04-04-2020, 11:49 AM | #1 |
Rep 401
More HP in 2020
I just discovered today that the 2020 750i xdrive not only has a bigger grill, but they squeezed out more HP in the engine too.
Anyone spent considerable enough time behind the wheel of a 2020 and an earlier model to tell whether its appreciable or more of a paper difference? |
04-04-2020, 12:33 PM | #2 | |
Rep 1,487
Blessed Beyond Measure
04-04-2020, 07:42 PM | #3 |
Rep 1,522
Would be a pitty when you can't feel it.
Torque is up from 650Nm to 750Nm, which is 15% more over practically the entire rpm band. Power is up also 15% which seems a serious upgrade. This renders the M760i rather obsolete. |
04-04-2020, 11:12 PM | #4 |
Rep 254
You can make up the difference easily with a simple ECU tune. I did a ecu remap (tune) recently and it transformed the car specially in sport mode. Very very torquey V8
C300->C63->535->S4->M4->Macan->Macan Turbo
04-05-2020, 06:01 AM | #5 |
Rep 401
04-05-2020, 07:51 AM | #6 |
Rep 226
I know I’m comparing my 750i which is RWD with a new one which is 4WD only, but it’s also 15% heavier, so once up and running and past any traction issues it won’t feel any different.
04-05-2020, 10:05 AM | #7 |
Rep 1,595
I had a '17 until October '19 and a 2020 since. I drove the 17 mostly in adaptive mode and same for the 20. The 20 feels more lively and responsive and this is something I noticed immediately. Noticeably quicker off the line -- and I am not a jackrabbit at all. Also noticeably quicker to accelerate from speed while on highway. But of course I have no way to quantify now.
There is a way to reset the "learned" shift points. Ignition to accessory and then press gas pedal to floor for 1 minute. I believe this resets the learned shift points to whatever the default is. After that the car will "relearn" -- and there are some who say this is bogus. But it also can't do any harm to try.
BMWCCA
Current: 23 760ix (Carbon Black/Tartufo) (after first one totaled) '23 X3; '23 MB E Wagon Prior: BMWs (3,5,7 & 8 series (2x!)) X3, MB (C, E, and S), Alfa GTV, MGB, Audi (A4, A6), Saab, Volvo, Toyota, Lincoln, Chrysler, Oldsmobile, Chevy, Rambler. |
04-05-2020, 04:01 PM | #8 |
Rep 1,522
AWD adds about 4% in weight. But indeed, when you'd upgrade to 2020 because it would mean a world in difference, that will most certainly not be the case.
04-05-2020, 04:07 PM | #9 |
Rep 1,522
04-05-2020, 10:51 PM | #11 |
Rep 839
You should feel it, there is .3 second difference between pre-LCI and LCI from 0-100 kilometres. According to BMW 0-100 in LCI is 4 seconds flat vs 4.3 seconds on our cars!
04-05-2020, 11:27 PM | #12 | |
Rep 63
Prior to the M760Li I had 750Li 2016. I have to say the upgrade was worth it, more than I thought it would be.
BMW M760Li 2018 | BMW M850i 2019 coupe
04-06-2020, 05:54 PM | #13 | |
Rep 1,522
The M760i was also an assertion of superior and refined power. I presume with the improved V8 the delta has become too small to maintain the 760. I guess BMW already communicated that they will discontinue this engine? |
04-09-2020, 12:15 PM | #14 |
Schumacher
786
Rep 2,278
Drives: E30 325is,E93 M3,X7M50,F06 M6
I could feel it going from a 2019 750 to a 2020 750 loaner they were both xdrive.
I am going to tune mine.
