07-18-2022, 11:26 PM | #1 |
Rep 58
285 all around?
I have four 20X10 O.Z. SUPERTURISMO DAKAR with 285/40R-20 PIRELLI SCORPION WINTER STAR BMW XL tires from my X5M which was gone, can I use these winter wheels/tires set on my g12 750i?
07-20-2022, 03:16 PM | #2 |
Rep 7,462
An F85 X5M wheel specs are:
The G11 7-series wheel specs are:
The G11 wheels have a totally different wheel bolt pattern and hub size. So to mount F85 wheels onto a G11 would require some augmentation to get the wheels to fit. I would have to run the tire specs through a tire size calculator to see if the 285/40/20 tires are equivalent. Here's a link to a site that will allow you to compare the two tire & wheel sizes to see if there's too much poke (toward the fender) or too much inset (toward the suspension)...as well as give you info about height and width: www.willtheyfit.com
07-21-2022, 12:14 PM | #3 | |
"Salud"
13791
Rep 4,668
265 front is the widest I would attempt. I do have 305 out back.
