      04-18-2019, 01:33 PM   #1
DMAX745i
DMAX745i's Avatar
Drives: E65, F01, F01, now G12
Just finished Chrome delete on Front grill and Rear Trunk Trim. Also wrapped front and rear reflectors. I also have lots of photos to include a Safe and Easy step by step process do disassemble the front grill.
DMAX745i
      04-18-2019, 01:45 PM   #2
Staszek
Schumacher
Staszek's Avatar
786
Drives: E30 325is,E93 M3,X7M50,F06 M6
Nice job! I am glad mine came with the chrome delete already, I would have done it, but its a lot of work. Such a difference on the M Sport.
      04-18-2019, 01:48 PM   #3
DMAX745i
DMAX745i's Avatar
Thanks Staszek. Did grills in a few hours and rest took a couple hours. Im just marking up a few photos to show the easy way to take apart grills to easily wrap cars ourselves. A lot easier than most think.
DMAX745i
      04-18-2019, 01:53 PM   #4
DMAX745i
DMAX745i's Avatar
REMOVING AND SEPARATING GRILLS
See photos below
I will number steps according to order of the photos.
1- Simply place a flat head screw driver in the three circled holes and press gently. Not too much as you dont want to break the clips. Work your war around the grill and pull gently and it will slide forward. Driver and passenger side come out the same way.
****NIGHT DRIVE CAMERA****
Of your car is equipped with night vision camera, please understand that its mounted in the drivers side grill. This grill is much more difficult to get out as the camera housing is slightly larger than the opening due to motorized grill vents.
**option 1, you will have to pull harder on this one, thought i was going to break something but then it just popped out nicely. This is how i got mine out.
**option2, let motor run until vents on front grill open up, leaving more room for grill to slide out. I reinstalled my grill using option 2 after it gave me trouble to reinstall way #1
2- ****This ONLY APPLIES to cars with night vision camera.
I recommend not to trouble the camera or lines attached. Up to you if you want to remove but so you know, the chrome bezel is removable which i will explain in the following steps. Improper disconnection could result in needing to recalibrate the camera.
3 & 4- there are a few locking tabs which pop out very easily with a SMALL flathead screw driver or pointy tool. Again, be gentle to not break these clips.
5 & 6- these are hinge clips. They were the tightest ones to get out but they eventually gave in.
7 & 8- These were actually the first tabs i popped out bus as i was working on other tabs, some of them popped back in so i put in as the last step.
9,10 & 11- VOILA. Grill is separated and ready to be wrapped. You can wrap either just the chrome piece or wrap the the inner slats too. I went with the 2 tone grill. Just my preference. Dont want it overly done.
DMAX745i
Wills28656.00
      04-18-2019, 01:53 PM   #5
pcrispy
Drives: '16 750i G12 M Sport, '12 528i
How easy was the back strip (and small pieces in the lights)? My grill is already black, but I've considered a gloss black for the back trim to match. Singapore Grey car color.
      04-18-2019, 01:55 PM   #6
DMAX745i
DMAX745i's Avatar
Too easy. Working on posting the DIY. GOT TO MARK UP PHOTOS. BUT WAY TOO EASY. ORDERED EVERYTHING OFF OF AMAZON. OOPS CAP LOCK🙈
DMAX745i
      04-18-2019, 01:56 PM   #7
DMAX745i
DMAX745i's Avatar
DMAX745i
      04-18-2019, 02:31 PM   #8
pcrispy
DIY would be awesome, along with a link to the Amazon stuff!
      04-18-2019, 03:02 PM   #9
DMAX745i
DMAX745i's Avatar
Amazon stuff as follow's
High gloss black vinyl. $23.99 cdn
Material stretches very nice with simple hair dryer.
Black High Gloss Realistic... https://www.amazon.ca/dp/B017BVZE5G?...p_mob_ap_share
Vinyl wrap tool kit. $12.49 cdn
Vehicle Vinyl Wrap Window Tint... https://www.amazon.ca/dp/B0719J99HL?...p_mob_ap_share
DMAX745i
pcrispy17.00
      04-18-2019, 06:44 PM   #10
DMAX745i
DMAX745i's Avatar
Front side Markers were really easy to do.
1- Cleaned the surface
2- Applied piece over sidemarker
3- Heat up with Hair dryer or heat gun
4- line out edges of sidemarker
5- Carefully cut out with small Xacto knife or blade.
