      07-03-2018, 06:42 AM   #1
Jlnike
Drives: 08 e90 m3 07 e90 328xi
Launch control
Can anyone confirm it works on g12 750 m sport?
      07-03-2018, 08:17 AM   #2
Jlnike
I see that it works via watching on YouTube I don't get what I'm doing wrong
Traction off
Sport mode
Sport shift
Hard break
Full accelerator to floor
No flag ever comes up showing launch control
      07-03-2018, 11:59 AM   #3
Jlnike
Do you really have to drive 6 miles before it gets enabled or does the car just need to be warmed up?
      07-03-2018, 09:37 PM   #4
roho3323
The Professor
roho3323's Avatar
Drives: BMW M6, BMW M240i, BMW 750i
I didn't even know our 750 msport had launch control? Do you have the YouTube link to share?
2010 BMW M6
2007 BMW 335i,2012 Audi S4-retired
2016 BMW 750i M-Sport
2015 BMW M235i-retired, 2022 M240i
      07-31-2018, 07:50 AM   #5
felixleasing
Drives: 2018 M5
Traction off
Sport mode
Sport shift
Hard break
Make sure you put the shifter in MANUAL mode, otherwise you are all good.
      07-31-2018, 08:32 PM   #6
Jlnike
Sport shift mode or actual manual mode so car will hold first?
      08-01-2018, 11:50 PM   #7
felixleasing
Drives: 2018 M5
Here is a link to this being discussed before
https://www.7post.com/forums/showthread.php?t=1333567
      08-02-2018, 05:14 AM   #8
Jlnike
Ive seen it, it's never worked for me.
      08-02-2018, 06:25 AM   #9
felixleasing
Drives: 2018 M5
Make sure you are I manual mode on the shifter.
That’s the trick to engage
      08-02-2018, 08:02 PM   #10
Jlnike
I think that's it... my m3 wouldn't allow it in manual so I never tried it on this one. So you literally have to paddle down to 1st? Probably makes sense because the car starts off normally from 2nd I think... wouldn't make for a quick launch.
      08-02-2018, 10:14 PM   #11
felixleasing
Drives: 2018 M5
Correct
      08-05-2018, 11:24 AM   #12
Jlnike
Still doesn't work,, I'm gonna have the dealer check it out next service.
Can anyone confirm if they have a sport plus mode or just sport and individual sport?
      08-10-2018, 11:30 AM   #13
Pelo Cat
United Kingdom
93
Just to check, you have run the car in first right? (done at least 1200 miles in total)...I believe some launch modes are disabled until after that time which may be the issue? (certainly not good to do it in the run in period)...
If you have more miles than that can't help! (Not tried it on mine but only a 730d so not expecting it to launch anyway!)
Safe travels.
      08-10-2018, 09:43 PM   #14
Jlnike
Tried everything 20k miles in
      08-12-2018, 08:53 AM   #15
Pelo Cat
United Kingdom
93
My F01 had a sport + mode and was an SE model...
My G11 SE only has sport and sport individual (June 2016 build). I believe only M Sport models now have the sport + but may be wrong? (and as you have an M Sport you should have sport + if that is the case).
Hoping someone else can help you out.
      08-12-2018, 01:39 PM   #16
Martin2C
Drives: 2017 750i M Sport
Just Sport and Sport Individual on my 2017 750 M Sport. You get a bit more ‘sport’ by moving the gear selector across to the left, that’s when I get full noise from the M Sport exhaust. But unlike Sport+ on other BMW, the full safety net stays on.
      08-12-2018, 09:46 PM   #17
Jlnike
Martin2c have you successfully used launch control?
      08-13-2018, 10:45 AM   #18
Martin2C
I haven’t tried yet, it’s quick enough off the mark in D! Will give it a go when I can and let you know.
      08-13-2018, 07:42 PM   #19
Jlnike
I have dinan tune and want to feel it launch
      08-14-2018, 01:42 AM   #20
Sjoerd
Sjoerd's Avatar
Netherlands
19
Drives: MY18 G11 750i, MY13 911S x51m7
So Launch Control:
I have a rear wheel drive but guess it works with x-drive as well.
Engine on; engine warm! (So 15m/20k of driving)
Press DSC only once; it will mention 'TRACTION' in the screen
Gear Lever to the left in S. Don't put it forward or backward to select manual. Only in S.
Left foot firm on the brake; brake to the max
Right foot firm on the gas; all the way through kickdown
A finish flag will show; revs should build up.
Release the brake, keep the pedal to the metal
Current: MY18 G11 750i (daily), MY14 Porsche 991 S (x51, m/7) (fun), MY17 Mini Clubman JCW All4 (GF)
Retired: MY14 F10 535d, MY11 F11 530d (temp), MY10 F10 535i, MY87 BMW E30 325i (fun), MY74 BMW E3 2500 (fun) (and more..)
      08-14-2018, 06:36 AM   #21
Jlnike
Originally Posted by Sjoerd View Post
So Launch Control:
I was holding traction off didn't know there was 2 different modes dynamic traction control or Dsc off
Thanks
      08-15-2018, 06:30 AM   #22
Jlnike
It worked... finally.
Thanks
