06-26-2019, 06:23 PM | #1 |
Rep 891
Ambi Light LED strip
So I have noticed my lower ambiental LED strip is lighting very uneaven and bearly visable at some places, and it is the same on all 4 door panels and the dash trim. The upper one lights good but the lower one is very uneaven. Did someone have the same problem?
06-27-2019, 04:54 AM | #2 |
Barge driver
8656
Rep 12,425
Do you have any pictures? I have one tiny spot on the upper strip on the dash that has discoloured slightly you can see it in day but at night the light emitting from the strip hides it.
730d/Z4C
06-28-2019, 09:48 AM | #3 |
Rep 137
Mine is the same way.
It's not terrible, but it is noticeable. It's a 2016 model, so I'm wondering if it's a first year problem. None of the others I've been in or had as loaners have this problem. |
06-28-2019, 09:55 AM | #4 |
Rep 669
I had a problem with the ambient lighting when I had my car. If it doesnt fix itself, the dealer will fix if under warranty.
06-30-2019, 11:49 AM | #5 |
Rep 891
So i took the passanger door trim apart and took a look at the ambi light assembly, there seems nothing to be out of place, but only thing I noticed is the see through plastic light guide that runs through the door trim had some lines like it was broken and the light seems to be lower on thease parts.
Unfortunatley they can not be bought separtetly but only comes with the trim. |
Wills28656.00 |
07-02-2019, 09:08 AM | #7 |
Rep 891
07-02-2019, 09:56 AM | #8 |
Rep 398
I agree--I also see others complaining on Bimmerpost about uneven ambient lights in their brand-new BMW's. I wonder if the supplier has QC issue or whether this happens to other makes. I also see that the newer bimmers have different ambient lighting, with straight pipes rather than curved ones, perhaps to address the tendency for the light tube to crack.
07-06-2019, 08:14 PM | #9 |
Rep 891
So I have managed to buy the new optical fibers for all 4 doors and replaced them and now it is perfect, all is even and much brighter.
However the front trim optical fibers does not come separate but only with the whole trim which is expensive. |
07-08-2019, 01:55 PM | #10 | |
Barge driver
8656
Rep 12,425
Do you have the part numbers by chance?
730d/Z4C
