03-12-2022, 10:40 AM | #1 |
Rep 312
CTEK MXS 5.0 Installation
Hi all,
I have purchased the above and want to hardwire it into the terminals under the bonnet / hood. I have had a look at other posts, so know it is not a big job, HOWEVER, what I don’t know is what to do ref the posts - I don’t want to cause myself other issues. Are the posts bolts that screw into a nut fixed in the body, or are they actually nuts that fit over fixed posts. Ie. If I undo one, do I end up with a bunch of loose cables, or are they fixed over a post that I can just add the CTEK eyelet connector to. I have just installed one on our other car, and that was simply a case of attaching to the battery itself under the bonnet / hood. If only I had access to TIS still! Thanks Mark
03-13-2022, 09:57 AM | #2 | |
Rep 1,595
BMWCCA
03-13-2022, 12:05 PM | #3 |
Rep 312
Thank you, yes it is the positive that I am unsure of. If it was just a nut / cap over an M8 threaded post, then that would be a breeze. I know that others have done it, so hopefully they will also chip in.
Many thanks Mark
04-10-2022, 02:19 PM | #4 |
Rep 312
For anyone interested, here is the definitive answer, as I finally got stuck in today.
The negative post is a nut over a fixed post, so easily undone, no issues. The positive post is a bolt, however, there is nothing attached to it, so can be fully undone and removed, leaving a threaded aperture behind. I am going to modify the red cap to allow the CTEK wire to come out that way, as it is removable, and easily replaced to return to stock, which is more difficult if I were to modify the black housing. Hope that helps anyone else doing the same.
