04-19-2023, 10:01 AM | #2 |
Rep 388
OEM - 61612408631
Bosch - 3397007309 Valeo - 577849 Bosch and Valeo codes may differ by region but you can find suitable ones by OEM code search. Also, these are direct fit blades, but there are other suitable ones from same manufacturers with adapters for fitting. I always prefer direct fit as it looks cleaner. I change my blades at least once a year. Usually after summer when sun is done baking the heck out of the rubber and I need a good set for rainy period. |
Mnotfeelingit19.00 |
04-19-2023, 05:37 PM | #3 | |
Rep 88
Are these an easy replacement? Basically a "plug n play"? |
04-19-2023, 06:46 PM | #4 |
Rep 388
Replacement is very easy. Just pinch the locking tab on the upper side and slide out the blade. Then just slide in and push on the new blades until the locking tab clicks in place.
If your blades are old then chances are that there are all sorts of road garbage between the surfaces that slide. It might make removal of old blades a bit more difficult so you might have to jiggle them out. You can use some anti seize to make life easier and do less friction damage. Once that is done, just clean the surfaces and it will be smooth saling from there on. Last edited by Raimo5; 04-19-2023 at 07:02 PM.. |
04-19-2023, 09:10 PM | #5 | |
Rep 88
Raimo5183.00 |
04-20-2023, 11:19 PM | #6 | |
Rep 88
04-21-2023, 05:14 AM | #7 | |
Rep 388
Apply few squirts of windshield washer fluid before you move them so you dont run wipers dry and scratch the windshield. |
04-21-2023, 05:49 AM | #8 | |
Rep 88
04-21-2023, 09:14 AM | #9 | |
Rep 7,480
04-21-2023, 01:57 PM | #10 | |
Rep 88
04-21-2023, 02:31 PM | #11 | |
Rep 388
04-23-2023, 10:52 PM | #12 |
Rep 874
Sorry if I had to repeat this part - keep holding down the stalk until the wipers stop at their service (vertical) position.
This process is very easy. Takes less than 5 mins total. Good luck! |
04-24-2023, 06:17 PM | #13 |
Rep 88
For some reason I’ve been holding it without the car fully being “on” and still nothing, just keeps moving back and forth, do I have to hold it down for a few mins?
04-24-2023, 08:22 PM | #14 |
Rep 388
That means you are in residing state, not parking. Parking state is when you first enter the vehicle and haven't pushed start/stop button yet, or when you end a drive and press start/stop button to finish.
04-25-2023, 03:19 AM | #15 |
Rep 88
04-25-2023, 07:03 AM | #16 |
Rep 388
04-25-2023, 05:52 PM | #17 | |
Rep 7,480
Examples…the 1st pic is from the f06 6 series & the 2nd pic is from the g05 X5…the position of the stalk to move the wiper blades into the fold out position are different: Do a keyword search for “WIPERS”…or perhaps “FOLD OUT” in the iDrive owners manual.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 04-25-2023 at 06:05 PM.. |
