02-02-2022, 12:44 PM | #1 |
Rep 106
seeking blendmount BV1-3032
Looking for a blendmount BV1-3032 before I pay full retail...
https://blendmount.com/aluminum-rada...y-3032-series/ |
02-15-2022, 01:57 PM | #4 |
Rep 106
see attached...
02-16-2022, 11:11 AM | #5 | |
Rep 11
I just got my blendmount and hoping to install this weekend. Did you watch any YouTube tutorial videos before installing? Or did you just wing it on the hardwire job? |
02-17-2022, 01:45 PM | #6 |
Rep 106
https://www.youtube.com/watch?v=jTQFVoRIkuE&t=60s
Also, figured out wire colors and pins via this thread: https://www.bimmerfest.com/threads/w...#post-13655426 |
02-19-2022, 01:54 PM | #7 |
Rep 11
The video and the thread were super helpful! It looks like I need to buy a mirror tap setup to connect the detector with rj 11 on one end and pins to put into the wiring harness on the other. Did you buy a particular brand?
02-19-2022, 08:29 PM | #8 |
Hide! My wife's coming!
812
Rep 2,816
I used Amazon and laid under $20. Worked like a charm. All the same. Just make sure to get the one that has different size pins.
02-20-2022, 01:32 PM | #9 |
Rep 106
03-03-2022, 06:51 PM | #10 |
Rep 11
Finally finished the Blendmount-V1Gen2 project… an electrical engineer friend who helped with the project recommended that I drive around for awhile with it installed before I replace the interior trim pieces just in case the electrical connections work their way loose from bumps or vibrations. I had a big of a tough time getting those trim pieces off initially so I readily agreed. Here's the finished look.
03-03-2022, 10:40 PM | #11 |
Rep 106
pmac23 Looks good!
Did you have to tape up the gesture control sensor area? I did. Also, I opted to bring the wire out from the trim differently than your setup... Lastly, I zip tied the mirror tap wires to the respective harness wires as well as zip tied the mirror tap shielded cable to the harness cable. |