6- Just "APPRECIATE" its beauty
DMAX745i
      04-18-2019, 06:49 PM   #11
DMAX745i
DMAX745i's Avatar
Working on photos for easy step-by-step diy for wrapping front grill. Total spent on blacking out my whole car $40 w/tx and some of my time.
DMAX745i
      04-18-2019, 06:59 PM   #12
pcrispy
Did you not remove the back strip? Just applied the wrap with it on the car and then razored it? Just curious how easily the edges would start to peel?
      04-18-2019, 07:13 PM   #13
DMAX745i
DMAX745i's Avatar
The chrome on the TailLight's is mounted most like with a 2 way tape. I would not be in the mood to clean off the tape nor try to re-centre the piece after. I wrapped all the pieces on the car. Fortunately for my i have quite some experience with modifying cars so ive done many different type of interior mods and customizing.
Wrapping the chrome strip was extremely easy. The surface must be properly cleaned with a degreaser before starting. (Dish soap works fine)
With the right amount of heat, glue will activate properly and stick to the cleaned surface. Trimmed the edges after properly stretching the material.
Ill post the DIY later on. Need to mark up photos.
DMAX745i
pcrispy17.00
      04-25-2019, 05:25 PM   #14
bportman86
Drives: 2019 BMW 740i
Do you think the back pieces are gonna last since you didn’t take them off? I had a shop here in KY tell me they wouldn’t do it because it would just come off after a few car washes.
      04-25-2019, 05:31 PM   #15
DMAX745i
DMAX745i's Avatar
Originally Posted by bportman86 View Post
Do you think the back pieces are gonna last since you didn't take them off? I had a shop here in KY tell me they wouldn't do it because it would just come off after a few car washes.
Only reason vinyl wrap would come off is if pieces are not cleaned with a degreaser and must heat up vinyl hot enough to activate the glue.
DMAX745i
      04-25-2019, 06:14 PM   #16
bportman86
Sounds good, I’ll probably be doing this in the next few days.
Any tips? I looked today and saw the glue you mentioned before definitely didn’t want to mess with prying that off and putting it back on.
      04-25-2019, 08:55 PM   #17
DMAX745i
DMAX745i's Avatar
Curious to know what brand of wrap your using?
DMAX745i
      04-26-2019, 08:31 AM   #18
bportman86
3M 1080 gloss black
      04-26-2019, 04:12 PM   #19
DMAX745i
DMAX745i's Avatar
3M 1080 gloss black
3M wrap, good material. Stretches very nice
I would start with the smaller pieces on the tail lights first. PLEASE MAKE SURE TAIL LIGHT AND CHROME STRIP ARE SUPER CLEAN. Very important to have surfaces perfectly clean. Sometimes you need to peel back some of the vinyl to reapply, and if it picks up dirt, good luck getting it to stick again. If surfaces clean, you can peel back 5-10 times without ruining glue.
Dont work with a piece of vinyl thats way oversized. Easier to work with and minimal wasteage if you have to redo a piece.
Use HEAT-GUN for best results.
Work in a dust free environment. Youll see every piece of dust push a spot in the vinyl. Wet the area around where your working to prevent dust from kicking up under the vinyl while you work.
If its your first time, you can mist water on the surfaces and it allows for peeling back easier if you make a mistake, just make sure to apply vinyl from one side to the other to minimize air/water bubbles under material.
Once your done, you may notice a few bubbles under the wrap, work the air/water bubble into a small area then poke it with xacto knife, and work air/water out the little hole. 3M vinyl is self healing, so after you work out air pockets, apply some heat and massage piece and voila. Perfecto.
I redid my piece in Carbon. What u think?
DMAX745i
      04-26-2019, 09:15 PM   #20
bportman86
Looks good. Can you post a pic where I can see your black spoiler.
      04-26-2019, 09:23 PM   #21
DMAX745i
DMAX745i's Avatar
In one of the photos you can see how easily i did the sidemarkers. Once i started to apply heat, the edged of the sidemarker stand out. Massage the edges and then carefully cut it out with exacto knife. By fluke, when i was massaging the edges with my nail, it ended making a perfect cut in the vinyl and i just used my finger to cut it out. Was kind of funny. No risk of scratching paint. 🙈
DMAX745i
      05-02-2019, 09:16 AM   #22
The.M5
The.M5's Avatar
Abu Dhabi
69
Drives: M5 F90 2018
Woh .. some great job has been done
Instagram: The.m5
