01-19-2020, 02:40 PM | #23 | |
Rep 1,434
2022 x5 m50i - Dravit grey
2005 evo 8 (current) built 2.3 488/409 mustang dyno Old stable mates - 87 325i, 88 m3, 90 m3, 97 m3 4dr, 04 325xi, 91 gmc Syclone, 08 335xi, and 13 x3 35i msp 2014 x5 50i msport Last edited by CT335xi; 01-29-2020 at 04:40 PM.. |
01-19-2020, 05:59 PM | #24 | |
Rep 2,350
01-20-2020, 12:39 AM | #25 |
Rep 334
01-20-2020, 02:08 AM | #26 | |
Chelsea Football Club
345
Rep 780
Just like any BMW, what becomes the maintenance nightmare is all the components around the block that would fail - the electric water pump, the HPFP, the gaskets, the brittle plastics etc. |
01-20-2020, 02:28 PM | #28 |
Rep 1,643
I'm right behind you at 150k! It's been hell lol
2007 E92 335i MT
01-20-2020, 06:51 PM | #29 |
Rep 890
Speaking of gaskets, b58 uses RTV instead of conventional rubber gaskets on many sealing surfaces. This is also claimed to improve the reliability. Whether this is going to be the case remains to be seen, however. Although, at least in my experience, good RTV seems to hold up a lot better than rubber gasket presumably made out of recycled rubber. Too bad Zupra hyped up the B58 motor and a lot of “tuners” will likely start buying 340is with this motor “cause it got Supra engine, bro”. B58 most likely won’t stay a hidden gem like the n54
01-20-2020, 07:18 PM | #30 | |
Rep 556
Drives: 2020 Z4 M40i
No. While I'm sure you can get the UK spec engine to produce as much or more power than the non-UK version, they are different engines. The UK version is a B58B30M1 whereas the "non UK" market uses the B58B30O1. a related article (the Supra uses the B58B30M1); Why the Toyota Supra Makes Less Power Than the BMW Z4 The engines are nearly equal, but not equal enough. The Toyota Supra shares a platform and a large majority of its components with the BMW Z4. But as we discovered last summer and recently confirmed, the Z4 will make 47 more horsepower than the Supra in top trim. Since ECU tuning has become so advanced with modern engines, the automatic response might be to think that it is all in the programming. A BMW parts catalog reveals that the changes go further than the code. According to the BMW ETK catalog, the US variant of the Supra will be equipped with the B58B30C engine. It carries part number 11002463592, and seems very similar to the engine for the US-spec Z4 M40i. However, the Z4 engine is actually the B38B30B, and has part number 11002464415. What does that mean? There are internal differences. Searching the interchanges for the two part numbers shows that the US Supra engine is the same as what Europeans will see in their variant of the Z4 M40i, while the US M40i engine will be used in the new G20 M340i 3-series. Digging into the motors reveals that the first different part is the cylinder head. The Z4 has a cylinder head part number of 11127934495 while the unit in the Supra is marked as 11127934494. The differences are not apparent based on the catalog illustration, and instead are likely to be in the castings of the cylinder heads as both use the same exact camshafts, valves, and ancillary components. Moving to the bottom end, both engines use the same crankshaft and bearings, but the pistons and connecting rods are different. The Z4 piston–part number 11258678934–is found in a variety of BMW products including the US M340i and European spec 7-series sedans. The Supra piston–part number 11258681079–is found in the motor for the US spec 7-series and the X7. Based on the catalog entries, basically every other component seems to be the same. The final difference appears to be in the turbocharger. The Z4 uses part number 11657934387, which is only shared with the M340i, while the Supra uses part number 11657934332, which is only shared with the Euro-spec Z4 M40i. Even though the turbocharger appears to be different, all of the clamps and mounting hardware are the same between the two. Even though the unit on the Z4 might have bigger wheels in it, there is a good chance that it should bolt right up to the Supra. The hardware for the ECU is even the same; the two cars share the 86T0 DME. After looking at the parts, it doesn't look to be very hard to replicate the power of the M40i in the Supra. For those that want to make an OEM equivalent, the primary components to change will be the pistons and rods as those are likely built to withstand a little more boost. Swapping the cylinder head and turbocharger would complete the package. A tune will take advantage of all of those components. We’re likely to see tuner shops digging into these cars as soon as they hit the ground. Based on what I see here, it likely won't be very complicated for them to make even more power than the Z4 M40i. cheers, Dave |
01-22-2020, 04:16 PM | #31 |
Rep 195
Drives: 2019 540i xDrive
Love my B58. I chose the 540 over the 530 due to various reviews I read that gushed over the effortless power and the smoothness. I'll admit ... once I owned it I was surprised at just how smooth it really was. Couldn't be happier.
I know mine has less power than the M340 but still.... |
clee1982797.50 |
01-23-2020, 01:21 PM | #34 | |
Rep 10,351
VCG: 11129894803 OFHG: 11428583896/97
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
01-24-2020, 01:07 PM | #35 | |
Rep 859
2023 i4 eDrive40
2022 Acura MDX |
chassis6536.00 |
01-25-2020, 09:19 AM | #36 |
Rep 2,310
Drives: 9Y0 Cayenne S
Ward's has a decades-long relationship with the automotive industry, and the companies therein. It is in Wards' interest to publish supportive information about products, and steer a wide path around what may be unsupportive information, accurate and helpful to consumers though it may be.
01-27-2020, 11:43 AM | #37 |
Rep 2,432
Drives: 2021 M2C
I definitely love my B58. It's a beast, especially with MPPSK!!
01-28-2020, 07:41 PM | #38 | ||
Rep 2,051
01-29-2020, 12:46 AM | #39 | |
Rep 890
CT335xi684.00 |
01-29-2020, 07:29 PM | #40 | ||
Rep 2,051
01-30-2020, 01:12 PM | #42 |
Rep 2,956
I know a lot of people that won't buy BMW's today because of all the issues they had with the N54 especially the HPFP failures which is a shame because the N55 was a workhorse engine and it appears the B58 is another step forward in performance/reliability.
01-31-2020, 04:38 PM | #43 |
Rep 249
N54 sound is still a thing of beauty. I have a B58 and an N54 in my driveway and there's no comparison in which I'd rather have. Can someone put my N54 in my M240i? Lol
2011 X1
2018 M240i Estoril Blue 2007 335i Jet Black 1992 Eagle Talon TSi |
01-31-2020, 04:38 PM | #44 |
Rep 301
I absolutely love my B58 too... a really good all round engine, good performance, great economy for what it is, and so incredibly smooth. I'm so impressed with it that I've decided my next car will be an 840i. I know the M850 is quicker, but I just personally prefer the B58 engine - I figure it will be more reliable in the long term, and the cost of the M850 is just too much to justify I feel.
