      12-02-2020, 05:41 PM   #67
ApFiore
Drives: 2013 F01 Msport
Originally Posted by ApFiore View Post
Downpipes went in last night. Haven't had a whole lot of drive time yet but it is definitely quite a bit more powerful. Traction control kicking in big time which was hard to do before. I was very surprised that there was next to no sound increase after adding DPs. Going to remove resonators on Monday.
I'll do some draggy pulls next week once my new tires go on. It's def not a sports car but highway rocket for sure.
When you did the stage 2 tune did they know you were installing the new catless down pipes? They told me if I installed them on the standard stage 1 or 2 tune the car would throw codes. Just wondering if when they installed the stage 2 tune they disabled the offending codes?? I have the stage 2 tune on order (not installed yet) and have the downpipes.
Stage 2 is only for cars with Catless DP. It's basically a more aggressive version of stage 1 because of less restrictive exhaust
Shouldn't be any codes if you install stage 1 then later do the DPs but you'll be leaving a bit of power on the table running stage 1 with DPs. Def don't run stage 2 without catless DPs.
      12-02-2020, 07:32 PM   #68
13M5F10
Hide! My wife's coming!
13M5F10's Avatar
Drives: 2013 BMW M5 | MSR Stage 3
Originally Posted by jlin101 View Post
Originally Posted by 13M5F10 View Post
I ran roughly 3.5-4 gallons in my tuned M5 and did it a few times in the 7. It did respond fairly well. I was told you have to do it in stages. Start with 1-2 gallons and increase to 3.5-4. Let the car adapt to the changes.
Mo from DME Tuning suggested adding 1-2 gal of E85 to each full tank of gas, is that just to increase the octane count?
Yeah! E85 has an octane rating of 108 octane so adding that with 93 will bump it up theoretically assuming you're getting quality gas.
      12-02-2020, 10:02 PM   #69
jlin101
Drives: 2018 X3 M40i, 2016 750i
the only 93 octane gas near me (Cenex brand) contains 10% ethanol, is that acceptable for 93-tunes?
      12-03-2020, 12:20 AM   #70
ApFiore
That's odd to hear because when I asked him last week about e85 he strongly recommended I stay away. I'll have to reach back out and get clarification
      12-03-2020, 07:26 AM   #71
jlin101
Perhaps he meant not using e85 straight?
      12-03-2020, 08:26 AM   #72
13M5F10
13M5F10's Avatar
Yeah you'll be fine. It's taken into consideration.
      12-05-2020, 01:58 PM   #73
jlin101
Mo from DME Tuning did Stage 1 on my '16 750 this am. The process was smooth and the car is indeed much livelier, with a definite shove in the back (did not even try full throttle).
      12-05-2020, 07:14 PM   #74
ApFiore
Don't forget to turn off dtc to actually use that new power! It's a blast
      12-05-2020, 10:23 PM   #75
jlin101
What is DTC?
      12-05-2020, 10:31 PM   #76
ApFiore
What is DTC?
Traction control. Hold the button down for a few seconds and it'll switch fully off. Def allows the car to actually use the new power. Nannies kick in and kill quite a bit of power when any wheel slip is sensed
      01-05-2021, 01:28 PM   #77
ApFiore
Anyone know what a stock m760 or B7 runs 60-130?
I'm
Going to do some draggy runs and wanna see how I stack up. I just ran a 10.06 but pretty sure I can get into the 9s
      01-06-2021, 07:25 PM   #78
13M5F10
13M5F10's Avatar
I'm
Check under M760
https://fastestlaps.com/makes/bmw
      01-07-2021, 06:21 PM   #79
ApFiore
I'm
Check under M760
Unfortunately no 60-130 times
