      11-01-2022, 08:40 PM   #1
inque1
Drives: 2016 740i
Bowers & Wilkins
Does anyone know how to add the Bowers & Wilkins tone with Bimmercode?
Thanks in advance.
      11-01-2022, 09:57 PM   #2
F82 in QC
F82 in QC's Avatar
Drives: BMW M4,BMW 750iX
Tried and I think it's not possible
      11-02-2022, 07:21 PM   #3
inque1
Drives: 2016 740i
Found it. Coded with no issues . Instructions below:
1. Go to HeadUnit (HU_NBT2) in Bimmercode
2. Click "Expert" and accept that you are going to cause the next pandemic.
3a. Under 3000_HMI. Go to HIGH_END_AUDIO_B_UND_W. Change from "Kein_Menue" to "Volle_insz".
3b. Under 3000_HMI. Go to HIGH_END_AUDIO_MENUE. Change from "Kein_Menue" to "Volle_insz".
4a. Switch to 300B_Touch_Command. Go to TC_HIGH_END_AUDIO_B_UND_W. Change from "Kein_Menue" to "Volle_insz".
5. Press CODE.
      11-03-2022, 12:32 AM   #4
Ironrose
Drives: BMW M760Li
A naive question. Is this for cars without the B&w setup.
How does it work without the relevant B&W hardware e.g. speakers, amp, head unit etc
      11-03-2022, 09:10 AM   #5
F82 in QC
F82 in QC's Avatar
5. Press CODE.
will try it out thanks.
      11-03-2022, 09:12 AM   #6
F82 in QC
F82 in QC's Avatar
some people say HK setup sounds a little better with BW tone i dont mind of the sound but the reason for me is I have retrofited BW led speaker covers
      11-03-2022, 10:16 PM   #7
inque1
Drives: 2016 740i
I think it sounds richer, but the difference is not that significant. I like the B&W concert mode. The downside of the B&W coding is that you lose the speed volume control (the option that increases/decreases sound based upon car speed).
      11-04-2022, 09:42 AM   #8
Opie55
Drives: '15 650i Convertible
5. Press CODE.
I have Bimmercode but have never used expert mode because it might as well be in Swahili. Then I see posts like this. How on earth did you know that "Volle insz" was what you were looking for?
      11-04-2022, 01:54 PM   #9
inque1
Drives: 2016 740i
I don't speak German either. But it helps that there are 1000's of other people on this forum that have used these codes successfully without any issues.
      11-04-2022, 02:14 PM   #10
Opie55
Totally agree - up to a point. If I'm looking for a very specific change that I know or suspect exists, I can search for it on the forums. Or if I stumble on a thread like this, I learn something new. But mostly I don't know what is possible, so I can't peruse my options or know what to search for. I've been hoping the developer would make expert mode look like regular mode, or some kind soul would create a cheat sheet. But I've not seen that, if it exists.
      11-05-2022, 05:56 AM   #11
peteinpa
Albania
396
Drives: 2013 535xi
Does anyone know if the B&W tone can be coded into a car with hi-fi? I have a g30 with bimmertech DSP Amp. Have to plug into the amp in the trunk to play with eq settings. Sure would be nice to do so from the IDrive in the cabin.
Tags
bimmercode, bowers and wilkins
