      01-21-2020, 05:32 AM   #309
RaptorStrike
Drives: 320i Sport Touring
Originally Posted by jlin101 View Post
Does the seat/steering wheel heating automatically turn off after a set time?
On mine it seems to stay active. Although the display on the AC shows three bars (as that's what I have it set at)
It does seem to allow itself to cool and then heat up again.
Steering wheel is the same.
I think you would need to check in the coding what the threshold is for the seat to switch off at. I think it's circa 34oC as standard. But could be wrong.
      01-21-2020, 09:48 AM   #310
bigmac f02+g12
bigmac f02+g12's Avatar
Drives: 17f15,18G12
Mine does not
BM
      01-22-2020, 09:58 AM   #311
Qsilver7
Qsilver7's Avatar
Nope...it stays on until you turn it off manually...or shut the car down. It keeps the steering wheel at approx 36° C (96.8° F):
      01-22-2020, 04:02 PM   #312
jlin101
Drives: 2018 X3 M40i, 2016 750i
good info, so I infer that the seat/steering temp is maintained while the heating element is modulated (on/off until deactivated).
      01-23-2020, 01:33 PM   #313
bigmac f02+g12
Drives: 17f15,18G12
Does anyone know of or have a cheat sheet for coding a 7 series ?
BM
      01-23-2020, 10:33 PM   #314
RaptorStrike
I'm still wondering if this is possible.
Originally Posted by RaptorStrike View Post
I'm pretty sure the answer to this will be no. However I'll ask anyway just incase it's possible.
I like the standard dash layout of Comfort/Adaptive on the digital cockpit.
I also like the way sport mode is on the Alpina display.
I've coded my car to have the Alpina dash layout. But went back to normal as wasn't overly enamoured about the standard dash layout.
Is there a way to keep the normal dash layout and code just Sport/Sport individual to have the Alpina style layout?
Or is only a case of either all standard or all Alpina.
Thanks.
      01-24-2020, 10:13 AM   #315
Qsilver7
Qsilver7's Avatar
To answer your question "broadly"...the answer is yes. Just a simple google/internet search using "BMW coding cheat sheet" will give you lots of results.
But is you want more specificity...if you give more as to what you're looking for and what method you plan to use (ie software/hardware...or an app, etc)...you may get better recommendations and suggestions from the forum.
      01-25-2020, 03:47 AM   #316
emerza
Drives: 2024 BMW X5 Xdrive40i
Ive been searching but cant find it. Anyone know how I could code my car with keeping the fogs on along with the parking lights? I currently use bimmercode and couldn't find it in there.
      01-25-2020, 08:51 AM   #317
bigmac f02+g12
Drives: 17f15,18G12
Using bimmercode app was looking vld and possibly auto high beams and extend camera range or if I could get them to stay on have that coded on my f02 and I luv it and it comes in handy
BM
      01-27-2020, 08:53 PM   #318
Wonks20
Drives: 2017 Bmw i3 Rex & 2019 750i M
Is it possible to increase the brightness of the angel lights and ambient light inside the car? Can't seem to find anything in bimmercode might be in expert mode?
      01-28-2020, 06:56 PM   #319
jlin101
My '18 X3 has a compass in the instrument cluster (where one sees the odometer/mpg/mph) which my '16 750. After examining the coding in the X3, I tried to enable the compass display using Bimmercode. In KOMBI2, change the following parameters from Inactive to Active to match the X3:
3000 Anzeige Konfiguration/CB KOMPASS
3000 Anzeige Konfiguration/CB KOMPASS ENABLE
3007 Pia Einheiten/PIA KOMPASS
3007 Pia Einheiten/PIA KOMPASS PORTIERUNG
Immediately upon successful coding, the compass did appear in the on-board computer; but after exiting diagnostic mode and restarting the car, the compass disappeared. Any thoughts?
      01-28-2020, 07:00 PM   #320
jlin101
ambient lighting intensity adjustment is in I-Drive setting under LIGHTING/INTERIOR (where one selects the color).
      01-28-2020, 07:19 PM   #321
M6BMWDriver
M6BMWDriver's Avatar
Drives: F12 Singapore Gray M6 Conv
In the HU head unit there is a setting as well for Kompass. Also, try to look for Compass
      01-28-2020, 08:17 PM   #322
Wonks20
I saw it thank you.
Trying to figure out to see if I can make the apple carplay full screen.
Screen mirroring seemed like it didn't work cause i have an iPhone.
      01-28-2020, 09:48 PM   #323
M6BMWDriver
I saw it thank you.
Apple carplay can only be activated by FSC code. Have a look at this, go to ebay.com then look for item number 254126008338
They got mine to full screen
      01-28-2020, 10:28 PM   #324
Wonks20
There is someone selling it for $20 will there be a difference?
Item # 333388687735
      01-28-2020, 10:48 PM   #325
M6BMWDriver
Item # 333388687735
Item # 333388687735
Depending on your nav version. So check your Nav Version in your iDrive
This item is only for 3 different map version using a USB
But some iDrive Map version will require you to have OBD cable and a laptop to do update it.
      02-04-2020, 07:06 PM   #326
M6BMWDriver
Does anyone knows where in e-sys i can code 2019 750 Ambient light brightness to be brighter
Also change the emblem of the curtain lights to M
Thank you
      02-05-2020, 03:03 PM   #327
Wonks20
Thank you
In the idrive setting there is an option to increase or decrease the ambient light brightness... mine is already maxed out you can code it to make it extra brighter??
      02-05-2020, 03:37 PM   #328
M6BMWDriver
Thank you
That's what I'm trying do is to code it for additional brightness
      02-05-2020, 03:56 PM   #329
Wonks20
I didn't code mine it was already in the idrive.
      02-05-2020, 03:59 PM   #330
M6BMWDriver
I understand that
We all have it in the iDrive
However, the LED can be even brighter by code
