01-25-2021, 07:13 PM | #375 |
Rep 8,364
01-27-2021, 08:16 AM | #376 |
Rep 104
2017 730xd B57 engine. Is it possible to deactivate swirl flap motor that open and close flaps?
I have 2F8500 error code. Maybe it can be done some adaptation? Everything is running ok. |
02-21-2021, 04:16 AM | #377 |
Rep 3
reclining ear seat.
Hey. I have reclining rear seats, and passanger side also have button to fold down front seat. Problem is that kids can press button and start front seat to fold even someone is sitting at front. Is that normal? It was quite hectic moment when my aging dad was sitting at front, and seat began to crush him when my son pushed wrong button at back. Is there way to prevent this.
02-21-2021, 08:29 AM | #378 | |
Rep 891
02-25-2021, 07:16 PM | #379 |
Rep 48
I'm a bimmercode user and it appears the option to code the code the vehicle to start up in "Adaptive" mode (instead of Comfort) no longer appears on the LCI model. No issue on the pre LCI (16-19). Any fix or workaround for this?
03-14-2021, 07:02 PM | #381 |
Rep 8,364
03-14-2021, 07:35 PM | #382 |
Rep 846
03-14-2021, 10:21 PM | #383 |
Rep 8,364
Sorry, I do not have all the changes written out to share.
04-11-2021, 07:15 PM | #384 |
krrrraaauuuuut
180
Rep 524
Entertainment Coding
I haven't found any conclusive results to see if I can get the rear HDMI input to play on the front screen on Rear Seat Entertainment options? I know European models have TV in motion right? I need a way to be able to control the rear monitors and see what I'm clicking so the tiny tyrant VIP passenger can be satiated! . I'm running Roku on a stick w/ BMW hotspot.
(Current) G12 750i X Drive / M-Sport / LOADED
(Current) 997 Turbo / 6MT / HRE FF01, Land Rover LR3 - Overlanding Family Adventure Shed, E60 525i - "family beater", Alfa Romeo Spyder Veloce - garage art (Gone) F10 550i / M-Sport, D2 Audi S8, AP1 S2000, Z32 300zx, S13 240sx |
04-12-2021, 12:36 AM | #385 |
Rep 160
Drives: BMW M760e xDrive (2x)
As far as I know on the PreLCI 7 the rear hdmi input is not connected to the front screen.
So it won't be possible. This would work on the LCI models. |
krautmeister180.00 |
08-29-2021, 02:25 PM | #386 | |
Rep 4
I think I have managed to get that done but I have no clue if that's safe or not, just my own/self experimentation, Go to instrument cluster on BimmerCode, then Expert mode and search for "MPA_ENABLE" and click on aktiv as it shows then start coding, however I haven't tried it that long only a few mins and got it back to the default one because I am taking the car to the Service. but it worked tho .. I hope it is safe doing as I haven't seen anyone has posted something about it. I believe this is what you meant by original layout, my car is a G11 740Li 2019. |
02-11-2022, 04:20 PM | #387 |
Rep 10
Hey guys, I've been trying to find some methods to code the following :
1. Make screen mirroring full screen 2. Soft touch turn signals to 5 blinks - I have found a way to put it in the Headunit but can't select it 3. Either remote start the car, or enable remote start for preconditioning ventilation. 4. Change the hud skin to the M hud, and add turn signals in the hud, and add more things to the hud. 5. Add the recommended tyre pressure feature in the tpms as seen on x3 2019. If you guys have any input on that would be amazing |
RMDrive0.00 |
02-22-2022, 08:52 AM | #388 |
Rep 8
Hey I just recently had the lowering links installed on my 740. The car appears to be lower while driving but when I park, it lifts back up. Does anyone know how to code it to where it stays lowered even when in park?
02-28-2022, 02:16 AM | #389 |
Rep 10
How did you manage to lower your car, can you provide the values you changed and where ? Thank you
02-28-2022, 05:12 AM | #390 |
Rep 80
03-02-2022, 10:47 AM | #391 |
Rep 8
03-03-2022, 03:16 AM | #392 | |
Rep 8,364
2. This works on ID7 with coding in BDC and MGU. 3. Remote start requires display key, vehicle antenna, coding, and initialization with ISTA. 4. HUD Turn signals does not work on any DKOMBI (digital dash) 5. The temperature dependent recommended values? |
03-06-2022, 06:18 PM | #393 | |
Rep 10
2. I managed to find the values to have it in the HMI, but i cannot select it, what are the values which i need to modify in BDC ? 3. I have display key, i also have remote parking, thats why i thought it might be easier, can you tell me how to do it ? 4. Understood. 5. I think is load dependent, I've seen it on X3 G01. Also another one: 6. How can i make the fog lights turn on when unlocking the car ? |
03-06-2022, 06:21 PM | #394 |
Rep 10
03-07-2022, 10:58 PM | #395 | |
Rep 8,364
2. PIA_DEFAULT_TIPPBLINKEN_AB_2018 3. Attaching steps for Remote control park. Remote start may have something similar. |
03-08-2022, 05:12 AM | #396 | |
Rep 10
3. There is nothing written about coding, only to use ista, is there any tutorial with the lines I need to modify? I'm only using bimmercode for now. Thank you very much for your help and patience! |
