06-18-2020, 11:06 AM | #2 |
Rep 1,487
Bolt pattern? Yes. Both are 5x112.
Blessed Beyond Measure
06-18-2020, 08:02 PM | #4 |
Rep 1,487
That's where you may run into issues.
06-19-2020, 09:10 AM | #5 | |
Rep 130
https://www.wheel-size.com/size/bmw/ Here is a 20" wheel comparison: Then use this site to run the spec differences. Front: https://www.willtheyfit.com/index.ph...h=8&offset2=30 Rear: https://www.willtheyfit.com/index.ph...9-0&offset2=44 You would need spacers front and rear. I would do 15mm in front and 20 in the rear for minimal poke (about 4mm) or 20mm front and 25mm rear for a greater poke (about 9mm). IMPORTANT: If you use spacers, you must get lugnuts that are the wheel spacer width longer. I believe stock are 28mm, so if running a 15mm spacer, you need to have 43mm lug nuts. Tire ratios are different front and rear as well with 35 on the G30 and 40 on the G11 fronts and 30 on the G30 and 35 on the G11, so be aware of that if you are getting G30 wheels with stock tires, those will not work on your G11.
Current: G01 X3 M40i (Carbon Black / Black Vernasca, Blue stitch Leather), E89 Z4 35i (Alpine White / Kansas beige leather), Ram 1500 Limited 4x4 (Black / Black leather), 2004 Honda Goldwing - Previously owned BMW's: E36 M3, E46 330i, E46 M3, F25 X3 3.5i M Sport, G12 750ix M Sport, F32 435i xdrive M Sport.
