07-25-2021, 04:05 PM | #178 |
Rep 33
Hey, lowered my G11 today using ISTA+ and my stock height measurements in sport were as follows:
26.5 inches Front (673mm) 26 inches Rear (660mm) Hope that helps! Also, I lowered my G11 by 30mm in the front and 25mm in the rear, thinking it might be too much since on my test drive I found that it was far less comfortable, does anyone know if its possible to lower the sport and comfort driving modes separately? I'd like to keep comfort and comfort plus at stock ride height but sport lowered if possible. |
07-26-2021, 04:01 PM | #179 | |
Rep 1,493
I truly appreciate that, thank you. |
07-29-2021, 05:02 PM | #180 | |
Rep 1
and if yes, how to ? |
07-29-2021, 05:49 PM | #181 | ||
Hide! My wife's coming!
812
Rep 2,816
07-30-2021, 12:47 PM | #182 |
Rep 204
07-30-2021, 02:52 PM | #183 |
Rep 204
Measure the current height 4 wheels follow ista requests exactly and bring it to ista without adding or subtracting, the suspension will be set to OEM
08-10-2021, 04:13 PM | #184 | |
Rep 56
08-18-2021, 02:24 PM | #185 |
Barge driver
8656
Rep 12,425
Not lowering but I wonder about the whether M760li has firmer damper/air spring settings and whether you could code it to a normal 7 if if the hardware is shared?
730d/Z4C
08-18-2021, 03:32 PM | #186 |
Rep 891
M760i has different suspension that is slightly higher when you you compare it (shock absorber next to the other). I have mounted the 760Li suspension on my car (and coded ofcourse) and the difference is barely noticable to almost none compared to a normal suspension.)
Wills28656.00 |
08-18-2021, 03:50 PM | #187 | |
Barge driver
8656
Rep 12,425
730d/Z4C
12-03-2021, 04:04 PM | #188 |
Rep 5
12-05-2021, 07:25 AM | #189 |
Rep 204
You can easily to do this yourself, follow this instruction...
https://www.7post.com/forums/showpos...&postcount=164 |
12-05-2021, 08:44 PM | #190 | |
Rep 5
12-06-2021, 12:06 AM | #191 |
Rep 8
10-31-2022, 02:32 PM | #193 |
Rep 9
ride height
Hi All
I managed to sort this out with ista and a KDCAN. IF anyone need help with this in the Middle east as I live in Dubai i can help you out. thanks Steven |
03-15-2023, 01:06 PM | #194 |
Rep 1
Hey guys this forum has been such a help. Recently go a 740e and needed to minimise that wheel gap. Was never looking to slam the car, but definitely needed lowering. I went down the road of airmatic drop links as no one around me bar an hour drive dealt with coding. The links definitely were a pain in the ass to get a level ride, but for some reason the mechanic said the stock heights were all over the place to begin with.
Anyway here’s what the final product (having to return twice for readjustments) looks like. I’m very happy with it and can not tell a difference between the stock drive quality. ( worth noting when it was sitting lower than this by error, the car definitely felt worse to drive and quite kitty/unstable on the suspension). This isn’t a technical measurement but from the top of the rim/alloy to the wheels well is 4 inches all around in sport. 4.5 in comfort. |
05-15-2023, 12:32 AM | #197 |
Rep 188
Drives: BMW X5 and BMW 7 Series
Also I believe with the Air Suspension in Spoet Mode at Speeds at 70+ MPH The car will Automatically Lower. But once you slow down anything under 70 it will automatically Raise back up.
Danyal.N55
05-15-2023, 11:25 AM | #198 | |
Rep 388
Toggling Sport mode will lower the car in any driving speed and there is no switchover at high speed regime as car is already at its lowest setting. |
