      05-12-2021, 11:14 PM   #23
Mnsnutn
Mnsnutn's Avatar
Drives: BMW M760i, Audi S8
Originally Posted by LuckyW View Post
My setup for suspension by software made by myself, if someone is interested in helping, I will provide advice at NO COST !!! (the requirements are ista's own diagnostic program and the enet cable + measure tape)
Because it is a forum to help each other, not to monetize others seeking help "mrgicm" Filip
"Regarding lowering the car, I can do it remotley. All you need is a Windows Laptop with internet connection and a enet cable.
Car can be lowered as much as you like but my suggestion is a 2cm drop as that is optimum for looks and keeping the ride comfort. Price for remote lowering is 200eur.
Please let me know if you have any questions
Best regards,
Filip" - mrgicm
Sport and Comfort
Hello — how much did you lower the vehicle in comfort mode?
      05-12-2021, 11:33 PM   #24
13M5F10
Hide! My wife's coming!
13M5F10's Avatar
Drives: 2013 BMW M5 | MSR Stage 3
Best regards,
Filip" - [COLOR="Red"]mrgicm
[/COLOR]
Sport and Comfort
1" drop for me was perfect.
      05-14-2021, 02:07 PM   #25
LuckyW
LuckyW's Avatar
86
Drives: BMW 520d M Sport
My setup is -
  • F- 670mm and R- 660mm / Comfort
  • F- 645mm and 640mm / Sport
Strongly recommends that the sport is not for jumping on curbs or dynamic rides on road slowdowns
These are the initial values ​​after measuring on the wheels at the moment, a few different trials and settings from which the current one suits me best ...
      05-23-2021, 11:36 AM   #26
LuckyW
LuckyW's Avatar
86
Of course, we start the sessions with a full car scan of all possible errors. (Complete Identification)
If you don't understand this manual, don't go for it or you'll screw it up
      05-23-2021, 12:02 PM   #27
LuckyW
LuckyW's Avatar
86
Measuring the lower edge of the rim with the upper edge of the wheel arch, we give the measure in millimeters.
68cm equals 680mm + the value by which we want the car to lower 20mm = 700mm
According to your preferences and needs
      06-12-2021, 10:13 PM   #28
double trouble
Drives: E60 m5
Originally Posted by mrgicm View Post
PM sent.
Hey, I saw you had some knowledge on lowering g12 via software. Would you be able to help me/send me a link to the software?
Thanks,
Ben
      02-27-2022, 11:34 PM   #29
TXSTYLE
"Salud"
TXSTYLE's Avatar
Subed....
      03-02-2022, 03:20 PM   #30
jimmyvonvitti
Drives: BMW 740i G11
I need someone who can lower my G11 for me.
I can't reach mricgm.
      03-02-2022, 11:03 PM   #31
E92TTCoupe
Drives: x335i/x550i/x640i/x540i/c750i
Honestly, links are the way to go..
      03-06-2022, 05:46 PM   #32
jimmyvonvitti
Hey I already have links installed. The car drives lowered but it raises back up high when in park.
I wanna have it lowered another inch and code it to sit low when in park.
      03-07-2023, 01:35 PM   #33
Alex_Karmo
Drives: BMW G12 2017
Where I can find info about stock height for G12 2017 740Li?
      03-10-2023, 05:40 PM   #34
Kirill_Nezd
Senior Technician
Kirill_Nezd's Avatar
10
Drives: BMW X5
I can do it
      03-11-2023, 09:24 AM   #35
bmwag459
Drives: BMW
Hello the option greyed on mine if i just the vin number to look if it‘s possible but if i connect the will it change because it‘s not my car
      03-12-2023, 11:07 AM   #36
Alex_Karmo
No one knows stock ride height for bmw g12 2017 740 Li?
Maybe there is info in service guides?
I try to find any info, but there is not any of it.
      03-12-2023, 01:26 PM   #37
Raimo5
Drives: BMW 740d xDrive (G11)
I assume you refer to ABL action in ISTA? If yes, then that is correct behavior. Most ABL's are greyed out when vehicle is not connected as they require connection. Once the car is properly connected and identified then it will become usable.
Stock ride height is what you end up after entering correct rim size and current height into ISTA process and the car does the corrections. Doesn't seems to be one single set value.
      03-12-2023, 03:04 PM   #38
Alex_Karmo
Yes. But I've got right now different numbers on my front left and right sides. After replacement Shock Absorber on left side. So I want to know stock numbers to use them.
      04-12-2023, 08:55 PM   #39
tonydt1g3r
Drives: F83
Its been a while since I have used a computer to program anything up on a BMW, but I used code/program the car with esys I would do it with the car on. But I think from what I am reading ISTA+ is done with the car off? And I need a charger now? Any suggestions for a charger to buy?
Also I have a 2021 745e so technically I can have it plugged into the wall charger? Not sure if this helps
      04-15-2023, 03:37 PM   #40
Raimo5
With ISTA, you can also do most service functions with engine running. If ISTA requires change of state, then it will do so automatically by issuing a command to the car.
Standard charger wont be able to keep up with power demands of G11. You will need a power supply and I would recommend at least a 70 amp one. I have seen power draw of up to 57A when programming my fully loaded G11. The power supply's are very expensive from established manufacturers like Exide, Deutronic, CTek and so on. You can also build one yourself from server PSU if you feel adventurous or buy a cheap but good and proven one like MST-80/90+ from AliExpress for as low as €350.
Low and high voltage system are isolated as far as I know so plugging in your hybrid charger wont help you.
      04-16-2023, 08:52 PM   #41
tonydt1g3r
Drives: F83
wow I read this a little late. I ended up using a CTEK 7200 that only had 7 amps. I guess I got lucky because it took me about 3 hours to dial in the exact height I wanted. Welp I guess I wont be using ISTA again without a power supply. Thanks for the warning tho.
      05-13-2023, 08:26 AM   #42
asci01
Drives: 2020 750I xDrive loaded
By the way, the reason for adding height to the reading is that the "altered information makes the suspension computer think the car is sitting higher than it is which has the effect of lowering the car"
      07-04-2023, 02:52 PM   #43
Ajay33
Drives: G12
Heeey
Looking for suggestions for my problem.
I have G12, previous owner had shock aborber replacement ( i dont know if they need to be coded and if he did this )
I tried get heigh throught ista to 67cm. but car got dropped to 64cm and not going back.
should i try to reset module? or drive more ?
      07-27-2023, 02:33 PM   #44
MTornberg
Drives: BMW G11 LCI 740 d M-Sport xD
Hello guys,
My G11 is already lowered with ISTA+.
But my question is if anyone has found the coding for height in sport mode?
My car lowers itself about 10 mm in sport mode. I would be stoked if it was possible to code it to lower about 20mm instead. So I can go low on demand..
Anyone with ideas?
There is a height offset in Sport mode, we just need to find it.
