07-17-2014, 03:32 AM | #1 |
Rep 623
Coding for Tire Pressure Monitor?
Any help on this? I changed 3001 RDC_SAFETY to aktiv and confirmed it was saved by exiting the program, restarting and checking the value but the display is the same as before, just -- for the psi and temps and the bottom says "Reading tire pressure values..." or something along those lines. I drove around for a couple miles and could not get it to display any info. I did try pressing reset which didn't seem to do anything either.
07-17-2014, 10:42 AM | #3 |
Rep 623
I never had any readings, just dashes and it saying it's checking tire pressure. Was it supposed to show the tire pressure even without the coding? Is the coding only to get temp readings also?
I do have the tech pkg.
2014 BMW M235i 6MT
2012 Mercedes E350 Bluetec |
07-17-2014, 11:09 AM | #4 |
Rep 623
Scratch that...for some reason it works this morning. Drove about 3.5 miles vs 2.5 miles last night, maybe I didn't drive far enough last night?
Weird thing is that it never showed anything there, it was always just "-- psi", was it supposed to work even without the coding, at least the psi part? |
07-17-2014, 11:21 AM | #5 |
Rep 5,262
ya before coding shows just PSI... after it adds temperature but you need to drive for 1 or 2 minutes before it starts showing... and i think do an initial reset
07-17-2014, 11:27 AM | #6 |
***** noob
1372
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
What about ppl wihtout the nav/tech pkg???
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
07-17-2014, 12:42 PM | #7 | |
Rep 333
08-21-2014, 10:19 AM | #9 |
Rep 3
TPS do not work on cars without Nav Sys
08-21-2014, 10:41 AM | #10 |
Rep 5,262
08-26-2014, 04:48 PM | #11 | |
Rep 3
Not reading :(
I guess there is something in the hardware that my car is missing. |
08-26-2014, 05:49 PM | #12 |
Rep 5,262
if you have rubber stems it will never work.... you don't have the sensors...
you need metal stems to be able to read the temp and psi Looks like the only requirement for psi and temp are metal stems as it doesn't matter if you have tech pkg or not |
08-27-2014, 09:43 AM | #13 |
Rep 89
I thought we are all having metal stems... Is it due to not having the Tech pkg?
08-27-2014, 11:05 AM | #15 |
Rep 89
