BMW 3-Series (E90 E92) Forum
Interior Trim Wrappers, chime in please!
02-06-2015, 07:27 PM | #1 |
Rep 1,052
For the folks who've done trim wrapping:
Wondering your best advice for the corners/edges and inner rounded trim corners where the vents are. For the vent holes especially, what's the best way to cut the fabric so you get the most even wrap? I got my brushed black metallic film and I'm ready to say goodbye to that wood. Thanks!
'08 328i | TiAg | 6MT | CDV Mod | RevMotoring Silicon Intake Tube | AG M310 | Cold | Premium | HiFi | V1 Hardwire | AirPlay - FiiO DAC
'15 Golf SE Sport | Pure White |
02-07-2015, 12:31 PM | #4 | |
Rep 1,052
I'm basing my project off this by AlphaOm
http://www.e90post.com/forums/showthread.php?t=690972 Quote:
I'm really bummed though because the piece of vinyl I was shipped seems to have the grain running the wrong direction to get my long pieces done and have the grain go the proper direction. I'm not quite sure how this could be.
02-07-2015, 05:52 PM | #5 |
Rep 1,052
I posted pics in the main forum section.
http://www.e90post.com/forums/showthread.php?t=1088779
02-08-2015, 02:02 PM | #6 |
Rep 405
Apply heat and stretch. Also notch the vinyl to help get around bends and not have it bunch up. I did my trim in black and red cf vinyl and roof in 4 d gloss cf. definitely take your time and start from one side to other. Not from the middle.
02-09-2015, 10:07 AM | #8 |
A family of bimmers
2757
Rep 7,743
you removed the actual vent from the trim correct? that will make it much easier to wrap those corners. Also, just cut the opening at a 45 to the corners but not all the way to the edge, leaving about 1/4-1/2 inch of vinyl to stretch. you'd be amazed how much it will stretch and be manipulated with a little heat.
for around outside corners, i find its best to get the corner first and work your way towards the flat edges. low heat from a hairdryer is highly recommended. just dont get too close with it. ill edit this post later with pics of mine with brushed steel.
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
02-09-2015, 10:24 AM | #9 | |
Rep 1,052
02-09-2015, 11:09 AM | #10 |
Rep 1,933
My advice to you is:
-Buy a heat gun; I got a cheap one that was like $20-30. Its a lot quicker than a hairdryer -Think about what part you are wrapping; I'm a perfectionist so I spent a lot of time on every corner only to realize that most of them aren't even visible after reinstalling -Take your time; It is a tedious process that you need patience for. Carefully heat an stretch since too much of either can damage the vinyl. |
02-09-2015, 11:29 AM | #12 | |
A family of bimmers
2757
Rep 7,743
02-09-2015, 12:24 PM | #13 | |
Rep 1,052
Though I didn't need the heat gun. My wife's Conair hair dryer was plenty hot for this job. I started with the ash tray cover, figuring that'd be easiest and then did the small dash piece to the left of the steering wheel to get the hang of a vent opening. I felt very comfortable after both of these and jumped right into the center console, which was actually very easy. For me, the door strips were the hardest ones even though they seemed like they were going to be the easiest.
02-09-2015, 12:34 PM | #14 | |
Rep 1,933
02-09-2015, 01:16 PM | #15 |
Bit by Modbug
258
Rep 1,109
Majority of the vinyl you get are easy to use, but I've ran into a couple kinds that were extremely difficult to use. I've re-wrapped my interior 6 times now and have went through 6 different brands, the super cheap CF vinyl ones works the best but they get scratched the easiest. Glossy ones are harder to work with, when you "redo" as in peel and apply again it leaves a permanent crease in the vinyl that can be seen under lights.
Cheap china made CF stretched so easily and the air bubbles could be pushed out in one or two tries. 3M/Avery glossy ones are not that bad, they just leave a permanent crease if you try to peel it back off.
Current: F86 | F30
Past: Cayenne GTS | Abarth 500 | YMB M4 | X6 M50i | E92 M3 6MT | X3 M40i | E92 335i Stage 3 | G35 Coupe |
02-09-2015, 04:08 PM | #16 | |
Rep 1,052
02-09-2015, 04:47 PM | #17 |
Rep 2,084
Anyone have comments on 3M 1080 vs. Di-Noc? I'd like to do the carbon fiber wrap and think the Di-Noc looks more realistic, but I've heard it's less forgiving when installing.
2013 135is DCT Carbon Black Metallic |
02-09-2015, 06:16 PM | #18 |
Quiet till poked
99
Rep 1,176
3M 1080 was developed to be easier to wrap. Thus it is also a thinner wrap compared to Di-Noc. So yes, Di-Noc does look more realistic with certain variations such as carbon fiber. However, since it's thicker, it is slightly harder to use. Personally, I think the 3M 1080 is better for anyone that's starting out and wants to do the job quickly or knowingly will change it again 6 months down the road. Also note that, if done properly, 3M 1080 is quite convincing. I've gone through a couple different wraps (all 1080) and each time my passengers thought I bought new trim.
02-09-2015, 08:09 PM | #20 | |
Rep 1,052
Clean the pieces down with 91% isopropyl alcohol, wipe with lint free cloth/microfiber, apply vinyl.
