BMW 3-Series (E90 E92) Forum
Deleting adaptive headlights??
03-31-2015, 05:28 AM | #1 |
Rep 14
To start off, I have searched.. alot..
So here's the lowdown. I'm in need of an adaptive headlight replacement for the third time in around two years. The roads around here just take a toll on these things. (Though this time it was condensation that killed it). Tired of dishing out the time and money constantly to just have the other side have an issue a couple months later. So I've went ahead and ordered a set of ecodes, they should be getting here before this weekend. So I know I'm going to need to code out the adaptive function, but is there anything as far as the wiring harness that I'm going to have to modify? Has anybody on here done this? Walk through or tips on coding them out? Thanks |
03-31-2015, 08:25 AM | #2 |
Stance to make her dance
717
Rep 2,007
You shouldnt have to modify any wiring of any kind. Coding should take care of it.
You know, the adaptive feature only works when the headlights are in AUTO. You could just leave the functionality (in case you ever want it back again), and just flip your headlights to the ON position each time...
INSTAGRAM: thompsac_m3 YouTube: ACCELERATED MOTION
2023 G80 CX M3, Individual BRG |
03-31-2015, 09:47 AM | #3 |
Rep 2,773
autoleveling in adaptive headlights actuated via adaptive modules
so, when you replace them with non-adaptive, you should wire this function to another pins in FRM and in both headlight connectors
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
03-31-2015, 10:11 AM | #4 | |
Rep 14
03-31-2015, 10:24 AM | #5 | |
Rep 14
Sorry for the noob questions |
03-31-2015, 10:54 AM | #6 |
Rep 2,773
what is ecodes ?
03-31-2015, 12:38 PM | #8 |
Rep 14
haha, sorry. They are the black housing depos, and not even e-codes at that, forgot I ended up just ordering the dot ones cause the ecodes were crazy expensive.
Anyway, for knowledge sake. All e-code means is that it complies with the euro spec, so a tighter light pattern and a couple other small changes. Last edited by JMEngland88; 03-31-2015 at 12:48 PM.. |
