10-28-2021, 08:10 AM | #1 |
Rep 42
Finally got my G11 745e M Sport
After much waiting...
It's here.
After 300 miles of ownership, I've done ~250 miles on EV and ~50 on ICE. There are some quarks and features worth a note:
You all know what these cars look like, but I've posted some pics just because. And you can see the before/after of my installation of a small post and hook to keep the cable out the way. Other than that, it's great. Smooth, tidy, quick, quiet and elegant. |
10-30-2021, 07:02 PM | #6 | |
Rep 839
It's a beauty enjoy it!
10-31-2021, 03:52 AM | #7 | |
Rep 42
My colleague was surprised it wasn't bigger, but it's fine for my needs. The folding floor bit in the 745 is a bit of a faff and takes some getting used to. I have it down all the time as it's handy to have sort small bits of shopping etc. stops it all rolling around. Last edited by psyrd; 11-01-2021 at 10:49 AM.. |
10-31-2021, 03:55 AM | #8 | |
Rep 42
For those that don't know it's black until you get around 6ft from it then goes a deep metallic blue. It's just off black enough to bring out the black trim and just blue enough to bring out the blue in the brake callipers. |
Zodiac46.00 |
10-31-2021, 06:23 AM | #9 |
Barge driver
8656
Rep 12,425
Looks great, I like the Carbon/Ruby/Citrine blacks that BMW do, nice colours.
In terms the head rest issue you have, ideally your head shouldn't be on the head restraint if you're sat with good posture. As it's a head restraint (in the event of an accident) not a rest, however if you want to bring it closer so you can rest your head on it then use the split back rest adjustment and you'll solve the issue. (that's what I've done). On the air suspension button the tell tale is the green LED, press it once and it raises 20mm at speeds up to 25mph (flashing whilst it does it), press it again to return, above 25mph it will lower automatically. Selecting sport mode will lower the suspension 10mm, automatically over 87mph it lowers 10mm in the other modes.
730d/Z4C
10-31-2021, 06:32 AM | #10 | |
Rep 42
Yes the headrest thing is more of an observation - the Jag XF was just a bit closer. And the air suspension button - I've read up on the docs and understand it all, just seems odd that it's not present in the software to view status especially if it's prone to overheating! |
10-31-2021, 12:58 PM | #11 |
Rep 79
What Jaguar XF did you have ? That’s what I had too prior to buying the 7 . Before that had an XJ.I settled on the 740e and like it but sometimes miss the 6 cylinder I had on the Jag. Will look at a 745e when they drop in price a bit .
11-01-2021, 02:46 AM | #12 | |
Rep 42
I was trying to hold out for the new fully elec XJ before making a final decision, then the pandemic hit, the new XJ got cancelled so I jumped to BMW. I looked at the 740, but found a stunning offer on a 745… did the side by side and went for it. Thus far the ev driving is perfect for me. That XF was the only diesel I've ever had and ever will have. Phev or ev from now on! |
11-02-2021, 12:08 PM | #14 | |
Rep 42
It's also important that it conveys business and personal "success" while not saying "I'm/we're over charging you". That's very important in my line of work. |
willin11161.50 |
11-04-2021, 10:23 AM | #15 |
Rep 208
Do a ceramic coating on that carbon black. So so so easy to get it scratched and it will cost you lots to repair.
G11 740xd M Performance
F16 X6 M50D F21 140xi Dark Side: E53 AMG |
11-04-2021, 04:32 PM | #16 |
Rep 42
11-04-2021, 06:52 PM | #17 |
Rep 18
Was this on ethanol? I have been wondering what one of these would run modified. Thats fast for this big girl. I think I saw someone say their m760 with a tune ran a 8.8 60-130 which would mean that stage 2 745 isn't much slower.
11-05-2021, 02:55 PM | #18 |
Rep 891
No ethanol, normal pump fuel 93 OCT (98RON). It was a rwd drive car not Xdrive.
11-13-2021, 02:14 PM | #19 | |
Rep 89
11-16-2021, 08:54 AM | #20 |
Rep 283
A quick question on the 745e. What happens if you go on a long highway trip without using navigation? Does the car drain the battery while driving on the highway effectively draining the battery during the early stages of the trip and you are left with the ICE engine for the remainder of the trip without any battery assist for acceleration? I know the i8 has a battery hold feature, but that is a pointless solution or does the car stop using battery power, if you are driving over a certain speed (say 75 mph) to conserve it for local driving?
11-16-2021, 11:26 AM | #21 | |
Rep 42
But in the real world... it depends on the engine mode. On Sport the battery is used to fill in turbo lag and top up the bhp, so if you're booting it it'll drain fairly quickly. I've never been in sports mode long enough to do this because... it's a 7 series and that's not really what it's for. In Hybrid mode I find it uses the battery when below 60 ish on the highway, when semi-coasting and stop/start traffic etc. It does a pretty good job of figuring out what to use: ICE vs EV. It's not yet killed the battery mid journey. The re-gen is good too and even then the battery is 0% it always seems to find enough for a short period on battery (parking up, getting into your village etc)... it's never truly drained. If you do lots of short trips, sub 20/30 miles return and plug it in daily/nightly the 745e is PERFECT. It's the best of all worlds: clean, quiet, cheap and the ICE is fun and quick when needed. If you do lots of longer runs, it's the worst of all worlds: 45 lt tank has a tiny range, the B58 block is thirsty and the EV range is tiny. |
11-16-2021, 01:35 PM | #22 | |
Rep 283
