019, 05:40 PM | #2 | |
Rep 6
07-14-2019, 09:32 PM | #4 |
Schumacher
786
Rep 2,278
Drives: E30 325is,E93 M3,X7M50,F06 M6
You can only put them all up or all down (including the center).
If you just press the button once it will put up the center shade and thats it, if you press and hold after you already hit the button it will just stop the center one and bring it down. You need to hold it down from the start and it will bring up all 3 at the same time. Same thing to bring them all down, you need to hold it down from the start with no delay.
07-15-2019, 11:25 AM | #5 | |
Rep 7,475
So if the sides are up and the rear is down (or vice versa)...press driver's button to either get them ALL up or ALL down. Once they are all in the same position, the driver's button can raise or lower them ALL with one single press & hold.
07-22-2019, 09:26 AM | #7 | |
Rep 7,475
(and again to anyone who may have missed it earlier in the thread...all 3 rear shades can only be operated together if they all are in the same position...if they aren't...once you get them all in the same position, then they can be raised or lowered together)
Smlltmr7501.50 |
07-26-2019, 06:50 PM | #10 | |
Schumacher
786
Rep 2,278
