03-18-2023, 03:29 AM | #1 |
Rep 88
Sunroof Creaking sounds
Got a 2017 G11 750i, and as of recently, there has been an INSANE creak when hitting bumps or dips coming from the rear Panoramic sunroof.
Imagine an old door or chair creaking when moving and it’s so hard to locate the exact sound but it’s basically behind the driver seat close to the mirror. Any one else have issues with this or have any tips on what I can do? It seems like the glass is rubbing against something but I can’t find out what to do. Would appreciate any feedback! |
03-18-2023, 10:33 PM | #2 |
Rep 829
Hard to say from your description, but Gummi Pflege applied to the sunroof gasket may address your sunroof noise...
Gummi Plege is the product BMW dealerships will use to recondition rubber gaskets and body seals. If this doesn't address it, your sunroof rails may require lubrication.... |
akataka23.00 |
03-19-2023, 03:57 AM | #3 | |
Rep 88
03-30-2023, 09:10 PM | #4 | |
Rep 8
http://https://bmwtechinfo.bmwgroup.com/sib_attachments/B540417_Repair%20Instructions%20for%20G12%20Sunroo f%20Noise.pdf |
Mnotfeelingit19.00 akataka23.00 |
03-31-2023, 04:37 AM | #5 | |
Rep 88
04-01-2023, 10:55 AM | #6 |
Rep 4
You need to drop the headliner and tighten panoramic roof bolts. I had that issue and it was one damn bolt that was causing it . On every pot hole , bump and even sharp turn I could hear that creaking .
Mnotfeelingit19.00 |
04-09-2023, 07:20 PM | #7 |
Rep 88
How difficult is it to drop the headliner? Preferred by a dealer ?
04-10-2023, 02:54 PM | #8 |
Rep 874
Should be easy. I had them fixed some creaking and they forgot to reconnect back the skylounge led. I dropped the car back and they fixed it in about an hr later. It didn't look like they needed to drop the entire headliner but figured it's not as hard as we might think.
04-24-2023, 01:11 AM | #9 |
Rep 552
wasn't there a TSB about this? I brought in my 2019 and they told me that there was a recall or something for a creaking roof and fixed it for me. I didn't even realize it was an issue
04-24-2023, 06:18 PM | #10 |
Rep 88
Do you have any paperwork or anything regarding it that I could use as a reference at my local dealer ? Would be much appreciated, I figured there would be something cause this is a common thing.
04-24-2023, 07:10 PM | #11 | |
Rep 552
04-25-2023, 03:18 AM | #12 | |
Rep 88
04-25-2023, 06:29 PM | #13 |
Rep 552
not sure tbh. it is a TSB so I want to say yes?
05-01-2023, 03:30 PM | #14 |
Rep 45
I had that issue and found the culprit on mine.
In the rear where the headliner has a front facing bump there are 3 bolts holding the sunroof down. Some white lithium grease on those bolts resolved the issue for me. Good luck |
06-19-2023, 01:36 AM | #15 |
Rep 12
Drives: 2017 BMW 750i (G12)
Can anyone help me with getting instructions on how to remove the headliner? I have the same issue and the dealership is not willing to provide instructions so I can tackle this myself. Thank you in advance.
06-19-2023, 10:19 PM | #17 |
Rep 829
TIS directions attached....but be careful, a crease in the headliner is permanent.
Zefjan1419854.50 |
06-19-2023, 10:55 PM | #18 |
Rep 12
06-19-2023, 11:06 PM | #19 | |
Rep 829
You will NOT be happy with a crease in your headliner....once the foam backing is crushed by a crease, it cannot be fixed, and it will want to crease at the sunroof area where headliner is less stiff. Last edited by M_Bimmer; 06-21-2023 at 11:31 PM.. |
Zefjan1419854.50 |
06-26-2023, 01:27 AM | #20 |
Rep 45
right under this little bump circled in blue, there are 3 bolts towards the back. grease those.
Zefjan1419854.50 |
06-26-2023, 11:44 AM | #21 |
Rep 4
Just remove B-pillar, C-pillar, holly shit handles and the lights and you will be able to drop the liner. There are couple of bolts that you need to tighten.
Zefjan1419854.50 |
07-16-2023, 05:48 PM | #22 |
Rep 12
I was able to grease the 3 bolts with lithium and tighten the middle one only. No luck, really trying to avoid removing the headliner but it’s looking like I have to.
